Solved Vista will not start up, CHKDSK stopped?
Not usually in this case. When you are ready, we will get you an ISO. Just burn to a CD, then install. You will be asked the KEy number. It should work at that point. Because it is OEM, if you do have a problem, MS will tell you to speak to the computer manufactuer. Lets hope we do not have to, however.
Not if you're using it on the same computer that Vista was originally installed on. It's pretty obviously that you meet that criterion.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I went in to a computer shop, bought a new hard drive and exchanged it with the current one. They helped me put the OS back on the system, and it works! So far so good, fingers crossed.
Thank you everyone that helped. I really appreciated the assistance when my computer was dead.
You are very welcome. We are glad that we were able to resolve your problem.
