SiSoftware Sandra
Display
Connection : Local Computer
Computer Overview
Analysing...
Finished Successfully : Yes
Mainboard
Analysing...
Warning 2533 : Disabled host controllers are present. Check BIOS settings.
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 2541 : FSB exceeds Chipset rated speed. Reduce FSB.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2543 : Memory hole may not be required. Check BIOS settings.
Warning 2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed.
Tip 2536 : Computer has no SMBus/i2c/BMB bus support.
Plug & Play
Analysing...
Mainboard Configuration
Analysing...
Processors
Analysing...
Warning 2533 : CPU 1 [Processor 0, Core 0, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 1 [Processor 0, Core 0, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 1 [Processor 0, Core 0, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 1 [Processor 0, Core 0, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 1 [Processor 0, Core 0, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Warning 2533 : CPU 2 [Processor 0, Core 1, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 2 [Processor 0, Core 1, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 2 [Processor 0, Core 1, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 2 [Processor 0, Core 1, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 2 [Processor 0, Core 1, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Warning 2533 : CPU 3 [Processor 0, Core 2, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 3 [Processor 0, Core 2, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 3 [Processor 0, Core 2, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 3 [Processor 0, Core 2, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 3 [Processor 0, Core 2, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Warning 2533 : CPU 4 [Processor 0, Core 3, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 4 [Processor 0, Core 3, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 4 [Processor 0, Core 3, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 4 [Processor 0, Core 3, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 4 [Processor 0, Core 3, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Warning 2533 : CPU 5 [Processor 0, Core 4, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 5 [Processor 0, Core 4, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 5 [Processor 0, Core 4, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 5 [Processor 0, Core 4, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 5 [Processor 0, Core 4, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Warning 2533 : CPU 6 [Processor 0, Core 5, Thread 0] : Disabled host controllers are present. Check BIOS settings.
Warning 241 : CPU 6 [Processor 0, Core 5, Thread 0] : Dynamic OverClocking/Turbo enabled. Performance may not be consistent and may not match expectations!
Tip 210 : CPU 6 [Processor 0, Core 5, Thread 0] : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Notice 224 : CPU 6 [Processor 0, Core 5, Thread 0] : SMBIOS/DMI information may be inaccurate.
Warning 236 : CPU 6 [Processor 0, Core 5, Thread 0] : Vcore higher than rated maximum. Check Vcore setting!
Buses and Devices
Analysing...
Tip 1202 : PCI : AMD F10h Athlon 64/Opteron/Sempron HT Hub : Device does not support bus mastering.
Tip 1202 : PCI : AMD F10h Athlon 64/Opteron/Sempron Address Map : Device does not support bus mastering.
Tip 1202 : PCI : AMD F10h Athlon 64/Opteron/Sempron DRAM Controller : Device does not support bus mastering.
Tip 1202 : PCI : AMD F10h Athlon 64/Opteron/Sempron Miscellaneous Control : Device does not support bus mastering.
Tip 1202 : PCI : AMD F10h Athlon 64/Opteron/Sempron Link Control : Device does not support bus mastering.
Warning 1209 : PCIe : PC Partner 6739h : Video card does not have an interrupt assigned.
Power Management
Analysing...
System Resources
Analysing...
Displays and Display Adapters
Analysing...
Tip 2221 : Video Adapter : AMD Radeon HD 6800 Series (960 SM5.0 775MHz, 1GB 1GHz, PCIe 2.00 x16) : Driver is not certified.
Tip 319 : Video Adapter : AMD Radeon HD 6800 Series (960 SM5.0 775MHz, 1GB 1GHz, PCIe 2.00 x16) : A refresh rate of at least 75Hz is recommended. Increase it if possible.
Tip 328 : Video Adapter : AMD Radeon HD 6800 Series (960 SM5.0 775MHz, 1GB 1GHz, PCIe 2.00 x16) : Reduce resolution to improve video performance.
Warning 318 : Monitor/Panel : Dell 1708FP(Digital) : A larger/better monitor is recommended for this video mode. Consider reducing the resolution.
Physical Disks
Analysing...
Warning 3103 : WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) (E:) (G:) : Acoustic Management enabled. Peformance may be impaired.
Warning 3103 : WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) (D:) (F:) : Acoustic Management enabled. Peformance may be impaired.
SCSI Devices
Analysing...
Printers and Faxes
Analysing...
Communication Devices
Analysing...
Warning (2301) : Standaardmodem : Port in use. [48F]
Ports
Analysing...
Game Controllers
Analysing...
Error (1000) : No devices found. : No controllers present!
Audio Devices
Analysing...
Warning 710 : Wave Input Devices (Recording) : Microfoon (6- Logitech G330 Hea : Driver may be obsolete. Check that it is the latest version.
Tip 708 : Wave Input Devices (Recording) : Microfoon (6- Logitech G330 Hea : Mono sound devices are obsolete. Use a Stereo sound device for better sound experience.
Warning 710 : Wave Input Devices (Recording) : Microfoon (7- Logitech Micropho : Driver may be obsolete. Check that it is the latest version.
Tip 708 : Wave Input Devices (Recording) : Microfoon (7- Logitech Micropho : Mono sound devices are obsolete. Use a Stereo sound device for better sound experience.
Warning 710 : Wave Output Devices (Playback) : Luidsprekers (6- Logitech G330 : Driver may be obsolete. Check that it is the latest version.
Warning 710 : MIDI Output Devices (Playback) : Microsoft GS Wavetable Synth : Driver may be obsolete. Check that it is the latest version.
Warning 710 : Mixer Devices (Mixing) : Luidsprekers (6- Logitech G330 : Driver may be obsolete. Check that it is the latest version.
Warning 710 : Mixer Devices (Mixing) : Microfoon (7- Logitech Micropho : Driver may be obsolete. Check that it is the latest version.
Warning 710 : Mixer Devices (Mixing) : Microfoon (6- Logitech G330 Hea : Driver may be obsolete. Check that it is the latest version.
Mice and Track-balls
Analysing...
Keyboards and Tablets
Analysing...
Smart Cards and SIMs
Analysing...
Network Adapters
Analysing...
Network (LAN)
Analysing...
IP Network
Analysing...
Operating System
Analysing...
Tip 1300 : Enter your company name or "Home" instead of "Unknown".
Warning 1316 : This copy of Windows contains Product Activation Technology.
Tip 1324 : .NET Framework 1.1 not installed. Install to run legacy .NET applications.
Tip 1327 : Java Runtime Engine not installed. Install it to run the current Java applications.
Virtual Computers
Analysing...
Virtual Machines and Runtime Engines
Analysing...
Key Applications
Analysing...
Start Menu Applications
Analysing...
Memory Usage
Analysing...
Processes
Analysing...
Tip 1601 : [System Process] : Program consumes a large amount of memory.
Tip 1601 : explorer.exe (Windows Verkenner) : Program consumes a large amount of memory.
Tip 1601 : Steam.exe (Steam) : Program consumes a large amount of memory.
Tip 1601 : Skype.exe (Skype ) : Program consumes a large amount of memory.
Tip 1601 : SpotnetMonitor.exe (Spotnet Monitor) : Program consumes a large amount of memory.
Tip 1601 : MOM.exe (Catalyst Control Center: Monitoring program) : Program consumes a large amount of memory.
Tip 1601 : CCC.exe (Catalyst Control Center: Host application) : Program consumes a large amount of memory.
Tip 1601 : RpcSandraSrv.exe (SiSoftware Sandra Agent Service (NT)(Unicode)) : Program consumes a large amount of memory.
Warning (1600) : WmiPrvSE.exe (WMI Provider Host) : Process no longer exists!
Warning (1600) : HPNetworkCommunicator.exe (HPNetworkCommunicator) : Process no longer exists!
Modules
Analysing...
Sessions
Analysing...
Services and Drivers
Analysing...
Tip 2130 : Background Intelligent Transfer Service : Service may be disabled on Home/Professional OS version.
Tip 2130 : Computer Browser : Service may be disabled on Home/Professional OS version.
Tip 2130 : COM+ Event System : Service may be disabled on Home/Professional OS version.
Tip 2130 : TCP/IP NetBIOS Helper : Service may be disabled on Home/Professional OS version.
Tip 2130 : IPsec Policy Agent : Service may be disabled on Home/Professional OS version.
Tip 2130 : Secondary Logon : Service may be disabled on Home/Professional OS version.
Tip 2130 : WIA (Windows Image Acquisition) : Service may be disabled on Home/Professional OS version.
Tip 2130 : Terminal Services : Service may be disabled on Home/Professional OS version.
Tip 2130 : UPnP Device Host : Service may be disabled on Home/Professional OS version.
Installed Applications
Analysing...
Installed Processes
Analysing...
Components & Objects
Analysing...
Users and Groups
Analysing...
Warning 1329 : Local Users : ASPNET : Account is not secured (no password). Consider password protection.
Warning 1329 : Local Users : OldEvil1 : Account is not secured (no password). Consider password protection.
Warning 1332 : Local Users : postgres : Guest account is enabled. For security, disable if not needed.
Media Players
Analysing...
Cryptography and Certificates
Analysing...
Fonts
Analysing...
Media Devices
Analysing...
DirectX
Analysing...
Tip 2221 : Direct3D 9 Devices : AMD Radeon HD 6800 Series (\\.\DISPLAY1) : Driver is not certified.
Tip 2221 : Direct3D 9 Devices : AMD Radeon HD 6800 Series (\\.\DISPLAY2) : Driver is not certified.
OpenGL
Analysing...
Remote Access Connections
Analysing...
Logical Drives
Analysing...
Tip 1821 : Hard Disk (C:) @ SAMSUNG HD204UI (2TB, SATA300, 3.5", 5400rpm, NCQ, 32MB Cache) : Label (name) drive.
Warning (1829) : Optical Drive (H:) @ TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW, 2MB Cache) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
Warning (1829) : Optical Drive (K:) @ POPG DYV8PYNODY3 (SCSI, BD-R, DVD+-R-DL, CD-R) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
Warning (1829) : Optical Drive (I:) @ KVSTWN EJGXE3KH (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
Warning (1829) : Removable Drive (J:) @ Multi Flash Reader (USB) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.
Application Scan
Analysing...
Data Sources
Analysing...
File Types
Analysing...
Environment Variables
Analysing...
Analysis and Advice
