Warcraft 3 Problems
i've tried that. this is annoying. i really want to play. anyways, i've tried something else. i've downloaded the game from the blizzard account store and when it finishes it doesnt do anything. so i go into the folder it created and double click the installer. a w3 menu comes up and says play frozen throne. so of course i click it and the menu disappears then just comes right back up. is there something i;m doing wrong? please help. thank you
    Dell XPS 420
    Dual Intel Core 2 Duo E6850 @ 3.0 GHz
    ACPI x86
    nVidia GeForce 8800 GT
    IDT High Definition Audio
    SyncMaster 2493HM Digital 24" Widescreen
    1920 x 1200
    Dual Western Digital 500GB Disk Drives
    Logitech G5 Gaming Mouse
    Logitech G11 Gaming Keyboard
    6k KB/s DL, 700 KB/s UP
Your welcome, sorry we couldn't help you more.
    Dell XPS 420
    ACPI x86
    1920 x 1200
so basically Blizzard said they do not support vista-64bit so they can't really help. -_- so many people have gotten the same error as me i just don't understand how they fixed it :[
I found this on atomicmpc.com, you may want to try this:
gummybear said:
well i just went to the eb sale before and thought i'd pick up wc3 + the wc:FT expansion since my bro also plays (cd key conflict!)
anyway, i have vista ultimate and couldn't get it to install, but i found a fix after quite abit of searching.
1) Go to Start > Run > type regedit
2) Navigate to "HKEY_CURRENT_USER\Software\Microsoft\Windows\Current Version\Explorer\Shell Folders"
if there is no string in there called "Programs" put that in with the value:
C:\\Users\\%USERNAME%\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs
and you can get the installation to work, game works fine too.
this may work for other games with the same problem. thought i'd post it up incase some had the same issue...
    Dell XPS 420
    ACPI x86
    1920 x 1200
Im trying that method now but is it possible to put my wc3 folder on my working computer and drag and drop it onto a portable hard drive and then put it on my laptop?
Glad that worked for you.
    Dell XPS 420
    ACPI x86
    1920 x 1200
my problem is kinda like this but when i go to install WCIII:RoC it gets to the install screen and i press the install button and then nothing then it says the program is not responding, i have tried a few different things including: updating directX, messing with the regedit stuff the programs string was already there
i just cant figure out why its messing up its a clean disk works fine on my other comp which is running XP
i have also tried to go into the disk and run as admin and compatability but when i go in the right click the say not responding and windows explore closes.
any help would be nice thanks.
i tried this but.... after installing... when i open the game... the monitor adjust 3-4 times then returned to desktop...
I have Vista Home Premium 32bit Sp1 Build 6001
