SP2 Disk Cleanup Tool
How to Use the Vista SP2 Disk Cleanup Tool
This will show you how to run the Vista SP2 Cleanup tool to permanently remove the Vista RTM and SP1 backed up files created during the installion of the Vista SP2 to gain more hard drive space.
Running the Windows Vista Service Pack 2 Disk Clean-up tool permanently removes the ability to uninstall the Vista SP1 and SP2. Do not run this tool unless you have no plans of uninstalling the Vista SP1 or SP2 and just want to save or regain hard drive space. The only option to remove them after using this tool is to do a clean install of Vista.
To see how much space you recover, make a note of how much free space you have on the C:/ drive in Computer before and after you run the SP2 Cleanup Tool.
It appears that most people are gaining on average 1GB of space back afterwards. :)
2. In the elevated command prompt, type compcln.exe and then press Enter. (See screenshot below)​
3. Type Y when you see Would you like to continue? and press Enter.​
NOTE: Tying N will cancel running the Vista SP2 disk cleanup tool. You can also just close the command prompt window to cancel to.​
4. It will take a little bit to finish. When it is finished, you will see the Windows Component Clean completed message. (See screenshot above)​
NOTE: You will see the Windows Component Clean was already run on this install message instead if you already ran this or installes Vista with a Vista installation disc that included SP2 with it.​
5. When it's done, you can close the elevated command prompt.​
6. Now, you just need to let all of us know how much space the tool cleared and saved for you. ;)
NOTE: I would happily tell you mine, but I have a Vista installation DVD that already includes the SP1 and SP2, so I have not backup files to clean up.​
I'm just getting the message...'compcln.exe' is not recognized as an internal or external command, operable program or batch file.
Oh - and Newbie means just that...............
Hello Hanntom, and welcome to Vista Forums.
Do you have the Vista SP2 installed, and ran the command in a elevated command prompt (link at step 1)?
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I lost 1GB after this - does that make any sense?
When I entered Y it began to work and I did not have to press enter. I never got the message that it was completed though, the command prompt window just closed. I tried to run it again to make sure it completed but as soon as I typed in Y the command prompt box closes, no time to hit enter.
    Sony VGC-JS130J
    Intel E5200
    Intel G45
    Integrated
    Integrated
    1680 x 1050
    WD 500 GB
Hello Moon unit,
That sounds about right. I would not worry about it. :)
Another usefull guide thanks Brink
I need those extra GB's. Using a 120 GB SSD wich fast can go out of space :D
104GB Before
105GB After
This was with a clean install. I only have SP1 "build" in disc so I install SP2 after and clean it up. But also I must still use RTM becouse SP2 final is not available in my language. Dosn't matter, this works fine and I have used it for long time now. But I need a clean install today :p
    Toshiba X300-13o
    Intel Core2Duo T9600 at 2.8GHz 6 MB - L2 Cache FSB: 1066Mhz
    Intel® GM45 Express chipset
    4,096 (2,048 + 2,048) MB
    NVIDIA® GeForce® 9800M GTX 1GB
    Toshiba TruBrite® WXGA+
    1,440 x 900
    OCZ Vetex 120GB SSD Read/Write - 200/160 MB 64MB Cache
    Logitech VX Nano
    24-Biters stereo, Harman Kardon®
    Toshiba Bass Enhanced Sound System With Dolby® Home Theater™. Includes Suboofer
    Yes, This is a laptop :)
OK Shawn,
I'm going to do the clean-up.
attached I have pics of my current allocation.
I also made an image using acronis.
btw, since I updated to SP2, my system restore does not auto create upon boot up or at 00:00
~Carmine
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hello Carmine,
Have you made any system changes or installed any programs or drivers since installing SP2? It will not auto create a restore point unless it detects a change in the system at that scheduled time.
Hello,
here is the difference.
capture2=original
capture5=after clean up
was the difference 720MB?
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Hello Carmine,
Hi Shawn,
No changes at all.
I thought a restore point was made everyday.
( it used to because I increased the allocation size for RP's to 50GB ) then I just deleted them all.
it's kewl, thanks for the help.
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Most people have been seeing around a 1GB gain, so that is about right.
i saved 1 gb well better then nothing right? Thanks
    HP Pavilion Laptop/DV2845SE
    ACPI x64-based PC
    Conexant High Definition SmartAudio 221
    NVIDIA MCP67M
    FUJITSU 250GB Hard Drive
Didn't get a "space saved" report. Here's what I did get.
Great postings here though. Very useful !!! Thank you.
    Acer X1700
    Intel Pentium Dual CPU E2220 @ 240Ghz, 2403Mhz, 2 Cores,
    4GBs DDR2
    NVIDIA GeForce G100
    LG Flatron W2061TQ
    600GB
Hello Schmitman,
You would have had to manually look to see how much free space you had on your C: drive before and after running this to see how much space you have gained instead. It looks like it has ran successfully though. On average, most people have been getting back around 1 GB though. :)
Hello Gorn, and welcome to Vista Forums.
Wow, now that is a record. Did you not run the SP1 Disk Cleanup Tool before? If not, then that may be why you had more free space after running the SP2 cleanup tool.
Thank you for posting back Gorn to confirm that. Still not a bad amount though. :)
Have just got 2 gig back following this guide after installing SP2 on Vista x64 Ultimate, so pretty pleased with that and once again it's all down to Shawn - cheers!
    Q6600@stock
    Asus P5N32-E SLI
    4GB Geil DDR2 PC6400 CAS4
    1 x BFG 8800 GTS 512mb OC
    2 x 80Gb Samsung SATAll in RAID 0
    2 x 80Gb Maxtor SATA1 in RAID 1
    1 x 120Gb Maxtor SATA1 back-up
    Bt Broadband, so about same as 56k modem!
I checked before doing it, and i have 49,6 GB free on C:, and now I still have the same after it, everything ran just fine and correctly, but I didnt gain even an 0,1 GB, and I haven't ran this in SP1 cause I didn't even know that this exists. Anyway, I upgraded to SP2 just today lol
    Toshiba Satellite A300-15I
    Intel Pentium Dual Core T2370 1.73 GHz (3.46GHz)
    I don't know
    Standard(I now) : 2,048 MB ; maximum expandability : 4,096 MB ; technology : DDR2 RAM (667 MHz)
    manufacturer:ATI ; type : ATI Mobility Radeon™ HD 3470
    I don't know
    15.4" Toshiba TruBrite® WXGA TFT High Brightness display and LG LCD TV
    1280x800, and I don't know for TV
    capacity : 200 GB
    certification : S.M.A.R.T.
    drive rotation : 5,400 rpm
    I don't know
    Keys : 87 Windows® keys : 2
    Logitech V220 Cordless Optical Mouse For Notebooks
    100 Mbps
    Physical dimensions:
    W x L x H : 363 x 267 x 34.5 (front) / 38.5 (rear) mm
    weight : starting at 2.7 kg
    Security features :
    Wireless LAN switch
    main hard disk (by screw)
    main memory (by screw)
    HDD password on request
    supervisor password
    slot for Kensington Cable Lock
    main battery pack (by sliding latch)
    user password
    Special features:
    integrated 1.3 Megapixels Web Camera for Video
