SP2 Disk Cleanup Tool
How to Use the Vista SP2 Disk Cleanup Tool
This will show you how to run the Vista SP2 Cleanup tool to permanently remove the Vista RTM and SP1 backed up files created during the installion of the Vista SP2 to gain more hard drive space.
Running the Windows Vista Service Pack 2 Disk Clean-up tool permanently removes the ability to uninstall the Vista SP1 and SP2. Do not run this tool unless you have no plans of uninstalling the Vista SP1 or SP2 and just want to save or regain hard drive space. The only option to remove them after using this tool is to do a clean install of Vista.
To see how much space you recover, make a note of how much free space you have on the C:/ drive in Computer before and after you run the SP2 Cleanup Tool.
It appears that most people are gaining on average 1GB of space back afterwards. :)
2. In the elevated command prompt, type compcln.exe and then press Enter. (See screenshot below)​
3. Type Y when you see Would you like to continue? and press Enter.​
NOTE: Tying N will cancel running the Vista SP2 disk cleanup tool. You can also just close the command prompt window to cancel to.​
4. It will take a little bit to finish. When it is finished, you will see the Windows Component Clean completed message. (See screenshot above)​
NOTE: You will see the Windows Component Clean was already run on this install message instead if you already ran this or installes Vista with a Vista installation disc that included SP2 with it.​
5. When it's done, you can close the elevated command prompt.​
6. Now, you just need to let all of us know how much space the tool cleared and saved for you. ;)
NOTE: I would happily tell you mine, but I have a Vista installation DVD that already includes the SP1 and SP2, so I have not backup files to clean up.​
You're welcome Phillip. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I saved 517MB
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Thanks for the tutorial. :) I was able to recover 1 GB.
    ACER Aspire 4520G
    AMD Athlon 64x2 Dual Core TK-55 1.8GHz, 2 x 256 KB L2 cache
    2 GB DDR2
    128 MB NVidia GeForce 8400M G
    15 MBPS
You're welcome Piaborgs, and welcome to Vista Forums. :)
Thanks for the warm welcome. I have actually been lurking in the forums trying to learn as much as I can from your posts. They are highly, highly informative. :)
    ACER Aspire 4520G
    2 GB DDR2
    15 MBPS
I ran the tool because of 136 GB on the c drive; with no docs stored on the machine, with all extra software except security, adobe, and majicjack, i had 1.16 GB free space! After cleaning, I have 1.68 GB freespace.
Still trying to figure out what eats up 132+GB of space on the OS C:\ drive with Vista installed.
Thanks for the cleanup. It worked well and did do its job.
Great tut as usual Shawn, I cleaned out over 300 mb.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
Hello Derek,
Not bad. :)
You're welcome Jeff. Nice amount. :)
Hey all. I saved 1.47 GB.
To properly see how much space you recover don't rely solely in the information in Windows Explorer, if you View the "My Computer" in icon view.
Instead, right click the drive (most likely your C://) and select properties. then go back to the properties once again affer running the cleanup described in the tutorial and note the new numbers.
from "My Computer" it appeared I too had not recovered anything at first glance.
On a side note:
If you leave the window open during the clean, you may want to refresh the data shown manually to ensure the accuracy of the auto update mourns.
To Do This screen Refresh: simply press <CTRL> R when that window is active on your desktop or if you have the menus available it can be found in he menu "View". Refresh is at the bottom.
(menu referred to is on the /File /Edit/View/Tools/Help/ menu bar)
Did this out of curiosity and reclaimed 1.5 GB disk space. Nice little tidbit.
    Toshiba Satellite A135
    Intel Pentium T2080 @1.73GHz
    Toshiba IAKAA v.1
    Crucial Tech PC2-4300 (2GB)
Hey,
You helped me free up 3GB of space on my drive.
Thanks, Would have never known
Karen
    Dell Inc. Studio Hybrid 140g
    Intel(R) Core (TM)2 Duo
    Intel(R) ICH8 Family SMBus Controller - 283E
    32 Bit; 1920 X 1080; at 60 Hertz
You're most welcome Karen, and welcome to Vista Forums. :)
