Hi & yes.
If you are unwilling to use the recovery console? Then I would suggest that the best way forward on this is to re-install XP on to the partition.
I would also suggest you wipe the current XP partition & install it as if it was "Spare space". OK?
- HP-Pavilion m9280.uk-a
- 2.30 gigahertz AMD Phenom 9600 Quad-Core
- ASUSTek Computer INC. NARRA3 3.02
- 3582 Megabytes Usable Installed Memory (4 Gig)
- ASUS NVIDIA Geforce GTS450
- Realtek High Definition 7.1 Audio (HP drivers)
- HP w2408 24.0" (Dual monitor)
- 1920 * 1200, 1920 * 1200
- 3*500 Gigabytes Usable Hard Drive Capacity Plus 2x USB (160Gig each) external HDD BluRay & DVD Weiters HL-DT-ST BD-RE GGW-H20L SCSI CdRom (Bluray RW) Device AlViDrv BDDVDROM SCSI CdRom (Blueray) Device TSSTcorp CDDVDW TS-H653N SCSI CdRom
- 40 Meg
