Solved bsod idk
ok so i went bk unticked all servises, ticked microsoft hide box, rebooted, now just use the computer as normal?
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
was there any more information you needed? havent got a bsod yet...
    toshiba satellite
Jason
Its my hunch that one of those start up programs is the cause of your BSODs
Just use the computer and if you get no more BSODS, put back half at a time to find the cause.
If that does not work, I will require more information.
Ill do exactly asyou say, you have been a big help iv learned a great deal in this 2 day excursion! thank you again for all ur help. why do you think my system restore is off? and should i try and make a restore point, or find out the cause of the bsod first, by checking start up programs? I know im full of questions, but im buyn the new calculator! lol
    toshiba satellite
Im trying to fix the BSOD first. Then it was always my intent to look into your other problems. We will make SR next. One possible cause is that a virus turned it off. We have to check for Virus and Malware, but lets do one thing at a time.
well rich maybe this will help you, im surfing as normal had a few diffrnt tabs open, i was running good, then i thought why not try and run the windows 7 upgrade mang, so i went to downloads, and had to retry download cause it didnt download lastnight, so i retry download, said the download was complete, i open soon as i try and open i get the bsod, now i look at downloads and the mangr never did download, idk if this helps, i hope i am being specif enough for you to understand what im saying
    toshiba satellite
I only need to know one thing. You had everything unticked and you got a BSOD?
i cant say positively.... but i just made sure everything is unticked now, and ill see if i get 1, is this what i should do?
    toshiba satellite
Yes untick everything if you still get BSOD we know that the startup items are not the cause. I will then give you a more traditional analysis. I was just going on a hunch with this one.
ok rich i did get the bsod with everything unticked,
    toshiba satellite
Send the reports like you did the last time. Ill give you the traditional analysis; my hunch did not pay off.
View attachment 23561 here is the report rich im not sure if its complete i got the bsod while it was in process,
    toshiba satellite
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Windows_NT6_BSOD_jcgriff2 (1).zip\Windows_NT6_BSOD_jcgriff2\Mini052711-02.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18327.x86fre.vistasp2_gdr.101014-0432
Machine Name:
Kernel base = 0x82c1a000 PsLoadedModuleList = 0x82d27930
Debug session time: Fri May 27 15:43:33.921 2011 (GMT-4)
System Uptime: 0 days 1:12:30.868
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {34, 2, 1, 82fc8fe9}
Probably caused by : ntkrnlmp.exe ( nt!KiTrap0E+2e1 )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000034, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, bitfield :
 bit 0 : value 0 = read operation, 1 = write operation
 bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 82fc8fe9, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 82d466d8
Unable to read MiSystemVaType memory at 82d272e0
 00000034
CURRENT_IRQL:  2
FAULTING_IP:
hal!KeAcquireInStackQueuedSpinLockRaiseToSynch+19
82fc8fe9 8711            xchg    edx,dword ptr [ecx]
CUSTOMER_CRASH_COUNT:  2
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  8077c878 -- (.trap 0xffffffff8077c878)
ErrCode = 00000002
eax=8077c8f8 ebx=8426d8d8 ecx=00000034 edx=8077c8f8 esi=00000000 edi=00000000
eip=82fc8fe9 esp=8077c8ec ebp=8077c904 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
hal!KeAcquireInStackQueuedSpinLockRaiseToSynch+0x19:
82fc8fe9 8711            xchg    edx,dword ptr [ecx]  ds:0023:00000034=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 82fc8fe9 to 82c74cc9
STACK_TEXT:
8077c878 82fc8fe9 badb0d00 8077c8f8 8077c8a8 nt!KiTrap0E+0x2e1
8077c8e8 82c8680b 00000000 85fab3f0 00000000 hal!KeAcquireInStackQueuedSpinLockRaiseToSynch+0x19
8077c904 82c867eb 8426d8d8 00000000 82cc6239 nt!ExpReleaseResourceForThreadLite+0x19
8077c910 82cc6239 8d76106c 94fef750 00000000 nt!ExReleaseResourceLite+0xf
8077ca60 82c3d612 94fef750 00000000 8d761030 nt!FsRtlReleaseFileForModWrite+0x168
8077cacc 82c3d554 8d761030 8d761038 00000000 nt!MiWriteComplete+0xb2
8077caec 82c9411f 953240b8 8077cb18 8077cb24 nt!IopCompletePageWrite+0x6f
8077cb44 82fcc453 00000000 00000000 00000000 nt!KiDeliverApc+0xce
8077cb64 82fcc668 8426d901 00000000 806d1120 hal!HalpDispatchSoftwareInterrupt+0x49
8077cb80 82fcc70c 00000000 8426d900 8077cbc8 hal!HalpCheckForSoftwareInterrupt+0x64
8077cb90 82c82f0e 8426d8d8 953240b8 00000001 hal!KfLowerIrql+0x64
8077cbc8 82c9466f 953240b8 95324078 00000000 nt!KiExitDispatcher+0x1db
8077cbe8 82c86cb4 953240b8 00000000 00000000 nt!KeInsertQueueApc+0x61
8077cc40 82c6017f 85fab3f0 00000001 00000000 nt!IopfCompleteRequest+0x36a
8077cc58 82c3d4a5 00000000 8d761030 00000001 nt!IofCallDriver+0x63
8077cc70 82cc6055 8077cca8 82c3d560 8d761030 nt!IoAsynchronousPageWrite+0x153
8077cd14 82c3d28a 94fef750 00000000 8426d8d8 nt!MiGatherMappedPages+0xaeb
8077cd7c 82dc25b9 00000000 dd9b1aa3 00000000 nt!MiMappedPageWriter+0x13d
8077cdc0 82ca964e 82c3d14d 00000000 00000000 nt!PspSystemThreadStartup+0x9d
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiTrap0E+2e1
82c74cc9 833dc0e6d38200  cmp     dword ptr [nt!KiFreezeFlag (82d3e6c0)],0
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KiTrap0E+2e1
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cb710de
FAILURE_BUCKET_ID:  0xA_nt!KiTrap0E+2e1
1: kd> lmtsmn
start    end        module name
8bda7000 8bdb4080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
83244000 8328a000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
8cf15000 8cf5d000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
8cc0c000 8cd07000   AGRSM    AGRSM.sys    Mon Apr 10 06:21:02 2006 (443A318E)
8339a000 833a2000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
833a2000 833c0000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
b4140000 b4227000   athr     athr.sys     Mon Jul 28 18:53:45 2008 (488E4DF9)
832de000 832e8000   BATTC    BATTC.SYS    Sat Jan 19 00:32:45 2008 (47918B7D)
8cd4b000 8cd52000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
83084000 8308c000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
addcf000 adde8000   bowser   bowser.sys   Tue Feb 22 08:23:54 2011 (4D63B8EA)
97b10000 97b1e000   cdd      cdd.dll      unavailable (00000000)
b4037000 b404d000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
8be81000 8be99000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
8cc00000 8cc0a200   cec_uvc  cec_uvc.sys  Fri Apr 10 04:58:58 2009 (49DF0A52)
830cd000 831ad000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
86f93000 86fb4000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
8308c000 830cd000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
8be1c000 8be1f780   CmBatt   CmBatt.sys   Sat Jan 19 00:32:47 2008 (47918B7F)
832db000 832dd900   compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
8c7a6000 8c7b3000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
86fb4000 86fbd000   crcdisk  crcdisk.sys  Thu Nov 02 04:52:27 2006 (4549B1CB)
8cfe0000 8cff7000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
86f82000 86f93000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
8c774000 8c799000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
8c7be000 8c7c6000   dump_atapi dump_atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8c7b3000 8c7be000   dump_dumpata dump_dumpata.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8c7c6000 8c7d0000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8bac1000 8bb61000   dxgkrnl  dxgkrnl.sys  Thu Jan 20 08:50:57 2011 (4D383DC1)
86f5b000 86f82000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
86c04000 86c14000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
833c0000 833f2000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
8cd3b000 8cd44000   Fs_Rec   Fs_Rec.SYS   unavailable (00000000)
8ce9e000 8ceb9000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8be99000 8be9e280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
82fc5000 82ff8000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8bb6d000 8bbfa000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
add45000 addb2000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
8be20000 8be33000   i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
8b404000 8bac1000   igdkmd32 igdkmd32.sys Wed Oct 22 20:18:23 2008 (48FFC2CF)
83341000 83348000   intelide intelide.sys Sat Jan 19 00:49:42 2008 (47918F76)
86ff1000 87000000   intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
adfd8000 adffe000   ipnat    ipnat.sys    Sat Jan 19 00:56:28 2008 (4791910C)
8be33000 8be3e000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
86343000 8634a000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8bfa9000 8bfd3000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
86c14000 86c85000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
adcee000 adcfe000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
832c2000 832cc000   LPCFilter LPCFilter.sys Fri Jul 14 20:40:36 2006 (44B83984)
8c7df000 8c7fa000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
83003000 83073000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
8cd07000 8cd14000   modem    modem.sys    Sat Jan 19 00:57:16 2008 (4791913C)
8c7d0000 8c7df000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
8be72000 8be7d000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8338a000 8339a000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
8cd14000 8cd3a680   MpFilter MpFilter.sys Tue Sep 14 17:23:59 2010 (4C8FE7EF)
8c7fa000 8c7ff900   MpKsl030c45d6 MpKsl030c45d6.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
8cfda000 8cfdf900   MpKslc3b98dff MpKslc3b98dff.sys Tue Mar 30 22:06:14 2010 (4BB2AE16)
adde8000 addfd000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
addfd000 ade1c000   mrxsmb   mrxsmb.sys   Tue Feb 22 08:23:58 2011 (4D63B8EE)
ade1c000 ade55000   mrxsmb10 mrxsmb10.sys Tue Feb 22 08:24:09 2011 (4D63B8F9)
ade55000 ade6d000   mrxsmb20 mrxsmb20.sys Tue Feb 22 08:24:02 2011 (4D63B8F2)
8cd8f000 8cd9a000   Msfs     Msfs.SYS     unavailable (00000000)
83293000 8329b000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8be9f000 8bece000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
86d90000 86dbb000   msrpc    msrpc.sys    unavailable (00000000)
8bfd3000 8bfdd000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
86f4c000 86f5b000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
86c85000 86d90000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
8bf31000 8bf3c000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
add28000 add32000   ndisuio  ndisuio.sys  Sat Jan 19 00:55:40 2008 (479190DC)
8bf3c000 8bf5f000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8c435000 8c446000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
8cf73000 8cf81000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
8cee3000 8cf15000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
86dbb000 86df6000   NETIO    NETIO.SYS    Mon Apr 05 11:15:04 2010 (4BB9FE78)
b404d000 b4058c00   NisDrvWFP NisDrvWFP.sys Tue Sep 14 17:24:12 2010 (4C8FE7FC)
8cd9a000 8cda8000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
8cfd0000 8cfda000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
82c1a000 82fc5000   nt       ntkrnlmp.exe Thu Oct 14 10:17:02 2010 (4CB710DE)
86df6000 86f06000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
8cd44000 8cd4b000   Null     Null.SYS     unavailable (00000000)
adcfe000 add28000   nwifi    nwifi.sys    Sat Apr 11 00:43:27 2009 (49E01FEF)
8bd97000 8bda6300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8cf5d000 8cf73000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
832cc000 832db000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
8329b000 832c2000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
83383000 8338a000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
83348000 83356000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
83356000 83383000   pcmcia   pcmcia.sys   Sat Apr 11 00:19:14 2009 (49E01A42)
adee4000 adfc2000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
8c747000 8c774000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
83073000 83084000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
831ad000 831ba300   qjbvcv   qjbvcv.sys   Wed Sep 02 17:37:57 2009 (4A9EE5B5)
8cda8000 8cdb1000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8bf1a000 8bf31000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8bf5f000 8bf6e000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8bf6e000 8bf82000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
8bf82000 8bf97000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
8cf94000 8cfd0000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
8cd7f000 8cd87000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
8cd87000 8cd8f000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
b4004000 b4037000   RDPWD    RDPWD.SYS    Sat Apr 11 00:51:22 2009 (49E021CA)
adcbe000 adcee000   RMCAST   RMCAST.sys   Sat Apr 11 00:45:24 2009 (49E02064)
add32000 add45000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
8c446000 8c746980   RTKVHDA  RTKVHDA.sys  Wed Jul 28 06:00:28 2010 (4C4FFFBC)
8bcf3000 8bd3f000   Rtlh86   Rtlh86.sys   Thu Nov 11 01:53:58 2010 (4CDB9306)
8be02000 8be1c000   sdbus    sdbus.sys    Sat Apr 11 00:19:14 2009 (49E01A42)
adfc2000 adfcc000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8cecf000 8cee3000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
86f44000 86f4c000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
adc0e000 adcbe000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
ade95000 adee4000   srv      srv.sys      Fri Feb 18 09:03:28 2011 (4D5E7C30)
ade6d000 ade95000   srv2     srv2.sys     Fri Feb 18 09:03:08 2011 (4D5E7C1C)
addb2000 addcf000   srvnet   srvnet.sys   Fri Feb 18 09:03:05 2011 (4D5E7C19)
8bece000 8bf0f000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8c799000 8c7a5f00   STREAM   STREAM.SYS   Sat Apr 11 00:42:47 2009 (49E01FC7)
8bfa7000 8bfa8380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
8be3e000 8be6f500   SynTP    SynTP.sys    Fri Mar 20 18:58:53 2009 (49C41FAD)
8cdb1000 8ce9e000   tcpip    tcpip.sys    Wed Jun 16 10:02:28 2010 (4C18D974)
adfcc000 adfd8000   tcpipreg tcpipreg.sys Wed Jun 16 10:01:59 2010 (4C18D957)
8be7d000 8be80f00   tdcmdpst tdcmdpst.sys Tue Oct 17 22:50:02 2006 (4535965A)
8bf0f000 8bf1a000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
adc00000 adc0b000   tdtcp    tdtcp.sys    Sat Jan 19 01:01:08 2008 (47919224)
8ceb9000 8cecf000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
8bf97000 8bfa7000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
8bdb5000 8be02000   tifm21   tifm21.sys   Fri Jun 19 17:44:10 2009 (4A3C06AA)
97af0000 97af9000   TSDDD    TSDDD.dll    unavailable (00000000)
8bff2000 8bffe000   tssecsrv tssecsrv.sys Sat Jan 19 01:01:15 2008 (4791922B)
86fe8000 86ff1000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
86fdd000 86fe8000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
86f3f000 86f43180   TVALZ_O  TVALZ_O.SYS  Thu Nov 08 22:07:46 2007 (4733CF02)
8bfdd000 8bfea000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
8be70000 8be71700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
8bd88000 8bd97000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8c400000 8c435000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
8bd4a000 8bd88000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8bd3f000 8bd4a000   usbuhci  usbuhci.sys  Sat Jan 19 00:53:20 2008 (47919050)
8cff7000 8cfff000   UVCFTR_S UVCFTR_S.SYS Thu Jun 26 04:25:19 2008 (4863526F)
8cd52000 8cd5e000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8cd5e000 8cd7f000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
832e8000 832f7000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
832f7000 83341000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
86f06000 86f3f000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
8cf81000 8cf94000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8bb61000 8bb6d000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
831bb000 83237000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
83237000 83244000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
978d0000 97ad4000   win32k   win32k.sys   unavailable (00000000)
8328a000 83293000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
Unloaded modules:
b4059000 b4140000   athr.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
8bc0c000 8bcf3000   athr.sys
    Checksum:  00000000
8bfea000 8bff2000   drmkaud.sys
    Checksum:  00000000
86fbd000 86fca000   crashdmp.sys
    Checksum:  00000000
86fca000 86fd5000   dump_ataport
    Checksum:  00000000
86fd5000 86fdd000   dump_atapi.s
    Checksum:  00000000
You have given me about 10 dump reports. The most consistent cause is the one given in the report shown above. The code given for the cause is A.
The reports that you have submittedreveal clues to the cause of your problem. They do not give a definitive answer. The more reports that we receivethe more clues are made available improving our chances of finding a solutionto your problem. Each remedy suggested must be performed regardless ofplacement in this report or other variables. You may have to experience severalmore BSODs until the final answer is discovered.
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Scan with your Anti Virus
How to Find Drivers
search Google for the name of the driver
- compare the Google results withwhat's installed on your system to figure out which device/program it belongsto
- visit the web site of themanufacturer of the hardware/program to get the latest drivers (DON'T useWindows Update or the Update driver function of Device Manager).
- if there are difficulties inlocating them, post back with questions and someone - will help you search Google for the name ofthe driver
- The most commondrivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer linksare on this page: http://www.carrona.org/drvrdown.html
and here
http://www.edbott.com/weblog/the-vista-master-driver-list/
You can also locate information aboutyour driver using this information
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
Run for 8 passes
Ifit passes try a good stick in each slot for 3 passes
Ifit fails do the same for 8 passes.
After performing all of the above,post back with any new BSOD reports, or indicate that the attempted repairswere successful.
If any links do not work, if clicked,please copy and paste to browser address bar.
It is very important to remember that the dump reports only giveclues as to the problem and although it is very easy to analyze only one ortwo, usually more are needed. If you experience additional BSOD afterinstalling a current version of the driver in question, be sure to post so thatwe can use the additional information to assist you in preventing the BSOD's
Since memory was specifically mentioned make memory test first.
Outdated drivers, ignore Microsoft Drivers
Code:
thank you again rich, i have pleanty of patients,
    toshiba satellite
Only Looks hard buddy, do one step at a time. Start with memory. Ill even give you the cheat sheet to make it easy.
Guide to using Memtest86+ - Geeks to Go Forums
If these steps fail, we will give you the driver verifier test. Many analysist give it first, but then we would miss other potential problems that can cause unacceptable performance other than BSODs in the future.
rich i cant download the test i get the bsod, when i try and download anything, so now what should i do,
    toshiba satellite
Make a full and updated virus scan
try any downloads in safe mode, see if that works.
Try the sfc scan that I mention above
We may have to go right to the driver verifier.
ok rich i think we need to go to the driver verifier, here is why i say that, i tried running a full scan with msse and right in the middl i got a bsod, i tried running the sfc and the screen will try to appear then it is gone. no luck on downloading in safemode either, seems like the bsods are becoming more freqnt to....
    toshiba satellite
Will do after one more thing. Can you get another computer. Download the memory test to a CD then insert CD in your computer?
man rich at this point there is no way i can get another computer.... only person i know around here is gone to a party
    toshiba satellite
