Solved Vista won't start - Startup Repair can't.. what next
just sounds like dust causing an overheat. if your fan still works your ok, but if you want to monitor it try downloading nvidia system monitor NVIDIA System Tools with ESA Support
    Home built
    phenom IIx4 810
    m4a79t deluxe
    8Gb DDR3 OCZ Platinum AMD Edition
    evga 295 co-op and 9800 gtx for PhysX
    Mk241H
    1920x1200
    Seagate Barracuda 7200 750Gb
    ABS Tagan BZ 800W
    Xclio A380PLUS-BK Fully Black
    Asus Royal Knight
    Logitech 5 button tilt wheel laser (don't remember model#)
    Razor Lycosa Mirror edition
    Wireless Road Runner
aerofanadam
How far from the Gillman Honda and Mitsubishi dealership are you? I lived Off Independence Ave, that is just behind the KMart that shut down years ago when I was in San Antonio, TX .
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
aerofanadam
Not too far I'm in the neighborhood where 3009 dead ends on Fm78
    Home built
    phenom IIx4 810
    m4a79t deluxe
    Mk241H
    1920x1200
    ABS Tagan BZ 800W
    Asus Royal Knight
I miss San Antonio but I really miss HEB stores and the Jalapeno sausage they sell.
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
yeah i couldn't go without the heb I hate walmart and can't see going to a place named piggly-wiggly
    Home built
    phenom IIx4 810
    m4a79t deluxe
    Mk241H
    1920x1200
    ABS Tagan BZ 800W
    Asus Royal Knight
Give yourself a huge pat on the back, now that you are a computer nerd, (the next step is computer geek), there will be no stopping you.
If you give it a good clean every couple of months or so you should be OK.
You can add an extra fan if you feel the need, but if it's kept clean then it should be OK.
I'm glad your up and running again. :)
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hi Stoney
I have now copied over everything from external drive that I want, good excuse for a bit of housekeeping! The only thing I need a final piece of advice on is that my video files that I copied using the Backup thingy when doing the Factory Reset are now .dat files. I don't know how to access them? I am currently copying them over and its going to take 3 and half hours so there is obviously a load of data there. The folder says USMT2.UNC (if memory serves). Any clues on what I do next?
Thanks Aerofan, I will download the tool you suggested.
I am glad to belong to the fellowship of computer nerds. Do I get a certificate and a medal or something?! I am actually quite chuffed with what I have done, thanks to you lot it gave me the courage to have a go.
RRxx
Hello fellow nerd, hehe,
I think it's because you have to associate them with the software you view them with, when you install the software or view them they should be OK.
If not give us a shout and we will take a look.
Really glad all is running OK.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hi Stoney
RRxx
Just glad my two bits were worth something (just don't look at the second one it might be Canadian;)). I always feel like trying to give out tech advise is like playing pool in a bar. You might be good, hell you might be damn good, but the next guy might me Minnesota Fats!
    Home built
    phenom IIx4 810
    m4a79t deluxe
    Mk241H
    1920x1200
    ABS Tagan BZ 800W
    Asus Royal Knight
