How to Use "Find and Find Next" in Registry Editor in Vista, Windows 7, and Windows 8
This tutorial will show you how to use "Find and Find Next" to find a text string in a key, value, or data inside the Registry Editor in Vista, Windows 7, and Windows 8.This can be real handy if a program improperly uninstalled and you need to remove all entries for it in the registry manually to finish removing it. It it recommended that you should create a restore point to backup the entire registry incase you make a mistake while editing the registry and need or have to do a system restore to undo it.
1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
2. If prompted by UAC, then click on Continue...
