Wise Registry Cleaner
Going back to the registry question, does the registry get very messy because of installing and uninstalling programs? Will this affect anything?
    ME
    Intel Core 2 Duo 2.40Ghz L2 FSB 1066Mhz
    Gigabyte GA965P DQ6 Rev 1 F11
    Geil PC6400 800Mhz 4GB Dual Channel Ram
    GIGABYTE GTX260
    Creative Sound Blaster XI Gamer Sound Card,
    Seagate 250Gb SATA 11, Samsung 400GB SATA
    Corsair 620W HX Series Modular
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
Any one?
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
The registry gets full of things like programmes you've uninstalled, licence keys for programmes youv no longer got installed, etc.
I use Tune Up to clean away trash files and clean the registry. Its reg cleaner is very lite compared to others, meaning itl miss a few entries to delete. But id rather that than have it delete files i need like ccleaner etc. It can also defrag the registry.
Ok, do you think in time the pc will become unseable if the registry is not cleaned? Do you notice any difference when cleaning the registry and defragging it?
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
There's actually no difference in performance even if you keep the registry as is. Infact, as i told in my earlier post, running registry cleaners is not at all a good idea. Simply let the registry work on its own. When you install a software, it creates its entry in the registry and the same way, when you remove that software, its removed from registry as well. No matter you can still see some registry keys of the software which is longer present in your system, it doesn't mean that your registry is bloating. My recommendations for everyone would remain the same, never use registry cleaners.
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
No the computer will still be useable even if you dont clean and defrag it.
Think of it like using the diskcleanup and defrag utilities of vista. You dont have to use them for your pc to work you could go a year without defragging and your pc will still work.
I just clean the system of junk files, uneeded registry entries and then defrag the registry then the boot files then the rest of the hard drive as i beleive my pc runs faster when iv done that.
When it comes to tweaking my computer for speed, i simply do rest of the stuffs to make vista more faster. But in registry, all i do is reduce waitokill value. Thats it.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
If you dont want to clean the registry, then click the link in my sig and under STEP 3 download the utilities.zip. This includes shortcuts for defragging your boot files etc.
Dont rely on the standard vista cleanup and defrag, at the very least use the advanced shortcuts.
Hi WizKid
Looks like Stew2 and Kavita have given you some good info there.
If you are interested in a Free version of PerfectDisk Professional from Raxco Software then send me a Private Message and I'll give you my Activation Code for it.
Sorry I seemed to upset you a little with my remark on registry cleaners. It wasn't intended to do that to you.
Kind Regards, Neil
    Intel Core i7-920
    Gigabyte GA-EX58-UD3R
    Gigabyte GV-N26OC-896H-B
    N/A - On Board via SPDIF
    BenQ 24" E2420HD
    1920 x 1080p Full HD
    Western Digital 1 x TB Sata 1 x 320GB Sata
    Zalman 1000 Watt
    Antec Twelve Hundred
    2 x Liteon DVD Burners Sata
Stew2, I use both of these Utilities but I like CCleaner a lot better than T/U for cleaning the registry. I do not touch Windows System Files with CCleaner though. I use it often since I am always upgrading my drivers to keep up with the games and such. :p
Kavita, What is a "waitokill" value? :shock:
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Hi astalavista, navigate to Hkey_Local Machine>System>Current Control Set and then at the right hand side you will find waittokill. Double click on it and then chnge the value to 20 and then restart your computer.
Note: The default value is 20000.
This will reduce the shutdown time to a great extent.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hey! So the cleaning registry, we should Windows Vista do it. It is the best choose, isn't it?
Yes, let Vista manage the registry.
    ME
    GIGABYTE GTX260
    LOGITECH G5
    LOGITECH WAVE USB
    4MB
I think the biggest problems caused by reg cleaners are caused by the people who use them. BACKUP YOUR REGISTRY BEFORE USING A REGISTRY CLEANER. imo, hehe.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
don't let programs touch your registry keys, let it be done by a person who knows what to do
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
I use this always
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
If you install and un-install programs a lot you might like to use Revo-Uninstaller and it will remove most of the left over files for you. CCleaner is safe for regular use
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
