icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp12_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini010511-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x86 compatible
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0x82248000 PsLoadedModuleList = 0x8235fc70
Debug session time: Wed Jan 5 11:16:47.051 2011 (GMT-5)
System Uptime: 0 days 11:22:05.982
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 9F, {3, 84989030, 876be030, 896a2c40}
*** WARNING: Unable to verify timestamp for nvmfdx32.sys
*** ERROR: Module load completed but symbols could not be loaded for nvmfdx32.sys
Probably caused by : nvmfdx32.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 00000003, A device object has been blocking an Irp for too long a time
Arg2: 84989030, Physical Device Object of the stack
Arg3: 876be030, Functional Device Object of the stack
Arg4: 896a2c40, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IRP_ADDRESS: 896a2c40
DEVICE_OBJECT: 876be030
DRIVER_OBJECT: 877d6150
IMAGE_NAME: nvmfdx32.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 489357fd
MODULE_NAME: nvmfdx32
FAULTING_MODULE: 8f094000 nvmfdx32
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 822793fb to 82315b8d
STACK_TEXT:
8233dacc 822793fb 0000009f 00000003 84989030 nt!KeBugCheckEx+0x1e
8233db28 82279018 8233dba0 82356500 82356400 nt!PopCheckIrpWatchdog+0x1ad
8233db68 822f230b 823564e0 00000000 f3620d32 nt!PopCheckForIdleness+0x343
8233dc88 822f1ecb 8233dcd0 87699602 8233dcd8 nt!KiTimerListExpire+0x367
8233dce8 822f2635 00000000 00000000 002807d2 nt!KiTimerExpiration+0x22a
8233dd50 822f089d 00000000 0000000e 00000000 nt!KiRetireDpcList+0xba
8233dd54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x49
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0x9F_IMAGE_nvmfdx32.sys
0: kd> !analyze -v
Arguments:
Debugging Details:
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
0: kd> lmtsmn
start end module name
8ebd9000 8ebe6080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
80607000 8064d000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
a525d000 a526de80 adfs adfs.SYS Thu Aug 14 10:57:15 2008 (48A447CB)
8ff64000 8ffac000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
8074e000 80756000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
80756000 80774000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
9c890000 9c8dd000 ATMFD ATMFD.DLL unavailable (00000000)
90302000 90309000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
91a98000 91b44000 BHDrvx86 BHDrvx86.sys Mon Nov 15 17:35:02 2010 (4CE1B596)
8041f000 80427000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
a436b000 a4384000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
91a19000 91a98000 ccHPx86 ccHPx86.sys Fri Feb 05 15:57:22 2010 (4B6C8632)
9c880000 9c88e000 cdd cdd.dll unavailable (00000000)
ae3c0000 ae3d6000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
8f194000 8f1ac000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
80468000 80548000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
8072d000 8074e000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80427000 80468000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
91b44000 91b51000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a59d000 8a5a6000 crcdisk crcdisk.sys Sat Jan 19 00:50:29 2008 (47918FA5)
91a02000 91a19000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
8a58c000 8a59d000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
8ff3f000 8ff64000 Dot4 Dot4.sys Sat Jan 19 00:49:12 2008 (47918F58)
903ea000 903f3000 Dot4Prt Dot4Prt.sys Sat Jan 19 00:49:09 2008 (47918F55)
903c9000 903d6000 dot4usb dot4usb.sys Sat Jan 19 00:49:09 2008 (47918F55)
902cd000 902f2000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
91b51000 91b5b000 dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
91b5b000 91b7f000 dump_nvstor32 dump_nvstor32.sys Fri Dec 07 18:27:08 2007 (4759D6CC)
91b7f000 91b89000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
8fd5b000 8fdfc000 dxgkrnl dxgkrnl.sys Thu Sep 24 21:27:14 2009 (4ABC1C72)
8a565000 8a58c000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
90782000 907e0000 eeCtrl eeCtrl.sys Fri May 21 17:44:53 2010 (4BF6FED5)
907e0000 907fd000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:53 2010 (4BF6FED5)
82863000 82873000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
805c7000 805f9000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
902f2000 902fb000 Fs_Rec Fs_Rec.SYS unavailable (00000000)
9038e000 903a9000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8f1ac000 8f1b1280 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
82215000 82248000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8f007000 8f094000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
90648000 90658000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
90658000 9065e380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
9063f000 90648000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
8eb07000 8ebbc000 HSX_CNXT HSX_CNXT.sys Thu May 08 16:04:13 2008 (48235CBD)
8ea05000 8eb07000 HSX_DP HSX_DP.sys Thu May 08 16:03:14 2008 (48235C82)
8291b000 82967000 HSXHWBS2 HSXHWBS2.sys Thu May 08 16:05:16 2008 (48235CFC)
a42e1000 a434e000 HTTP HTTP.sys Sat Feb 20 15:53:31 2010 (4B804BCB)
82b85000 82b98000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
90702000 9075d000 IDSvix86 IDSvix86.sys Fri Nov 05 17:11:46 2010 (4CD47312)
90620000 9063f000 Ironx86 Ironx86.SYS Tue Apr 27 20:47:15 2010 (4BD78593)
82b98000 82ba3000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
87760000 87767000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
82967000 82991000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
828aa000 8291b000 ksecdd ksecdd.sys Mon Jun 15 08:48:53 2009 (4A364335)
a42be000 a42ce000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
91b98000 91bb3000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
a526e000 a5271180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
906cf000 90701c40 mfehidk mfehidk.sys Fri Jul 31 17:59:40 2009 (4A73694C)
8ebbc000 8ebc9000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
91b89000 91b98000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
82800000 8280b000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
90663000 9066b000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
80702000 80712000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
a4384000 a4399000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
a4399000 a43ba000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
a43ba000 a43d9000 mrxsmb mrxsmb.sys Tue Feb 23 06:10:12 2010 (4B83B794)
91bb3000 91bec000 mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
a43d9000 a43f1000 mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
90346000 90351000 Msfs Msfs.SYS unavailable (00000000)
80656000 8065e000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8f1be000 8f1ed000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
82b10000 82b3b000 msrpc msrpc.sys unavailable (00000000)
807e9000 807f3000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a556000 8a565000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
ae3ac000 ae3bf580 NAVENG NAVENG.SYS Mon Dec 13 20:42:27 2010 (4D06CB83)
ae261000 ae3ab900 NAVEX15 NAVEX15.SYS Mon Dec 13 20:51:18 2010 (4D06CD96)
82a05000 82b10000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
82991000 8299c000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8299c000 829bf000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8fe44000 8fe55000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
8fe00000 8fe0e000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
8ffac000 8ffde000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
82b3b000 82b76000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
9036a000 90378000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
906c5000 906cf000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
82248000 82601000 nt ntkrpamp.exe Tue Jun 08 10:36:44 2010 (4C0E557C)
8a405000 8a515000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
9065f000 90662c80 NuidFltr NuidFltr.sys Tue Jun 29 04:54:25 2010 (4C29B4C1)
902fb000 90302000 Null Null.SYS unavailable (00000000)
8fd59000 8fd5a080 nvBridge nvBridge.kmd Fri Jun 26 17:38:18 2009 (4A453FCA)
8f405000 8fd580e0 nvlddmkm nvlddmkm.sys Fri Jun 26 18:15:23 2009 (4A45487B)
8f094000 8f193600 nvmfdx32 nvmfdx32.sys Fri Aug 01 14:37:49 2008 (489357FD)
80712000 8072d000 nvraid nvraid.sys Wed Jun 06 16:34:41 2007 (46671A61)
80774000 80798000 nvstor32 nvstor32.sys Fri Dec 07 18:27:08 2007 (4759D6CC)
8ebc9000 8ebd8300 ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
8ffde000 8fff4000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
80685000 80694000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8065e000 80685000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
806ed000 806f4000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
806f4000 80702000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
a5272000 a5350000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
902a0000 902cd000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
82b76000 82b85000 processr processr.sys Sat Jan 19 00:27:20 2008 (47918A38)
8a5f5000 8a5f9a80 PS2 PS2.sys Mon Dec 12 20:26:59 2005 (439E2363)
8040e000 8041f000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
828a0000 828a9200 PxHelp20 PxHelp20.sys Wed Mar 12 21:57:44 2008 (47D88A18)
90378000 90381000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
8ebe7000 8ebfe000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
829bf000 829ce000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
829ce000 829e2000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
829e2000 829f7000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
90689000 906c5000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
90336000 9033e000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
9033e000 90346000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
a42ce000 a42e1000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
90003000 9029f7c0 RTKVHDA RTKVHDA.sys Tue Aug 04 05:48:13 2009 (4A7803DD)
9066b000 9067f000 RTSTOR RTSTOR.SYS Tue Apr 07 23:53:11 2009 (49DC1FA7)
a5350000 a535a000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
903d6000 903ea000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
8a54e000 8a556000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
a420e000 a42be000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
ae20a000 ae261000 SRTSP SRTSP.SYS Wed Feb 24 18:54:51 2010 (4B85BC4B)
9067f000 90688080 SRTSPX SRTSPX.SYS Wed Feb 24 18:55:07 2010 (4B85BC5B)
a520f000 a525d000 srv srv.sys Mon Sep 06 09:45:36 2010 (4C84F080)
8a5a6000 8a5ce000 srv2 srv2.sys Mon Sep 06 09:45:21 2010 (4C84F071)
a434e000 a436b000 srvnet srvnet.sys Mon Sep 06 09:45:18 2010 (4C84F06E)
80798000 807d9000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8fdfc000 8fdfd380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8280d000 82863000 SYMDS SYMDS.SYS Mon Aug 17 19:34:39 2009 (4A89E90F)
82873000 828a0000 SYMEFA SYMEFA.SYS Wed Apr 21 17:46:52 2010 (4BCF724C)
9075d000 90782000 SYMEVENT SYMEVENT.SYS Thu Aug 13 18:22:41 2009 (4A849231)
a536e000 a53c7000 SYMTDIV SYMTDIV.SYS Tue May 04 00:29:10 2010 (4BDFA296)
8fe55000 8ff3f000 tcpip tcpip.sys Wed Jun 16 09:45:41 2010 (4C18D585)
a535a000 a5366000 tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
8f1ed000 8f1f8000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
903b3000 903c9000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
807d9000 807e9000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
9c860000 9c869000 TSDDD TSDDD.dll unavailable (00000000)
8a5ec000 8a5f5000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
8a5e1000 8a5ec000 tunnel tunnel.sys Thu Feb 18 06:28:13 2010 (4B7D244D)
807f3000 80800000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
90351000 90368000 usbccgp usbccgp.sys Sat Jan 19 00:53:29 2008 (47919059)
90368000 90369700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
82beb000 82bfa000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8fe0f000 8fe44000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
82ba3000 82bad000 usbohci usbohci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
82bad000 82beb000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
903a9000 903b3000 usbprint usbprint.sys Sat Jan 19 01:14:40 2008 (47919550)
90381000 9038e000 usbscan usbscan.sys Sat Jan 19 01:14:09 2008 (47919531)
90309000 90315000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
90315000 90336000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
80694000 806a3000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
806a3000 806ed000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
8a515000 8a54e000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
9060d000 90620000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
8f1b2000 8f1be000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80548000 805b9000 Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
805b9000 805c7000 WDFLDR WDFLDR.SYS Mon Jul 13 19:11:25 2009 (4A5BBF1D)
9c640000 9c843000 win32k win32k.sys unavailable (00000000)
8064d000 80656000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
903f3000 903fc000 ws2ifsl ws2ifsl.sys Sat Jan 19 00:56:49 2008 (47919121)
a5366000 a536e000 xaudio xaudio.sys Thu Oct 18 18:36:53 2007 (4717E005)
