For those with just one hard drive, assuming that you have enough space, use the Disk Management (right click My Computer, select Manage, then select Disk Management) and shrink your current Vista partition as much as it will allow. Once that is done, create a new partition in the space provided, format it and let it mount it to a new drive letter, the system will pick this for you. Now, make a note of the partition sizes, try to keep them as distinct as possible (If you drive is a 250 GB drive, then shrink the original partition to 150 GB and let Vista create a second 100 GB partition).
Now, you can back up your files to the new partition, and then perform a clean install ***only formatting the larger 150 GB partition)
Remember this is an example - use whatever numbers on the partitions to make it obvious to *you8 which partition is which - when you go to format your partition you obviously want to format the partition where Vista is installed, not where you stored your files and such....
Of course, this point is pretty much moot if you have a Vista recovery partition from an OEM, as I think those format the *drive* and not the partition, but I may be mistaken....
- Operating System
- Windows 10 Pro X64 Insider Preview (Skip Ahead) latest build
- The Beast Model V (homebrew)
- Intel Core i7 965 EE @ 3.6 GHz
- eVGA X58 Classified 3 (141-GT-E770-A1)
- 3 * Mushkin 998981 Redline Enhanced triple channel DDR3 4 GB CL7 DDR3 1600 MHz (PC3-12800)
- eVGA GeForce GTX 970 SSC ACX 2.0 (04G-P4-3979-KB)
- Realtek HD Audio (onboard)
- 2 * Lenovo LT2323pwA Widescreeen
- 2 * 1920 x 1080
- SanDisk Ultra SDSSDHII-960G-G25 960 GB SATA III SSD (System) Crucial MX100 CT256MX100SSD1 256GB SATA III SSD (User Tree) 2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II Mech. HD Seagate ST1500DL001-9VT15L Barracuda 7200.12 1.5 TB S
- PSU
- Thermaltake Black Widow TX TR2 850W 80+ Bronze Semi-Mod ATX
- Case
- ThermalTake Level 10 GT (Black)
- Cooling
- Corsair H100 (CPU, dual 140 mm fans on radiator) + Air (2 *
- Logitech MX Master (shared)
- Logitech G15 (gen 2)
- AT&T Lightspeed Gigabit duplex
- Operating System
- Sabayon Linux (current, weekly updates, 5.1.x kernel)
- Lenovo ThinkPad E545
- AMD A6-5350M APU
- Lenovo
- 8 GB
- Conextant 20671 SmartAudio HD
- Lenovo 15" Matte
- 1680 * 1050
- INTEL Cherryvill 520 Series SSDSC2CW180A 180 GB SSD
- PSU
- Lenovo
- Case
- Lenovo
- Cooling
- Lenovo
- Logitech MX Master (shared) | Synaptics TouchPad
- Lenovo
- AT&T LightSpeed Gigabit Duplex
