The Creative Console Launcher file available from our downloads page has
recently been updated. Please redownload the Creative Console Launcher
installer again and your issue should be resolved.
To download, please follow this link:
Customer Support: Downloads
(Please note that the date indicated is still 7 Sept but the file has
been replaced with one that works with X-FI XtremeGamer).
1. To resolve this issue, please try to do a complete uninstall of the
sound card first. You can do this by performing a Cleansweep. This
removes every component that is related to the sound card. Thus,
allowing you to perform a fresh or clean installation. For the
instructions on how to do this, please refer to the link below:
"Uninstalling SoundBlaster Drivers and Applications"
Creative Labs Europe | Customer Support: KnowledgeBase
2. Please swap your sound card to another PCI slot, preferably one that
is farthest from the graphic card.
3. Once you have uninstalled your Sound Blaster please do a clean boot.
A clean boot involves preventing non-essential programs and services
from running in the background. This will help determine if there is a
software or service conflict with the Creative software or hardware. The
instructions on how to do this can be found on either of the link below:
"Clean Boot troubleshooting for Windows"
4. After performing a Clean boot, try to download the latest driver from
our website. Please go to:
Please also make sure that:
* Sound Blaster drivers are properly installed and enabled.
* The Sound Blaster card is selected as the preferred device for
playback as well as recording
* Volume controls are configured correctly
* Disable any 3rd party audio devices such as microphones integrated
with WebCam, or USB microphone or sound card
Here are some additional information that might help us resolve your
issue:
- Are you able to install the new Console Launcher without any issues?
- Can you try to play other games and see if you experience the same
issue you are experiencing in Battlefield Eearth? Do you also experience
this issue in movie/audio playback?
If this issue only occurs in Battlefield 2142, you may want to check
with the game developer to see if they have any updates or patches. This
may resolve your issue.
If the issue persists, please let me take a look at your system specs.
Please follow the instructions below on how to save and attach the CTSI
file:
1. Click Start, Run, and type ctsi.exe.
2. If it reports no such file is available, please run and install
http://files.creative.com/Applications/Creative_System_Information/CSI_1_01_05.exe.
3. Once done installing, startup the program.
4. Once the data is collected, save the file as a .TXT file
5. Zip and attach it in your reply mail.
Again, I apologize for the issue encountered and I hope I have given you
enough information to resolve your issue. By the way, you may be
interested to have the GigaWorks ProGamer G500 5.1 which was designed
to be an awesome gaming speaker system. A THX Certified 5.1 system rated
at 310 Watts total RMS power, its combination of raw muscle and
technical sophistication will blow you away. For more information, here
is the link:
