in order to change it back to what it *opens with* so it will open as Windows Shell Common file, click on the properties, then where it says *opens with* click on *change*, then *Browse.* Make sure that you change it from *Programs* to *All Files* in the scroll down menu on the lower,right-hand side and then go to C:\Windows\System 32\shell32.dll
shell32.dll is Windows Shell Common. It doesn't matter if you are on 32 or 64-bit.
Hope this helps~
