BSOD Caused by system files?
i did it..and attached my log file...
Hello
If you can get to your desktop run a full sfc scan and then send that report it will help.
1. Click Start...
2. In the search box type: cmd
3. When the popup list comes up go to the top and RIGHT click on cmd.exe and run it as administrator.
4. When the command box appears then type: sfc /scannow notice there is a space between the sfc and the forward slash. After the sfc scan is done send me that report, if the scan comes back with any errors then run it 3 more times as it fix's more each time it is run. If it will not run all of then the first report will be the best, here is a great tutorial on how to do this it is very easy, while running the scan don't use your computer and don't click any buttons or use the mouse just let it run by it's self.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    Intel Core 2 Duo CPU T6400 @ 2.00 Ghz
    54 Mb/sn
Be sure to do it for at least 8 passes. Then check the slots with a know good stick. If passes, memory is not the problem.
Hello the sfc looks good, do you have the windows sidebar turned off, if yes thats ok so do I everything else is fine in the sfc.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
i have not gotten any bsods in 2 days.but i'm using only 2gb ram now.the other 2 gb is removed.
    54 Mb/sn
Test using Memtest as suggested.
