Why No More CRT Monitors?
dang, i got two in the garage i'd happily give you (both 17", 1 hp, 1 viewsonic). too bad you're not local to me...:huh:
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
since when can't you adjust the dimensions of an lcd monitor? i can adjust width and height but not in unison, thats why auto adjust was invented lol, if the screen is slightly out of phase or half the picture is off the screen, press the auto adjust and it automatically picks up where the actual edges of the screen are and puts it back into its rightful place, heres a screenie to show that you can adjust the height and width :)
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
@ mpcr well, can you take scans of them and let me see them? I'm not going to buy them, just curious as to how they look...
@ Tstright, not really, I just have better experiences with my crt monitor. For instance, I can never make a 4:3 lcd monitor, widescreen via horizontal and vertical length. I can never adjust the screen on the one I have which is what made me thing lcd's have fixed screen ratios as opposed to tube monitors (which are scanline-free unlike non-hd, tube tvs).
@ above I'm talking about compressing the entire screen vert and hori, I can't do this on my lcd monitor but I guess some lcd monitors can do it. Never saw so for myself though. Also auto-adjust will compress and/or stretch the screen so the edge of the picture will reach the edge of the screen, as you say, but sometimes I may not want that. Also lcd's are freaking expensive...at least the good ones, not a typical dell 4:3 one, which is the one i have.
i suppose you could use a tv, kill 2 birds with one stone :D
    16Mb Sky bb
Even if I never really used a CRT screen, I do find the image better on them while playing games. I had a friend that actually kept his CRT screen to play games with a computer with much higher specs than mine.
    Custom built (Myself)
    Intel Core i3
    Asus P7P55-M
    8GB DDR3
    EVGA Nvidia GTX 550Ti FPB
    HP w2207h with Acer H213H
    1680x1050 and 1920x1080
    1 TB WD Caviar Black 32mb cache, 750 GB WD Caviar Blue, 500 GB WD Caviar Blue, 320 GB WD
    Mushkin HP-550 550W Power suppy
    Cooler Master Elite310
    Air
    Microsoft Comfort 1000
    Logitech Access 600
    15 Mb/s up and down
    I also have an Asus G53SW-A1
