BSOD Caused by system files?
Hello when you say that you got rid of vista and reinstalled it, did you do a factory restore, did you have it reformat the hard drive. The steps are very important to us as to how you did it. If it was wrong then there will still be a problem. So Please tell us what you did and how you did it.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
Please run the hardware diagnostics I mentioned in this post. Restoring to factory defaults or doing a clean install should immediately rule out all software problems, so we are left with hardware to deal with.
If you need any help running those tests, feel free to post.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Hello I agree with Jonathan King please follow his instructions about running the hardware diagnostic's.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
i captured a jpeg..maybe it can be useful too...
i think the virus program(AVG) which i use may cause the driver problem maybe...so i removed it and installed Avira instead of it.
    Intel Core 2 Duo CPU T6400 @ 2.00 Ghz
    54 Mb/sn
Thank's I'm sure the BSOD expert will check it out.
How are you getting on with the hardware diagnostics suggested in the earlier post?
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Yes..i formatted all my harddrives and installed a new vista to my pc...i did it with my toshiba rescue disks...it formatted my harddrive and installed it with factory settings...so i had a clean and a brandnew vista...i didnt get any bsods...but when i was workin in my new vista..it started to give me a new bsods.
after i installed vista i only setuped these softwares:
mic. office prof 2010...bsplayer...and bittorent...
    54 Mb/sn
i'm updating my drivers from the site of intel as you write in the post...i made an automatic detect.so it found lots of drivers...
but i have a problem with the audio driver.it doesnt have a setup file because it says:Audio Driver for Intel Desktop Board
Product Detected Realtek High Definition Audio Current Driver Installed 6.0.1.5599 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
what can i do?
    54 Mb/sn
and when i tried to setup Intel® Graphics Media Accelerator Driver for Windows 7*, Windows Vista* (exe)
it gave a warning...it said like that...:this driver is unverified with this pc...please contact with your pc manufacturer.
this is my second driver question.
i updated other drivers..wifi,chipsets etc..
    54 Mb/sn
hi again
after one day without any bsods....today i got some of them..and now the situation is this:
i cant open vista...when i try to open with safe mode...it gives bsods which i cant see what are those codes...
i try to open with my rescue disk,but it says firstfully: "windows is loadind files"
then give me an error...
file : windows\system32\boot\winload.exe
status : 0x0000001
the selected entry couldnt be loaded because the application is missing or corrupt.
what can i do now?i cant open anything now! show me a way please...
i installed my vista a couple of days ago...and installed my all drivers updated.yesterday i didnt take any bsods but today i cant open it...i'm really bored of this
    54 Mb/sn
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
today i opened my laptops backside and changed the places of rams...then vista opened...but when i look to my bluescreenviewer it shows me those errors...
alfaFF.sys
fltmgr.sys
ntkrnlpa.exe
    54 Mb/sn
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello because of the ntkrnlpa I would recommend doing a repair installation. This will allow you to repair your vista installation without losing your files, settings, and programs. Please read the following tutorial as it will walk you through the process..
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
This will help you repair your system, if you have any questions please post back and either myself or someone within the forum will gladly help you.
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
thanx for the reply...i think if i repair my system files,it will be nice...but i have only rescue disk..and my D: has HDD recovery folder...but there is no setup file in it.
americancritic
    54 Mb/sn
i made a system check with the program named "COMBOFIX"...it gave me a result and i attached its log file...
maybe it can be helpful for us??
    54 Mb/sn
my problems are not fixed still...
i formatted my pc...but i took bsods still...
irql not less or equal
bad pool header
memory management
i took bsod while i was formatting too..
i think my rams are bad...so i removed one of my two 2gb ddr2 rams
then i could open my pc...
    54 Mb/sn
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello
If you can get to your desktop run a full sfc scan and then send that report it will help.
1. Click Start...
2. In the search box type: cmd
3. When the popup list comes up go to the top and RIGHT click on cmd.exe and run it as administrator.
4. When the command box appears then type: sfc /scannow notice there is a space between the sfc and the forward slash. After the sfc scan is done send me that report, if the scan comes back with any errors then run it 3 more times as it fix's more each time it is run. If it will not run all of then the first report will be the best, here is a great tutorial on how to do this it is very easy, while running the scan don't use your computer and don't click any buttons or use the mouse just let it run by it's self.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
