Why does vista keep updating?
There is something wrong. Go to "available updates", right click on the updates and "hide" them. Hopefully they then won't bother you again.
    Dell
    Q6600
    HP w2207h
er..where is available updates?
Besides I don't see how this even should constantly show the option to update. I guess it's either lying about upgrading or lying about me needing to upgrade.
Control Panel>Classic view>Windows Update
Depending on how new the installation is, it's not unusual for WU to keep getting updates.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Whenever I go to start, next to the red shutdown button, is the yellow update shield. I have practically updated 4 times in a day,,,why?
Try reset the whole WU with aggressive mode How do I reset Windows Update components?
If it don't help read in Windows Update history what error messages do you have.
You can also try install these problematic hotfixes directly from Microsoft Download Center http://www.microsoft.com/DOWNLOADS/en/default.aspx ( not from Windows Update)
Er...it won't let me install some updates...could it be because I have symantec anti-virus which the maker of is gay because I cannot install the necessary updates for it without a serial number I have to submit (it runs, just doesn't report to windows security center in a "format" it understands)? Anyway I took a scan, and anyone can tell me what it means...
wow...never thought this crap would be this complicated. I'm gonna have to do this later...damn...and agressive mode didn't work btw. It kinda looked like it did for the first ten minutes.
Yes it means Try again, I've had the same message sometimes, it generally installs at second attempt.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
    Av.MTH, Download 8.27, Upoad 0.91
Try installing the updates one by one. What's gay got to do with it?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Generally? You serious? I think 90% of situations where your computer lets you try something again, just keep failing. "Try again" doesn't work unless you make some kind of change beforehand...or you just got unlucky updating or installing something.
I know that. But often unselecting multiple updates and installing them one by one works.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Yeah i have that :( the updates keep failing but i just ignore it lol!
    Intel Pentium Dual Core E5200 Overclocked @ 2.90
    ASUStek
    OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
    ASUStek ENGTX275 PCI-E x 1
    19inch benq
    1400x900
    400 gb
    700 Watt artic power
    Artic cooler
    4.70 mb/s download, 0.37 mb/s upload
Some updates have to be accepted before you can install them. I do not think that makes the developer gay, he or she is just ensuing that your protection is doing what it is supposed to.
    Dell XPS 720
    Itel Core (TM)2 Extreme CPU Q6800 @ 2.93GHz
    2 TB
    NVIDIA GeForce 9900 GTX
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    3 x 1 TB DEL Hard drives.
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
I was not calling anyone but the manufacturer of symantec antivirus, gay, because you can't, despite having the software, get updates to have symantec report to windows security alerts in a "format it understands" without submitting a serial number to their site. I've yet to see a degree of gay any higher.
K, I'll do the one by one thing. Doubt this is going to work though.
I would pick a better word as anyone who is gay reading this might think it rather derogatory.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Dell XPS 720
    2 TB
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
