which card to go for
kev s148
Power User
    home built
    Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
    ASUS P6T Deluxe V2 iX58
    6GB (3x2GB) Corsair Dominator DDR3 1600MHz@1400mhz 8-8-8-24
    BFG GTX 285 OCX
    on board
    samsung t220 sync master
    1TB samsung
    Corsair HX1000W
    antec 902
    Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
    Microsoft Wireless Laser Desktop 7000
    6mb
    LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
Check Radeon HD 5850 too. Test reports are extremely good. May also be cheaper in the UK.
    Dell
    Q6600
    HP w2207h
does look a nice card but the 5870 looks better iam now not sure what to do as the radeon is a directx 11
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
by the looking of things there will be a new nvidia card out in the new year
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
5870 5870!!!!! really the 5870 is the better card and if you have the cash two of those on cf will smoke anything out there, but even a single 5870 is faster than the 285 and just as fast as the 295 and its cheaper
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
looking at the specs of them they do look dam good and the price of them is around £320
BUT what price and what spec are the nvidia gt300 going to be ???
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
Any way if i had to pick one of tha cards from my first post which one would be the best to go for
Thank you
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
Honestly? I'd go the 285. Less niggles with SLI issues and at the resolution you are using, it would handle pretty much most games maxed out.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
What if any is the diffrence between ati and nvidia graphics cards
or is it down to personal prefrences
sorry for all the questions i just want to make sure iam geting the right
card as iam going to be spending around £300
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
um mostly personally preference, but with ati you get more power for the money where nvidia is more expensive..... but honestly i wouldn't get either of those nvidia cards i'd get a 5870, also as far as nvidias new card so far its been a flop and will prolly be slower than its 295.... and its price will prolly be way more than £320
    1680 X 1050
    6 Mbs Down 1 Mbs Up
yep, look at these benchmarks :
HD5870 Benches
1
2
3d Vantage-295 beats the 5870 but how much is 295 compared to the hd5870? exactly.
hope this helps with your dilemma ;)
Dom
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
I have read on a few sites that there use to be problems with the software on the ati cards and if so have these problems been sorted
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
HD5870 Benches
1
2
Dom
I can get a nvidia gtx295 oem for £310
but i would rather spend a bit more on a future proof card
like ive said iam going to be spending about £300 so i want to get it right
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
that has been fixed :p and their software just keeps getting better now, also the 5870 is the much better card..... and if you can get two on cf you will be set for the next few years
    1680 X 1050
    6 Mbs Down 1 Mbs Up
Check out the 5850HD, that's got comparable speeds with the GTX 295. If you can afford it, go with 2 5850's in CrossFire. Also, if you can, wait till December/January for nVidia's GT300 series release.
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
if you want complet hassle free computing the 285 , if your not worried about working out the odd sli niggle you may come across then the 295 for raw power :D
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
after what ive read and seen i might now be going for the ati hd5870 as for some reason i can see the nvidia version being aroun the £400 marker
and in all the reviews ive seen the hd5870 has beeten the gtx285
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
exactly...... the 5870 is the best deal right now.... add a second one later and your set for years :D
and @archie..... nvidia has never had raw power :sarc: just good drivers thats it..... raw power and nvidia shouldn't even be in the same sentence unless its nvidia doesn't have raw power :party:
    1680 X 1050
    6 Mbs Down 1 Mbs Up
In that case, go for the 5870. Honestly, whatever you buy now will be superseded anyway, but the 5870 will be enough for quite some time.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
