Visual Performance
You posted in this thread saying your machine was slow. That might simply be because you have a lot of processes running in the background. But changing the display settings will save some memory. Like I said before usually around 14 - 20 MB.
I really do not have a lot of processors running.I sent some pics, maybe you can tell me wich ones I do not need?.Thanks
    Dell Inspiron 1525
    CELERON DUO
    360GB
Whats the percentage of ram used at idle, and how many processes do you have running at idle?
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
you can type msconfig and see what processes you are initially starting
    Dell Inspiron 1525
    CELERON DUO
    360GB
mdnsresponder is part of apples bonjour service. If you run itunes I think it automatically installs on your computer. This is not a necessary service.
The only other question I'd ask is are you running more than one malware program as a service? If so, this could give you a performance hit. Otherwise, your processes look pretty streamlined.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Yeah I am not sure about the bonjour, i have no ipod,or iphone, i just download podcasts,so how do i disable this feature?.I only use microsoft security essentials, and bitdefender security,that is all.Thanks
    Dell Inspiron 1525
    CELERON DUO
    360GB
to disable bonjour type services.msc in search and find bon jour right click and disable
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Bonjour and quicktime install when you install iTunes.
They can be disabled under services safely as everything will still function with out it.
Start > type services and hit enter > look for anything associated with iTunes.
To change whether it starts up automatically or not, double click on the service you want stopped, ie. Bonjour. Change the start up type to 'Manual' then hit 'Stop' see picture.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
ken
Hi Ken, will I still be able to use itunes?,to view my podcasts?this is all I use it for.
    Dell Inspiron 1525
    CELERON DUO
    360GB
ken
according to the description of bon jour you should be fine. read about the service in services.msc
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
iTunes will still function perfectly, as I had all iTunes default auto services set to 'Manual' never a problem.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Ok, I disabled it, itunes said that bonjour is disabled.but itunes still loaded up ok. thanks for that ken.
    Dell Inspiron 1525
    CELERON DUO
    360GB
    Dell Inspiron 1525
    CELERON DUO
    360GB
ken
Thanks ken, I did it! it's all good:)
if you dont share WMP over your network, you can also dis able wmpnetwk.exe. it is only used to share wmp media and is constantly looking for devices, etc
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
I do not share this either.thanks a lot mate!:)
    Dell Inspiron 1525
    CELERON DUO
    360GB
