When you go into the bios and change the boot order to boot from a dvd
Put in the dvd and restart and you will be asked press any key to boot from dvd
If you use a Vista install disc on the left hand side after it starts to boot is the option repair my computer this is on a screen that also says install Vista
Since you don't want to reinstall try the option repair my computer
- Lenovo Thinkpad T400
- Intel Mobile Core 2 Duo P8700 @ 2.53GHz
- LENOVO 64734VM
- 2.00GB Single-Channel DDR3 @ 531MHz
- Intel Mobile Intel 4 Series Express Chipset Family
- Conexant 20561 SmartAudio HD
- 15 inch
- 1280 x 800
- 1x 180GB Intel 530 series SSD 1 x 120GB Hitachi 5400rmp 1 x 650GB Western Digital Elements 5400rpm 1x 1Tb Western Digital Elements 5400rpm
- Medium for New Zealand
- Other Info
- Weakest part of my computer is the graphics chipset. Only ever used a laptop. Also use USB Freeview TV Card Lenovo Docking Station External Speakers Other bits a pieces as needed
