Solved bsod idk
Go to my second request for information. Do it slowly step by step.
idk every time i try to attch the minidump files that i moved to my desktop it tells me i dont have permission, and i keep geting kickd to the bsod, This my help tho, my neph was downloading a movie yesterday, and he said it requird additonl codecs, he allowed but then canceld, and my system restore is off for some reason??
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
You have to run as administrator. Read my first request carefully it will tell you how.
i have a window that says admin on it it is executing program 1 of 3 is this what i need ?
    toshiba satellite
I am feeling bad buddy. I want to help but I am not getting the information.
The information is suppose to be there when I open. When I open yours it begins to load and then its the wrong information.
Start over, do this one step at a time. Read each step.
Dump files - Upload to Seven Forums - Windows 7 Forums
Edit No that is what I am getting,
I do not know how you are getting that.
Doing better buddy. Right files, but could not open them.
Might be a problem with zip
Lets talk
Using the Windows 7 instructions.
One step at a time, tell me what you do. Put only one step in each post and wait for me to answer.
clik start, type windows mini dump it appears i clik then i see the files
    toshiba satellite
Ill get back to that, but Im going to try and see if I can open it with zip.
ty man, this is frustrating
    toshiba satellite
Can you go directly to the location? Click on the C drive, what do you see if you click on windows mini dump?
Dont get discouraged, if I cant get this to work, Ill get the author of the tutorial to help.
can you step me thru how to do that rich, i went c drive clicked but didnt see windows mini dump
    toshiba satellite
If you can click on c
you will see windows click on that
then you should see mini dump. Try to follow the tutorial from that point.
I did not look yet, Keeping you in suspense.
lol ty
    toshiba satellite
It starts off correctly, but then it says cannot file path specified.
Tell me what your setting say
Go to advanced setting like I told you before it should say
Small memory dump
path:%SystemRoot/mindidump
Is this what you have it set on?
