Hi Martin10522 - It doesn't usually matter what language it's in.
The reports are set up the same no matter what language is used.
There's also a lot of English in the reports, so I can figure most of it out.
Finally, I can copy and paste - so if there's something in Chinese that I need to know, I'll copy it into a post and will ask you what it means.
OK, please open up Device Manager. You'll see that there's an error related to an ISATAP adapter. Please right click on that device and select "Uninstall". The device usually won't come back, so don't worry about that.
You appear to have dump files being generated - but when submitted to Microsoft OCA the dump files are determined to be "bad" for some reason.
You have an application error in Set5D2C.tmp - which is usually suspicious (a temp file running as an executable). I'd strongly suggest a virus scan or two to ensure that you're not infected.
You're also experiencing errors in a program named SD_Bot.exe Most references to this refer to a cracking program. Unfortunately we're unable to help with cracks/warez. There's 2 reasons for this - the first being that they're illegal, but the second is that they don't behave as a normal program should - so they aren't amenable to normal troubleshooting.
In short, I suspect that this is due to an infection and would suggest that you post over in the security forums for assistance:
System Security - Vista Forums
