What have the kids done to my comp.
Hi Hunter1mantis,
In addition to what richc46 has said, check for services if they are set properly. Please follow below mentioned steps:
1. Click on the Start button.
2. in the Search box, type SERVICES.MSC.
3. Press Enter key.
4. Accept any UAC prompt that appears, and in the Services control panel, look for the following
5. Background Intelligent Transfer Service -double-click on it,
6. Check the Startup type - ensure that it is set to 'Automatic (Delayed Start)
7. Windows Update-double-click on it
8. Check the Startup type - ensure that it is set to 'Automatic (Delayed Start),
9. Now try starting the Windows Update service and the BITS - if you get errors, post the EXACT error message.
Please post back with the results.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
Looks like that display setting of the monitor have been change, try to solve it from the monitor front button as well as Display option comes on desktop home screen.
    Dell Inspiron 1550
    i3 Processor
    3gb
    320 Gb
hi there,,
i work in a repair centre and we have the same error message on 4 different machines this morning.
1 of them has just had a format and re install on a new hard drive
2 others have just been cleaned of infections and were working fine with updates yesterday.
those 3 were on vista...
we have one on windows 7 that also has exactly the same error message.
so its not vista only...
so before trying to fix something that isnt broken i would hang fire.. it might be an issue with microsofts servers.. it is the release day of windows 8..
