Solved Zip and unzip
Hello and OK the framework 4 is installed, now I am trying to install the windbg and I get to this point and need to know what I should do, here is a screenshot.
Thanks
Tom
That install Path is okay - Make note of where WinDBG.exe is Located as you will need this to Associate the .DMP Files with it
You may still use Windows Debugging tools if you do not associate the .DMP Files - You will just have to open up WinDBG and then click File > Open a Crash Dump...
If you need any more Help then please ask
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
As MrNeeds says - "Just keep clicking NEXT", anything else will make things too confusing.
FWIW - here's how I suggest using WinDbg: WinDbg Analysis Report
Please note that the only difference may be in the symbol path and (because of recent developments in how WinDbg is downloaded) in the installation path.
Here's the instructions from SevenForums:
Configuring Debugging Tools: Configuring the "Debugging Tools" - Windows 7 Forums
Principles of Debugging: [Advanced] Principles of debugging - Windows 7 Forums
Hello I have followed the instrutions to the letter but it will not let me register, I typed from the cmd and I run it as administrator.
c:\>cd bebuggers
c:\debuggers>windbg.exe _IA
I have ran 4 times and nothing happens, any suggestions, thank you all for your help..
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
Make sure to use a -, not _.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Hello I have followed the instrutions to the letter but it will not let me register, I typr from the cmd and I run it as administrator.
c:\>cd bebuggers
Tom
Did you install Windows Debugging Tools in C:\debuggers?
If not the that is your Problem
Replace Debuggers with the Root of your Debugging Tools
Josh
    AMD HD Radeon 6870
    Novatech Night
Hello
I did change it from c:\program Files\Debugging tools for windows (x64) to
c:\debuggers
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello here is a screenshot for you to see I juts did it again and this is what it says.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
HelloI went searching and found that somehow the Debugging tools for windows (x64) installed it's self twice, here is a screenshot, is it better to uninstall everything and start over.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Did you change the location Windbg is installed in? The default location is C:\Program Files\Debugging Tools for Windows (x64)\, for a 64-bit system.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Thanks
Tom
On this screenshot at the bottom I changed it to the c:\debbuggers
Ok the screenshot did not come along with this, I will try again
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Change it to whatever directory you installed Windbg in.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Hello after opening the windbg this came back, so what do I do now to try and repair this. Thanks
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello Jonathan_King when I gave control of my system to you what did you find that was wrong with it, I know you were all over the place but you got it fixed pretty qucik and to all who read this Jonathan_King is amazing with computers. Thanks
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Looks good mate!
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Glad you got it Sorted ;)
    AMD HD Radeon 6870
    Novatech Night
Hello Josh,
I was looking at your screenshots, the first was ok but in the second well I made a screenshot for you to look at please and then maybe how to get it repaired...Thanks
The debugger file is empty,
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
I am not sure but when I first installed the windbg for some strange reason it did it twice, when Jonathan_King connected to my system he got rid of one, the one that's installed now is the one that during the install I changed the debugging tools for windows (X64) to c:\debuggers, That I think is why it does not look like the one that shows in your screenshot, do you have any idea how to change it because I am having problems with this one as far as I cannot open a mini dump from the forum it keeps opening the one that JK put on my desktop, any help would be great thank you all...
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
I can do another TeamViewer session with you later, Tom.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
May I ask what a Team Viewer session is?
    AMD HD Radeon 6870
    Novatech Night
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
