Issue:
After installing updates from Windows Update, you may get into a Reboot loop where you machines gets to “configuring updates 3 of 3. 0% complete” then reboots. The machine then continues to reboot.
Solution:
1a. Boot to the Windows DVD and choose the repair option in the lower left hand corner, choose System Restore, and select a Restore Point predating the attempted installation of the updates.
1b. If you don't have the DVD and the Vista came preinstalled on the machine, boot to the Safe Mode options using F8 during startup (tutorial: How to start Windows in Safe Mode).
Once in Safe Mode, invoke System Restore as follows:
Start | Run | (type in) rstrui.exe | [OK]
Select an available Restore Point predating the attempted installation of the updates.
Recommendation:
To avoid running into the same problem again, install the following update separately and ASAP:
A software update is available for the Windows Vista installation software feature:
Download links for manual installation:
Vista x86 : Download details: Update for Windows Vista (KB937287)
Vista x64: Download details: Update for Windows Vista for x64-based Systems (KB937287)
Solution:
Recommendation:
- Home Build
- AM2 Black
- Gigabyte S-Series
- 4Gb
- G/F 9600 GT
- onboard
- 22in LCDX2
- to many to list
- PSU
- Home Build
- Case
- God knows
- Cooling
- Fan
- yes got one and a Cat
- yes with Buttons
- 1.5mb
