You should upgrade or use an
alternative browser.
bsod 0x0000009f problem with shutdown restart sleep and hibernate
i set it how it showed but i didnt see anything about drivers in it. how do i know if i updated the drivers
- hewlett packard
- amd turion tm 64 x2 mobile technology tl-60 2.00ghz
- Quanta 30CF 85.26
- 3.00 GB
- nvidia GeForce 7150M / nForce 630M
- Conexant High Definition SmartAudio 221
- Generic PnP Monitor (15.4"vis, January 2007)
3. You can now set your Windows Update settings. (see screenshots below)
NOTE: See steps 4 to 8 below for each setting, then step 9 when finished.
Check the box that says Microsoft Updates, it will take a while.
- Dell XPS420
- 6 gig
- ATI Radeon HD3650 256 MB
- Intergrated 7.1 Channel Audio
- Dell SP2009W 20 inch Flat Panel w Webcam
- 640 gb
- Cooling
- Fan
- Dell USB 4 button optical
- Dell USB
- Other Info
- DSL provided by ATT
started update a little while ago hope it works without being able to restart
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
If you cant start at all, we may have to save your stuff then reinstall.
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
no its shutting down,restart,sleep,and hibernate from windows goes to the bsod.
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
now a message popped up what the hell did i do.
Problem signature:
Problem Event Name: APPCRASH
Application Name: NisSrv.exe
Application Version: 3.0.8402.0
Application Timestamp: 4db89a7b
Fault Module Name: IpsConsumer.dll
Fault Module Version: 3.0.8402.0
Fault Module Timestamp: 4db89a85
Exception Code: c0000005
Exception Offset: 000119fc
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 3097
Additional Information 2: c54571ea709dc4600180433fe80d9a77
Additional Information 3: 82c1
Additional Information 4: 81b1eabc85dd31655c724bc440930a51
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
i hit the check for solution button but nothing
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
Do you have a Vista install DVD?
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
nothing came with the computer and i shouldn't have said nothing the box disappeared but nothing else came up afterwords.
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
so no install disc the only thing that came in the box was the plug and the computer.
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
the updates are installing but 1 failed and 10 were canceled so one of those are probably the one i need.ill tell you how it turns out
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
bsod popped up. but its now configuring the updates
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
ok almost all the updates are done only 9 important and 3 optional what now.
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
Exactly what happens when you try to boot, now.
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
bsod still and now its just 1 update
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
Try again, if not tried already in safe mode
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
Forget the update for now, lets try to boot.
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
when it was finishing the update it restarted no problem the second time i got the bsod again
- hewlett packard
- Quanta 30CF 85.26
- 3.00 GB
Every BSOD, send me the report.
- Dell XPS420
- 6 gig
- 640 gb
- Cooling
- Fan
- Dell USB
- Other Info
