Vista System restore failed not able to boot up - blue screen
Hi Lemur,
When I tried this, it is showing below message:
C:\Windows\System32>EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys
Microsoft (R) File Expansion Utility Version 6.0.6000.16386
Expanding nvlddmkm.sy_ to nvlddmkm.sys.
Can't open output file: nvlddmkm.sys.
Did I do anything wrong.
And also when I checked timestamps for both nvlddmkm.sy_ in Video folder, and nvlddmkm.sys in system32\drivers folder --both are having same date: 26\04\2007
Joshna
This solution comes with a money back guarantee (pay the man, Ken)...
During the installation of the most current Vista drivers, an OLD file
nvlddmkm.sys is copied into windows/system32/drivers and not the current one
in the install.
Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
nvlddmkm.sys.old. Go to the nvidia directory and find the file nvlddmkm.sy_
and copy it to windows/system32. Using the cmd window (DOS box) type
EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete, copy
the new nvlddmkm.sys to windows/system32/drivers and restart the computer.
Your computer should now work properly.
You will notice that any uninstall and reinstall of nvidia drivers will not
remove the old nvlddmkm.sys file and will not overwrite it with the newer
version. You have to do it manually. I do not know why this happens but who
cares as long it is fixed.
    SONY Vaio VGN-FZ11Z
    Intel Core 2 Duo Processor T7300 2GHZ
    2 GB/Go DDR2
    NVIDIA GeForce 8400M GT GPU, Blue Ray Disc Drive
    15.4 WXGA (1280X800) X Black LCD with Double Lamp technology
    1280X800
    200GB/GO
Hi Ken,
What app should I get to check temp. Sometimes it runs hot. Not always.
Joshna
joshna
does that laptop run hot? get an app to check the temps like everest, cpu-z and tell u s what they are
ken
    SONY Vaio VGN-FZ11Z
    2 GB/Go DDR2
    1280X800
    200GB/GO
It sounds like your drive may be bad - if you tested in on two computers and the installation failed. I'm sorry if you stated this before. Who is the manufacturer of the drive?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
I do not understand lemur.
    SONY Vaio VGN-FZ11Z
    2 GB/Go DDR2
    1280X800
    200GB/GO
Do you know who the manufacturer of your hard drive is?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
How can I know the manufacturers name. My laptop is Sony Vaio VGN-FZ11Z ..200GB/go HDD
    SONY Vaio VGN-FZ11Z
    2 GB/Go DDR2
    1280X800
    200GB/GO
