How to Turn Compressed Folders On or Off in Vista
By default, Vista handles ZIP files like folders. This will show you how to turn on or off the ability for Windows Explorer to treat Compressed Folders like a normal folder and open and view it the same way (on), or like a file (off). For example, ZIP files show up under the folder tree (like folders) in Windows Explorer. Vista will look inside of the ZIP files when doing searches, causing it to take longer to finish the search sometimes. If you have another 3rd party ZIP program (WinZip, 7-Zip, etc.), then this can be an annoyance to you and you may want to turn this feature off.Compressed Folders is turned on by default on Vista.If you are not using a 3rd party ZIP program, that may...
