System Files - SFC Command
How to Repair and Verify the Integrity of Vista System Files with System File Checker
System File Checker (SFC) checks that all Vista system files are where they should be as they were by default and not corrupted, changed, or damaged. This will show you how to verify and repair the integrity of Vista system files with the System File Checker (SFC) command codes.
If SFC Cannot Finish or Repair a File:
NOTE:
This is for when after you run the SFC scan below, it cannot finish or repair a file. There is no guarantee that SFC can repair the system files if they are corrupted or damaged to much. If SFC still cannot repair them after this, then you might try running Check Disk (chkdsk), System Restore, a Repair Installation, or a clean reinstall of Vista.
1. How to Read the CBS.LOG
NOTE:
When SFC runs, it logs it's actions to the C:\WINDOWS\LOGS\CBS\CBS.LOG. You can find the specific SFC entries by searching for the [SR] tags in the log.
A) For how to see only the SFC scan details in the CBS.LOG:​
  • Open a elevated command prompt.
  • Copy and paste the command below into the elevated command prompt and press Enter.
    Code:
    findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt
  • Close the elevated command prompt.
  • Click on the sfcdetails.txt file that was just placed on your desktop to see the SFC scan details (ones with the [SR] tags) in the CBS.LOG.
  • You can safely delete the sfcdetails.txt file afterwards if you like.
2. Replace the Files that SFC Cannot Fix
NOTE:
If SFC cannot fix a file, it will be listed in the CBS.LOG above. Read the CBS.LOG to find out what file it is so you can replace it with a good copy.
A) For how, see:​
Be aware that if you have modified your system files as in theming explorer/system files, running sfc/scannow will revert the system files such as explorer.exe back to it's default state. Make the appropriate backups of your system files that you have modified for theming if you wish to save them before running sfc/scannow.
NOTE:
If sfc cannot start or finish, then try running it Safe Mode.
2. In the elevated command prompt, type the command that you want to do in bold below in steps A to E to run System File Check.​
A) sfc /scannow - Scans the integrity of all protected system files and repairs the system files if needed. (See screenshot below)​
NOTE: Restores Vista's original setup of system files. (EX: Fonts, wallpapers, System32 files, etc.)
B) sfc /verifyonly - Scans and only verifies the integrity of all proteced system files only. (See screenshot below)​
NOTE: If it finds anything like in the screenshot below boxed in red at the bottom, you should run step A to see if it can fix it. See how to read the CBS log above for details on the SFC scan results.​
C) sfc /scanfile=(full path of file) - Scans the integrity of the chosen system file and repairs it if needed.​
EX: sfc /scanfile=C:\Windows\System32\kernel32.dll​
D) sfc /verifyfile=(full path of file) - Scans and only verifies the integrity of the chosen system file.​
EX: sfc /verifyfile=C:\Windows\System32\kernel32.dll​
E) sfc /? - For a list of all sfc command codes with description. (see screenshot below)​
3. Press Enter.​
NOTE: It may take a while to finish.​
4. Close the elevated command prompt when it finishes.​
5. If you got a message to restart the computer in the command prompt, then restart the computer to finish the repair.​
If SFC could not fix something, then run the command again to see if it may be able to the next time. Sometimes it may take running the sfc /scannow command 3 times restarting the PC after each time to completely fix everything that it's able to.
If not, then download and run the 32-bit (x86) or 64-bit (x64) System Update Readiness Tool for your same installed 32-bit or 64-bit Vista, restart the PC afterwards, and try the sfc /scannow command again.
If still not, then you can attempt to run a System Restore using a restore point dated before the bad file occured to fix it. You may need to repeat doing a System Restore until you find a older restore point that may work.
If still not, then you can use the steps in the yellow TIP box at the top of the tutorial to manually replace the files that SFC could not fix.
Re: System Files
Your welcome Peter,
Welcome to the forum. :party:
Glad it solved your problem.
Re: System Files
i followed your guide as i keep getting all kinds of alerts telling me that processes are shutting down. I did the scannow and the result said that there were errors but these could not be fixed. the results were saved in the log files.
So i at least now know there are errors but still can't fix them. Does this now mean i need to do a repair install?
Many Thanks
Sean
Re: System Files
Hi Sean (hypno),
Yes. :(
A repair install would be alot easier that digging through the CBS.log file and then manually reinstalling each corrupted file one by one though. ;)
Have a great New Years,
Re: System Files
Hi Sean (hypno),
Yes. :(
Quick question, same problem here.
But before I go off and do something that might make me hang myself:eek:
Doing a repair install, does it keep all my present settings?
I won't lose anything? (Hope that's the case)
Re: System Files
Hi JohnLug,
You will need to backup your email messages and settings, but you should always backup anything you do not want to lose just in case something goes wrong.
Re: System Files
Dang, was hoping it would be a quick, easy thing.
Oh well, I'll have my new HD in a week or so and before doing anything, I'll backup everything. :)
Re: System Files
JohnLug,
For me all I lost was my Windows Mail stuff. It was no big deal for me, but I would feel bad if something went wrong with the install and you lost everything. :(
Re: System Files
JohnLug,
I know Windows Mail will. I do not know for Outlook, but I would assume it would to be safe.
Re: System Files
Your welcome Rick.
after running /scannow on vista business 32, although I have admin rights, when I went to read cbs.log I got 'access is denied'
how do I get to read it?
Hi dwicker,
At the top of the tutorial there is a link in the To Read CBS Log File section that will show you how to read it without getting the access denied message. Usually if SFC cannot fix it, you will have to do a System Restore, Repair install, or complete reinstall though.
Thanks for your response
I found that by copying to my desktop I could read it
But as it's so large it's mega difficult to read
I've almost decided to do a repair, despit vista been only 6 weeks old on my system
sadly, looks like vista is in beta
Many Thanks
David
David,
Yeah, that CBS file is huge. I like using the method at the top of the tutorial so all you would have to read through is just the logs specifically for SFC. Unfortunately, if SFC and CHKDSK cannot fix it, then the more drastic measures usually have to be taken.
HI John,
Outlook email will also need to be backed up. Different program but still have to back it up. If your referring to Outlook 97/2000/2002/2003/2007 then save your mailbox as a .pst file and you should be ok.
Raj
I cannot run sfc. Have tried in safe mode and normal and just keep getting same error.
Windows Resource Protection could not start the repair service.
Any help?
Microsoft Windows [Version 6.0.6001] SP1
Hi David,
Since you have the SP1 installed, you will not be able run a Repair install from a Vista installation DVD.
I hunted the net with Google and found nothing that really helped. I would suggest running a System Restore using a restore point dated before the problem began. You can see how to here if needed.
http://www.vistax64.com/tutorials/66971-system-restore.html
If the System Restore does not help, or did not go back far enough, this will show you how to undo it.
http://www.vistax64.com/tutorials/76256-system-restore-undo.html
Hope this helps you,
