Solved Vista won't boot, System restore/Startup repair can't fix
For some reason, it would not boot into sfae mode command prompt before, but somehow it worked just now. I have it running sfc /scannow and a chkdsk on next reboot.
Keeping fingers crossed!! :D
Good, well done! You are working very hard to help repair this computer.
Fingers crossed!:D
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
The HDD is dying, the chkdsk revealed bad sectors. The laptop is under warranty and Fujitsu is sending us a replacement HDD. Thanks for all of your help!
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
im having the same issue but with a vista ultimate x64 bit tower not laptop i have tried the windows repair disk like it said and i have tried safe mode and last known point, the things i was doing before it happened was downloading minecraft, what can i say im a sucker for gaming
I had the exact same problem and all you have to do is wait it out. This is the first time i have just let the computer do it's thing while i researched how to fix it. Give it time and I promise it will start-up just fine.
