acer 5315 ongoing
I haven't downloaded any dvd. I have a proper vista disc with the reg no on the back of the acer. The only thing I have downloaded is the sata driver to a usb flash......
As I have lost count of the number of times I have tried to re install vista I tried a couple of new ideas - changed the bios sata to read ide - that did not work.
I also added a new partition and tried to get vista to install to that. The partition appeared correctly as Disc O - it then found the sata drive thought about it for ages -
then told me it could not install the drive and to go to the manufacturer site for an updated one - which is where I obtained the drive in the first place...
Click "C"
Click okay
and nothing happens
Maybe I am being a little harsh but do you do left click on C and then button "NEXT"....
Or maybe and just maybe you need to actually boot from Vista DVD to do clean install.
But for this purpose boot normally into vista, than put your installation DVD in CD/DVD-rom drive and tell us what do you get?
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
All my fun and games was from the vista dvd - trying to do a clean install...
Going throught the installation - time & currency etc
then
Where do you want to install windows
Empty box
click load driver
click browse
click on Acer C
click okay
but now we have an intel driver highlighted ICH8M E/M SATA AHCI
click next
screen goes back to empty box
but if I try enough times with rescan/browse/load driver mixed in
I get the outdated driver message
Can I go out and buy a laptop ide hd...........
I said at the very beginning that it was a used acer with loads of junk files and that it runs very slowly. I shouldn't have this problem installing vista on a laptop - should I....I installed vista on a desktop with no troubles but expect that was with a ide hdd.
Hi smokeyone
As you can get to the desktop go to Acer eRecovery, start the program.
1) make your eRecovery DVD's.
2) Then in the program you will find eRecovery reinstall.
Acer Assist
messages
Acer Assist
EPI LICENSE
EXPAT LICENSE
Launcher
PCRE LICENSE
uninstall
Default Programmes is really windows
Control Panel Programmes Default Programmes
Set your default programmes
Associate a file type or protocol with a programme
Change auto play settings
Set programme access and computer details
Smokeyone-
I've installed vista to a desktop SATA drive many times, (and on dated hardware to boot!).
I can assume you are currently running windows xp? Or are you trying to replace vista with vista?
Vista will not allow you to play with hard drives unless it has booted from the DVD.
    Pentium 4 @ 3.0GHz
    Intel D915PCY
    Transcend Axe-RAM 2gb
    ATi Radeon HD 4670 Superclocked
    Sound Blaster Audigy SE
    Gateway HD 1900
    Western Digital 120gb BEVS series 2.5" Mobile Drive
    Xtreme Gamer 500W
    NZXT Hush
    Stock Intel
    Logitech S510 Combo
    Logitech S510 Combo
Even windows cannot find e recoverery so I am assuming it's been deleted sometime in the past. E recovery is listed under empowering technology but the actual file has gone.
For the other forum member that tried to assist - it's a vista acer laptop and all I wish to do is a fresh clean instal - I have a vista disk and have found the sata drivers
but just waist time going around in circles as vista refuses to load them and still says no drive or that the drivers are outdated...........
