Nemephosis
"when" makes it sound like a sure thing that should definitely not be turned on, I'm fairly sure you weren't going for that though
"when" makes it sound like a sure thing that should definitely not be turned on, I'm fairly sure you weren't going for that though![]()
ah! They do say after all that "you die only once". If murphy pays you a visit then your only hope is: Sr or backup or both or throw the damn thing out the window (in the case you live in a basement go to the first floor).
I have been saved in the past by sr and when that has failed to solve the problem i just switched hds (i always make an image of my hd ). I use acronis true image; excellent software and a lifesaver.:d
