Bsod while playing GTA 4,help please!
Edit:perhaps it is because my computer are cantonese(chinese) so its corrupted for you??not sure lol.
No, minidumps are just memory. They're not "localised" (they don't come in different languages).
As a suggestion, try uploading more of them. It's possible that subsequent minidumps will be intact.
Ok,i have another quest,if i get like 100 bluescreen will my computer be more slow or will it get damaged or something?thanks.and ill do that when i get back home...
Its your case. If you want to play games you need air. Removing the side panel will make it worse. Ideally, you'd want one exhaust at the top, one at the back, 2 intake at the front and one on the side.
I dont really understand why will it make it worse lol,can you explain some more :P??
my side panel at the right has no holes so i thought removing it will be better,correct me if im wrong..
Oh,so all the side on my computer should have those small holes/fans?Thanks for the suggest!
but can you tell me the normal Temp while playing games/on windows and what is the temperature for overheat?thanks.
    Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    Lenovo 1440 X 900 60Hz
    1440 X 900
    1TB
No side panel means the air can escape not rebound into the case. Ideally, your cpu should be under 60 degrees celsius and a gpu can get up to 100 C, so you want lots of cooling. Lots.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Yeah,but thing is the right panel does not have any hole,thats the reason why i removed it,should i put it back?
Also i tried to check my temp,without playing gta 4
It is 45~55
While playing its 50~59,sometimes it can go to 61 but hardly...
And GPU stays 40 to 41 all the time...
I cant believe my computer is 50degree and i dont feel hot lol..is that my system monitor's problem?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
That's fine, put the panel back. If you can't install any extra fans, I'd wait until you can build a new PC.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
-.-...not again,i bought this 5 weeks ago...
ima go play gta 4 now and get some bluescreen
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
OK something i wanna say also
Bluescreen only happens while playing GTA 4(happened once while im not but only once..)
Also i found a *.dmp file on C:\Windows but its 205MB
and its called memory.DMP is it the one?
the dump file is that large because it is set to entire memory in system control panel. you should go into the system control panel>advanced settings>start up and recovery>change to kernal dump
ken
i've just got another bluescreen while surfing the net,here is some detail.
問題簽章:
問題事件名稱: BlueScreen
作業系統版本: 6.0.6002.2.2.0.768.3
地區設定識別碼: 3076
與問題相關的其他資訊:
BCCode: 1000000a
BCP1: 81D16B00
BCP2: 0000001F
BCP3: 00000001
BCP4: 81C7942A
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
協助說明問題的檔案:
C:\Windows\Minidump\Mini102109-01.dmp
C:\Users\Martin\AppData\Local\Temp\WER-75816-0.sysdata.xml
C:\Users\Martin\AppData\Local\Temp\WER5B29.tmp.version.txt
^ignore the chinese.
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
FFs,bluescreened again,but this time the message says
The video memory card has an unexpected faulty or something..
Here is the dmp file...
Edit:Was playing gta 4.
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
The .dmp is corrupted. Do you see this:
I think your mobo is broken. Can you try a clean boot?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Ok,i've setted the things like yours..but i thought i should choose the 64kb option??anyway..ill wait for another BSOD
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Im no expert on BSOD but i very much doubt its the case... your temps are ok.
if your running a quad core u dont want GTA4 split over the 4 cores... turn 2 off, and your memory is sufficiant enough to run GTA4 too. failing this, id suggest checking the HDD for errors on the disk.
your GPU is ok too.
    Acer 5630WLMi
    Intel Centrino Duo 1.66Ghz, 667MHz FSB, 2MB L2 Cache
    1x 2GB 800MHz DDR2
    Onboard 256 Intel Rubish
    Onboard Intel HD
    15.4" Crystalbrite
    160GB SATA
    N/A
    N/A
    N/A
    Laser Optical
    Laptop
    2.6mbps Download, Upload unknown (not tested)
your GPU is ok too.
Thanks for the suggest/idea.How do i turn 2 cpu off lol?
and btw while i was playing gta 4,the cpu usally goes on 1 and 2,but it never goes to 3,4,how can i set it to balance so all the cpu would work better?thanks.
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
lmao no yoo don't want too split it onto all 4 cores at all it will run dog slow worse than it is at the moment due to multi core not been fully supported by a fair amount of games.
    Acer 5630WLMi
    1x 2GB 800MHz DDR2
    Onboard Intel HD
    15.4" Crystalbrite
    160GB SATA
    N/A
    N/A
    N/A
    Laser Optical
    Laptop
That advice is highly misguided.
Please explain :confused:
If the game doesnt support muticore proccessing then its going to run badly if atal, i have games that dont support Dual core so i have to turn core 2 off to run it on 1.
When i had my quad core extreame that was the same problem worst of all it caused me to bin the damn thing as i was just constantly having to turn cores 3+4 on and off :sarc:.
i really dont think ive missguided atall
    Acer 5630WLMi
    1x 2GB 800MHz DDR2
    Onboard Intel HD
    15.4" Crystalbrite
    160GB SATA
    N/A
    N/A
    N/A
    Laser Optical
    Laptop
Anyway how do i turn my cpu off?
And btw i got bluescreen last night while playing gta 4,
i tried to wait but after 15 mins i had to sleep and it remains at phys dump:50 and it wont move...lets see if it is corrupted this time..
oh wait..there is no *.dmp file at minidump this time..
perhaps its because i turned it off but not restart..
and something strange is that..there was no reason while i had the bluescreen,normally it says something like memory card has an unexpected faulty or something but this time there is none...
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Open the start menu, click on Run,type in msconfig and click on OK
In the System Configuration window click on the start sub menu and the on Advanced Options button.
In the second window that appear, you should be provide with an option for enabling and disabling the number of processors you want to use.
Validate your entry by clicking on OK.
Restart your PC and it should be fine.
    Acer 5630WLMi
    1x 2GB 800MHz DDR2
    Onboard Intel HD
    15.4" Crystalbrite
    160GB SATA
    N/A
    N/A
    N/A
    Laser Optical
    Laptop
That will achieve nothing except to hobble his machine without any particular reason. It affects all processes - including the OS.
Processes which do not spin off sufficient threads to "use" all cores just use as many cores as they can. The unit of scheduling is the thread, not the process, meaning that it's quite possible and even common to have a thread from App1 on procX while a different thread from Game2 is on procY - except that will never happen if you get him to artificially limit the number of processors.
So should i turn them off??
Damn bluescreen is really annoying..i wonder if window 7 fixed this problem or not..
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
No, you shouldn't. It is vanishingly unlikely to have any positive effect on the situation, and if it did it would simply prove that the hardware (processor or motherboard) is broken. Otherwise, the only effect would be to turn your quad-core into a less-than-quad, thereby slowing everything down for no good reason.
The advice was well-meaning of course, but misguided.
Since the dumps generated by your machine are corrupted, it is not possible to troubleshoot directly. Once you're confident that nothing is over-clocked or under-cooled, the BIOS and drivers are up-to-date, in particular the video, it may be time to consider a clean build with absolutely nothing else except base OS componentry - stuff that came on the Windows disc.
After that, if your game still causes BSODs on a completely fresh Windows installation, you can be very confident of underlying hardware abnormalities.
As for whether Win7 "fixed this problem", there's absolutely no reason at all right now to suspect a bug in Vista. The vast majority of Vista users do not experience your symptom. Therefore, the cause is clearly environmental - something that's different about your software and/or hardware environments.
OK thanks,and btw,is there any website that can check if my drivers are up to date?
Also,what is the lowest requirment for window 7?
i wanna buy it lol :P
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
