Bare Foot Kid
R.I.P. August 13th 2014
I have no idea what the difference is between those.
Here is what happens. I turn on the machine and it sends me to a "system recovery options" screen after I choose the OS and choose my profile and enter the password. My options are Startup Repair, System Restore, Windows Complete PC Restore, Windows Memory Diagnostic Tool, Command Prompt, and Recovery Manager. If I choose Recovery Manager it will give me the option of 'Recovery with automatic backup' or 'Full factory recovery'. None of the other options before that are working at all. I've tried startup repair and it says there isn't anything wrong. None of the restore points exist anymore, but when there were some options it wouldn't actually restore to the points I was trying to send it to. So basically my last option is to do a full on restore while trying to preserve some of the folders in the user profile.
This would be your best option!
LaterTed
It sounds like you believe that it will save my user profile files then, right? As long as I can still get access to those files then I'll be happy. For all I know it will pretend to do the full system restore and then it will end up booting on to the same screen I'm at now. lol
There are NO GUARANTEES, but it doesn't sound like you have many other options.
Later
- * BFK Customs *
- Intel C2Q 9550 Yorkfield
- ASUS P5Q Pro
- 8GB Dominator 8500C5D
- XFX ATI 1GB 4870 XXX
- Realtek HD 7-1
- 1x 47" LCD HDMI & 2x 26" LCD HDMI
- 1920x1080P & 1920x1200
- 2x 500GB 7200RPM 32MB Cache WD Caviar Black
- PSU
- Corsair 620HX
- Case
- CM Cosmos RC-1000
- Cooling
- Tuniq Tower 120, 2x 140mm and 3x 120mm case fans
- Razer Diamondback 3G
- HP Enhansed Multimedia
- 18.6Mb/s
- Other Info
- My First Build ;)
