Visual studio 2005 in 64-bit vista
I did so and i got this message:
Windows cannot find 'G:\setup.exe'. Make sure you typed the name correctly, and then try again.
Sorry, Which suggestion did you try when you got that message?
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
I don't know if this helps but it sounds like this method worked for this person,
http://www.vistax64.com/net-general/162907-visual-studio-2005-vista-64-issues.html#post756013
It seems i have a similar problem. But the person in this thread was able to install vs2005 but i am not able to. In the 3rd post it says something about 'copying the files from the DVD'. Where to copy the files to?
You could try copying the files to the desktop and see if that works.
Just so you know you're not alone, there seems to be quite a few people with similar issues from what I can find, I know that's not an answer but at least you know it's not just your computer.
    Asrock P67 Extreme4
    auria eq2367
How about if you try this, Copy the file to your desktop, right click and go to Properties, Compatibility tab and check the box to run in compatibility mode and select xp sp2 mode, also check the run this program as administrator box, apply, OK.
Worth a try.
    Asrock P67 Extreme4
    auria eq2367
    Asrock P67 Extreme4
    auria eq2367
Sorry but I am at a loss as to how to get that working, Unless you want to try to put it in the program files x86 and see if you can run it from there.
    Asrock P67 Extreme4
    auria eq2367
nope that doesn't do it either
Do you have UAC turned off? You Have to restart to take effect, That seems to be what worked on at least one of the searches I found earlier.
    Asrock P67 Extreme4
    auria eq2367
    Asrock P67 Extreme4
    auria eq2367
I have an installation guide for the other software which says i need 2005.... since 2005 is not working i have to go for other versions now
Let us know how that works out for you.
    Asrock P67 Extreme4
    auria eq2367
I don't mean to be rude here in any way, but you are sure you need Microsoft Visual Studio 2005, not Microsoft Visual C++ 2005 Redistributable Runtimes. Some developmental software and SDKs however, will need Visual Studio, so you are probably perfectly correct when you say that this is what you need. If however, all you are trying to do is get a game to work, then you probably need the runtimes. Can you please tell us what piece of software you are trying to get working?
Sorry if it is Visual Studio that you need,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard
Hi Richard,
The software he told me he was trying to install is called "opnet modeler 14.0 which needs visual 2005 for a project". The quoted text is what he wrote in a message to me.
Derek
    Asrock P67 Extreme4
    auria eq2367
Richard
Hi Richard,
Derek
Thanks for that derekimo. Missed that fact when reading this thread!
Sorry,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard
Hi Richard,
Derek
Sorry,
Richard
No need to be sorry it was actually in the message that he sent me to say Thanks so you couldn't have known, You didn't miss anything that was there!;)
    Asrock P67 Extreme4
    auria eq2367
Is this problem solved ?
I got exactly the same problem on a windows 7 64 bit machine. I need vs2005 because I develop software for a Windows CE and this needs vs2005.
If there is a solution for this problem, I really like to hear.
