Vista problems
I haven't tried it in safe mode yet. But I did disable the sound driver and have played with no sound and it seems to be all right. I will continue to try it out.
    AMD Phenom X4 9750 Quad-Core Processor
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Okay, let us know how that goes and we'll try and find a fix :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
OK that didn't work. With the HD audio driver uninstalled it still caused a crash. Shouldn't the nvidia driver work alone? After i uninstalled the windows audio driver there was only the nvidia driver left, but there was no sound at all. After the crash, I rebooted and windows installed it's driver.
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Okay, can you do the following for me please?
OTL
Download OTL to your desktop.
Double click on the icon to run it. Make sure all other windows are closed to let it run uninterrupted.
When the window appears, underneath Output at the top change it to Minimal Output.
Under the Standard Registry box change it to All.
Check the boxes beside LOP Check and Purity Check.
Click the Run Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL.
Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post it with your next reply.
Once OTL has completed its first scan it will save notepad copies of the scans in the folder that OTL was started from. Unless set to produce an Extras log it will only produce OTL.txt in subsequent scans.
A copy of an OTL fix log is saved in a text file at
:\_OTL\MovedFiles
in most cases this will be C:\_OTL\MovedFiles
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
OTL logfile created on: 7/31/2011 9:43:35 AM - Run 1
OTL by OldTimer - Version 3.2.26.1 Folder = C:\Users\Alexian\Desktop
Windows Vista Ultimate Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 9.0.8112.16421)
Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
3.00 Gb Total Physical Memory | 1.68 Gb Available Physical Memory | 56.03% Memory free
6.21 Gb Paging File | 4.81 Gb Available in Paging File | 77.38% Paging File free
Paging file location(s): ?:\pagefile.sys [binary data]
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files
Drive C: | 465.75 Gb Total Space | 148.77 Gb Free Space | 31.94% Space Free | Partition Type: NTFS
Drive E: | 37.26 Gb Total Space | 19.47 Gb Free Space | 52.27% Space Free | Partition Type: NTFS
Drive F: | 1397.23 Gb Total Space | 1310.75 Gb Free Space | 93.81% Space Free | Partition Type: NTFS
Computer Name: MAGIC-BOX | User Name: Alexian | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user
Company Name Whitelist: Off | Skip Microsoft Files: Off | No Company Name Whitelist: On | File Age = 30 Days
========== Processes (SafeList) ==========
PRC - C:\Users\Alexian\Desktop\OTL.exe (OldTimer Tools)
PRC - C:\Program Files\Real\RealPlayer\Update\realsched.exe (RealNetworks, Inc.)
PRC - C:\Program Files\Logitech\SetPointP\SetPoint.exe (Logitech, Inc.)
PRC - C:\Program Files\Common Files\Logishrd\KHAL3\KHALMNPR.exe (Logitech, Inc.)
PRC - C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe (NVIDIA Corporation)
PRC - C:\Program Files\NVIDIA Corporation\Display\nvtray.exe (NVIDIA Corporation)
PRC - C:\Program Files\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe (NVIDIA Corporation)
PRC - C:\Program Files\Secunia\PSI\psia.exe (Secunia)
PRC - C:\Program Files\Secunia\PSI\sua.exe (Secunia)
PRC - C:\Program Files\Secunia\PSI\psi_tray.exe (Secunia)
PRC - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\ccsvchst.exe (Symantec Corporation)
PRC - C:\Program Files\Common Files\Logishrd\LVMVFM\UMVPFSrv.exe (Logitech Inc.)
PRC - C:\Program Files\DivX\DivX Update\DivXUpdate.exe ()
PRC - C:\Windows\explorer.exe (Microsoft Corporation)
PRC - C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe (Safer-Networking Ltd.)
========== Modules (SafeList) ==========
MOD - C:\Users\Alexian\Desktop\OTL.exe (OldTimer Tools)
MOD - C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcr90.dll (Microsoft Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcp90.dll (Microsoft Corporation)
MOD - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\asoehook.dll (Symantec Corporation)
MOD - C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll (Microsoft Corporation)
========== Win32 Services (SafeList) ==========
SRV - (Akamai) -- c:\Program Files\Common Files\Akamai\netsession_win_e477fed.dll ()
SRV - (Lavasoft Ad-Aware Service) -- C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe (Lavasoft Limited)
SRV - (LBTServ) -- C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe (Logitech, Inc.)
SRV - (nvUpdatusService) -- C:\Program Files\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe (NVIDIA Corporation)
SRV - (MotoHelper) -- C:\Program Files\Motorola\MotoHelper\MotoHelperService.exe ()
SRV - (Secunia PSI Agent) -- C:\Program Files\Secunia\PSI\PSIA.exe (Secunia)
SRV - (Secunia Update Agent) -- C:\Program Files\Secunia\PSI\sua.exe (Secunia)
SRV - (N360) -- C:\Program Files\Norton Security Suite\Engine\5.1.0.29\ccSvcHst.exe (Symantec Corporation)
SRV - (UMVPFSrv) -- C:\Program Files\Common Files\Logishrd\LVMVFM\UMVPFSrv.exe (Logitech Inc.)
SRV - (FLEXnet Licensing Service) -- C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe (Acresso Software Inc.)
SRV - (DeviceMonitorService) -- C:\Program Files\Motorola Media Link\NServiceEntry.exe (Nero AG)
SRV - (MotoHelper.exe) -- C:\Program Files\Motorola\Moto Helper Service\MotoHelper.exe (Motorola)
SRV - (ServiceLayer) -- C:\Program Files\Nokia\PC Connectivity Solution\ServiceLayer.exe (Nokia)
SRV - (nHancer) -- C:\Program Files\nHancer\nHancerService.exe (KSE - Korndörfer Software Engineering)
SRV - (npggsvc) -- C:\Windows\System32\GameMon.des (INCA Internet Co., Ltd.)
SRV - (sprtsvc_ddoctorv2) SupportSoft Sprocket Service (ddoctorv2) -- C:\Program Files\Comcast\Desktop Doctor\bin\sprtsvc.exe (SupportSoft, Inc.)
SRV - (WinDefend) -- C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
========== Driver Services (SafeList) ==========
DRV - (eeCtrl) -- C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys (Symantec Corporation)
DRV - (EraserUtilRebootDrv) -- C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys (Symantec Corporation)
DRV - (DrvAgent32) -- C:\Windows\System32\drivers\DrvAgent32.sys (Phoenix Technologies)
DRV - (BHDrvx86) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\Definitions\BASHDefs\20110723.001\BHDrvx86.sys (Symantec Corporation)
DRV - (SymEvent) -- C:\Windows\System32\drivers\SYMEVENT.SYS (Symantec Corporation)
DRV - (IDSVix86) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\Definitions\IPSDefs\20110729.030\IDSvix86.sys (Symantec Corporation)
DRV - (NAVEX15) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\Definitions\VirusDefs\20110730.002\NAVEX15.SYS (Symantec Corporation)
DRV - (NAVENG) -- C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\Definitions\VirusDefs\20110730.002\NAVENG.SYS (Symantec Corporation)
DRV - (Lbd) -- C:\Windows\system32\DRIVERS\Lbd.sys (Lavasoft AB)
DRV - (Lavasoft Kernexplorer) -- C:\Program Files\Lavasoft\Ad-Aware\kernexplorer.sys ()
DRV - (nvlddmkm) -- C:\Windows\System32\drivers\nvlddmkm.sys (NVIDIA Corporation)
DRV - (LMouFilt) -- C:\Windows\System32\drivers\LMouFilt.Sys (Logitech, Inc.)
DRV - (LHidFilt) -- C:\Windows\System32\drivers\LHidFilt.Sys (Logitech, Inc.)
DRV - (LVUVC) Logitech HD Webcam C310(UVC) -- C:\Windows\System32\drivers\lvuvc.sys (Logitech Inc.)
DRV - (SRTSP) -- C:\Windows\System32\Drivers\N360\0501000.01D\SRTSP.SYS (Symantec Corporation)
DRV - (SRTSPX) Symantec Real Time Storage Protection (PEL) -- C:\Windows\system32\drivers\N360\0501000.01D\SRTSPX.SYS (Symantec Corporation)
DRV - (SYMTDIv) -- C:\Windows\System32\Drivers\N360\0501000.01D\SYMTDIV.SYS (Symantec Corporation)
DRV - (SymEFA) -- C:\Windows\system32\drivers\N360\0501000.01D\SYMEFA.SYS (Symantec Corporation)
DRV - (SymDS) -- C:\Windows\system32\drivers\N360\0501000.01D\SYMDS.SYS (Symantec Corporation)
DRV - (SymIRON) -- C:\Windows\system32\drivers\N360\0501000.01D\Ironx86.SYS (Symantec Corporation)
DRV - (LVRS) -- C:\Windows\System32\drivers\lvrs.sys (Logitech Inc.)
DRV - (PSI) -- C:\Windows\System32\drivers\psi_mf.sys (Secunia)
DRV - (SASKUTIL) -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS (SUPERAdBlocker.com and SUPERAntiSpyware.com)
DRV - (nvsmu) -- C:\Windows\System32\drivers\nvsmu.sys (NVIDIA Corporation)
DRV - (SASDIFSV) -- C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS (SUPERAdBlocker.com and SUPERAntiSpyware.com)
DRV - (SASENUM) -- C:\Program Files\SUPERAntiSpyware\SASENUM.SYS ( SUPERAdBlocker.com and SUPERAntiSpyware.com)
DRV - (BVRPMPR5) -- C:\Windows\System32\drivers\BVRPMPR5.SYS (Avanquest Software)
DRV - (NVHDA) -- C:\Windows\System32\drivers\nvhda32v.sys (NVIDIA Corporation)
DRV - (MagicTune) -- C:\Windows\system32\drivers\MTiCtwl.sys (Samsung Electronics, Inc. )
DRV - (SCDEmu) -- C:\Windows\System32\drivers\scdemu.sys (PowerISO Computing, Inc.)
DRV - (L8042Kbd) -- C:\Windows\System32\drivers\L8042Kbd.sys (Logitech, Inc.)
DRV - (pccsmcfd) -- C:\Windows\System32\drivers\pccsmcfd.sys (Nokia)
DRV - (WDC_SAM) -- C:\Windows\System32\drivers\wdcsam.sys (Western Digital Technologies)
DRV - (dsiarhwprog) -- C:\Windows\System32\drivers\dsiarhwprog.sys (Thesycon GmbH, Germany)
DRV - (PD0620VID) -- C:\Windows\System32\drivers\P0620Vid.sys (Creative Technology Ltd.)
========== Standard Registry (All) ==========
========== Internet Explorer ==========
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = MSN.com
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Secondary_Page_URL = [binary data]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:NoAdd-ons
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\System32\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Bing
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:SecurityRisk
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://www.microsoft.com/isapi/redir.dll?prd={SUB_PRD}&clcid={SUB_CLSID}&pver={SUB_PVER}&ar=home
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,CustomizeSearch = http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\system32\blank.htm
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = Sign In
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = Hotmail, Messenger, Juegos, Videos, Musica, Horoscopos, Imagenes y Windows Live en MSN Latino
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {CFBFAE00-17A6-11D0-99CB-00C04FD64497} - C:\Windows\System32\ieframe.dll (Microsoft Corporation)
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = 192.168.*.*;*.local
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Bing"
FF - prefs.js..browser.search.defaulturl: "http://www.bing.com/search?FORM=WLETDF&PC=WLEM&q="
FF - prefs.js..browser.search.order.1: "Ask"
FF - prefs.js..browser.search.selectedEngine: "Google"
FF - prefs.js..browser.search.useDBForOrder: true
FF - prefs.js..browser.startup.homepage: "http://www.google.com/"
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}:6.0.18
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}:6.0.20
FF - prefs.js..extensions.enabledItems: [email protected]:4.0.21.0
FF - prefs.js..extensions.enabledItems: [email protected]:1.0.176.0
FF - prefs.js..extensions.enabledItems: [email protected]:1.5.3
FF - prefs.js..extensions.enabledItems: {0b38152b-1b20-484d-a11f-5e04a9b0661f}:5.6.11.2
FF - prefs.js..extensions.enabledItems: {20a82645-c095-46ed-80e3-08825760534b}:1.2.1
FF - prefs.js..extensions.enabledItems: {635abd67-4fe9-1b23-4f01-e679fa7484c1}:1.6.5.200812101546
FF - prefs.js..extensions.enabledItems: {BBDA0591-3099-440a-AA10-41764D9DB4DB}:2.0
FF - prefs.js..extensions.enabledItems: {2D3F3651-74B9-4795-BDEC-6DA2F431CB62}:4.6
FF - prefs.js..extensions.enabledItems: {972ce4c6-7e08-4474-a285-3208198ce6fd}:3.6.17
FF - prefs.js..keyword.URL: "http://www.bing.com/search?FORM=WLETDF&PC=WLEM&q="
FF - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\system32\Macromed\Flash\NPSWF32.dll ()
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=: File not found
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=1.0: C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll ()
FF - HKLM\Software\MozillaPlugins\@divx.com/DivX Browser Plugin,version=1.0.0: C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll (DivX, LLC)
FF - HKLM\Software\MozillaPlugins\@divx.com/DivX Player Plugin,version=1.0.0: C:\Program Files\DivX\DivX Player\npDivxPlayerPlugin.dll File not found
FF - HKLM\Software\MozillaPlugins\@divx.com/DivX VOD Helper,version=1.0.0: C:\Program Files\DivX\DivX OVS Helper\npovshelper.dll (DivX, LLC.)
FF - HKLM\Software\MozillaPlugins\@Google.com/GoogleEarthPlugin: C:\Program Files\Google\Google Earth\plugin\npgeplugin.dll (Google)
FF - HKLM\Software\MozillaPlugins\@java.com/JavaPlugin: C:\Program Files\Java\jre6\bin\new_plugin\npjp2.dll (Sun Microsystems, Inc.)
FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: C:\Program Files\Microsoft Silverlight\4.0.60531.0\npctrl.dll ( Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/OfficeAuthz,version=14.0: C:\PROGRA~1\MICROS~3\Office14\NPAUTHZ.DLL (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/SharePoint,version=14.0: C:\PROGRA~1\MICROS~3\Office14\NPSPWRAP.DLL (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3502.0922: C:\Program Files\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3508.1109: C:\Program Files\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WPF,version=3.5: c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@pack.google.com/Google Updater;version=13: C:\Program Files\Google\Google Updater\2.4.1536.6592\npCIDetect13.dll (Google)
FF - HKLM\Software\MozillaPlugins\@real.com/nppl3260;version=12.0.1.647: c:\program files\real\realplayer\Netscape6\nppl3260.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprjplug;version=12.0.1.647: c:\program files\real\realplayer\Netscape6\nprjplug.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprpchromebrowserrecordext;version=12.0.1.660: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprpchromebrowserrecordext.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprphtml5videoshim;version=12.0.1.660: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\MozillaPlugins\nprphtml5videoshim.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nprpjplug;version=12.0.1.660: c:\program files\real\realplayer\Netscape6\nprpjplug.dll (RealNetworks, Inc.)
FF - HKLM\Software\MozillaPlugins\@real.com/nsJSRealPlayerPlugin;version=: File not found
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=3: C:\Program Files\Google\Update\1.3.21.65\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\@tools.google.com/Google Update;version=9: C:\Program Files\Google\Update\1.3.21.65\npGoogleUpdate3.dll (Google Inc.)
FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files\Adobe\Reader 9.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
FF - HKCU\Software\MozillaPlugins\@tools.google.com/Google Update;version=3: C:\Users\Alexian\AppData\Local\Google\Update\1.3.21.65\npGoogleUpdate3.dll (Google Inc.)
FF - HKCU\Software\MozillaPlugins\@tools.google.com/Google Update;version=9: C:\Users\Alexian\AppData\Local\Google\Update\1.3.21.65\npGoogleUpdate3.dll (Google Inc.)
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{20a82645-c095-46ed-80e3-08825760534b}: c:\Windows\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\ [2009/06/26 04:13:27 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{BBDA0591-3099-440a-AA10-41764D9DB4DB}: C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\IPSFFPlgn\ [2011/07/22 19:06:26 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{2D3F3651-74B9-4795-BDEC-6DA2F431CB62}: C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\coFFPlgn_2011_7_0_8 [2011/07/31 09:28:56 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{ABDE892B-13A8-4d1b-88E6-365A6E755758}: C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\Firefox\Ext [2011/07/23 22:03:35 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{23fcfd51-4958-4f00-80a3-ae97e717ed8b}: C:\Program Files\DivX\DivX Plus Web Player\firefox\DivXHTML5 [2011/07/23 22:13:26 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 5.0\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2011/07/23 22:20:06 | 000,000,000 | ---D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 5.0\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2011/07/23 22:20:06 | 000,000,000 | ---D | M]
[2008/12/23 16:15:59 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Alexian\AppData\Roaming\Mozilla\Extensions
[2008/12/23 16:15:59 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Alexian\AppData\Roaming\Mozilla\Extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}
[2011/07/23 22:10:49 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\extensions
[2011/07/23 22:13:17 | 000,000,000 | ---D | M] ("Winamp Toolbar") -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\extensions\{0b38152b-1b20-484d-a11f-5e04a9b0661f}
[2011/06/30 21:19:01 | 000,000,000 | ---D | M] (Разпознаване на устройство Logitech) -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\extensions\[email protected]
[2008/12/26 19:58:49 | 000,000,682 | ---- | M] () -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\searchplugins\ask.xml
[2011/05/06 21:00:55 | 000,001,832 | ---- | M] () -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\searchplugins\bing.xml
[2011/07/29 20:22:31 | 000,001,018 | ---- | M] () -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\searchplugins\facebook.xml
[2010/03/21 11:16:13 | 000,010,017 | ---- | M] () -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\searchplugins\mywebsearch.xml
[2009/08/13 12:12:30 | 000,001,196 | ---- | M] () -- C:\Users\Alexian\AppData\Roaming\Mozilla\Firefox\Profiles\x471kzt3.default\searchplugins\winamp-search.xml
[2011/06/19 18:31:15 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
[2011/06/26 10:30:14 | 000,000,000 | ---D | M] (Default) -- C:\Program Files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
[2010/02/14 16:50:43 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
[2010/08/10 12:49:45 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
[2011/06/19 18:31:15 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA}
File not found (No name found) --
[2011/07/31 09:28:56 | 000,000,000 | ---D | M] (Norton Toolbar) -- C:\PROGRAMDATA\NORTON\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\COFFPLGN_2011_7_0_8
[2011/07/22 19:06:26 | 000,000,000 | ---D | M] (Symantec IPS) -- C:\PROGRAMDATA\NORTON\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_5.0.0.125\IPSFFPLGN
[2011/07/23 22:03:35 | 000,000,000 | ---D | M] (RealPlayer Browser Record Plugin) -- C:\PROGRAMDATA\REAL\REALPLAYER\BROWSERRECORDPLUGIN\FIREFOX\EXT
() (No name found) -- C:\USERS\ALEXIAN\APPDATA\ROAMING\MOZILLA\FIREFOX\PROFILES\X471KZT3.DEFAULT\EXTENSIONS\[email protected]
[2009/06/26 04:13:27 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\WINDOWS\MICROSOFT.NET\FRAMEWORK\V3.5\WINDOWS PRESENTATION FOUNDATION\DOTNETASSISTANTEXTENSION
[2011/06/26 10:30:13 | 000,142,296 | ---- | M] (Mozilla Foundation) -- C:\Program Files\mozilla firefox\components\browsercomps.dll
[2007/04/10 18:21:08 | 000,163,256 | ---- | M] (Microsoft Corporation) -- C:\Program Files\mozilla firefox\plugins\np-mswmp.dll
[2011/06/19 18:30:00 | 000,476,904 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\mozilla firefox\plugins\npdeployJava1.dll
[2008/11/21 16:45:26 | 000,098,304 | ---- | M] (DivX, Inc) -- C:\Program Files\mozilla firefox\plugins\npDivxPlayerPlugin.dll
[2009/07/07 16:20:42 | 000,061,440 | ---- | M] (AOL LLC) -- C:\Program Files\mozilla firefox\plugins\npdnu.dll
[2009/07/07 16:20:42 | 000,065,536 | ---- | M] (AOL LLC) -- C:\Program Files\mozilla firefox\plugins\npdnupdater2.dll
[2011/06/07 12:35:34 | 000,103,864 | ---- | M] (Adobe Systems Inc.) -- C:\Program Files\mozilla firefox\plugins\nppdf32.dll
[2011/07/23 22:03:24 | 000,150,712 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\mozilla firefox\plugins\nppl3260.dll
[2011/07/23 22:20:05 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin2.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin3.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin4.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin5.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin6.dll
[2011/07/23 22:20:06 | 000,159,744 | ---- | M] (Apple Inc.) -- C:\Program Files\mozilla firefox\plugins\npqtplugin7.dll
[2011/07/23 22:03:58 | 000,011,776 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\mozilla firefox\plugins\nprjplug.dll
[2011/07/23 22:03:14 | 000,105,472 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\mozilla firefox\plugins\nprpjplug.dll
[2011/07/11 16:48:12 | 000,012,800 | ---- | M] (Nullsoft, Inc.) -- C:\Program Files\mozilla firefox\plugins\npwachk.dll
[2011/05/11 20:41:19 | 000,001,394 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\amazondotcom.xml
[2011/03/23 15:45:48 | 000,002,193 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\answers.xml
[2011/05/11 20:41:19 | 000,002,252 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\bing.xml
[2011/03/23 15:45:48 | 000,001,534 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\creativecommons.xml
[2011/05/11 20:41:19 | 000,001,131 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\eBay.xml
[2011/05/11 20:41:19 | 000,002,364 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\google.xml
[2011/05/11 20:41:19 | 000,001,178 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\wikipedia.xml
[2011/05/11 20:41:19 | 000,001,096 | ---- | M] () -- C:\Program Files\mozilla firefox\searchplugins\yahoo.xml
O1 HOSTS File: ([2011/07/23 18:55:24 | 000,000,027 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
O1 - Hosts: 127.0.0.1 localhost
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
O2 - BHO: (Winamp Toolbar Loader) - {25CEE8EC-5730-41bc-8B58-22DDC8AB8C20} - C:\Program Files\Winamp Toolbar\winamptb.dll (AOL Inc.)
O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\Real\RealPlayer\BrowserRecordPlugin\IE\rpbrowserrecordplugin.dll (RealPlayer)
O2 - BHO: (DivX Plus Web Player HTML5 <video>) - {326E768D-4182-46FD-9C16-1449A49795F4} - C:\Program Files\DivX\DivX Plus Web Player\ie\DivXHTML5\DivXHTML5.dll (DivX, LLC)
O2 - BHO: (Spybot-S&D IE Protection) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O2 - BHO: (Symantec NCO BHO) - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\coieplg.dll (Symantec Corporation)
O2 - BHO: (Symantec Intrusion Prevention) - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\ips\ipsbho.dll (Symantec Corporation)
O2 - BHO: (Windows Live ID Sign-in Helper) - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\microsoft shared\Windows Live\WindowsLiveLogin.dll (Microsoft Corp.)
O2 - BHO: (Windows Live Messenger Companion Helper) - {9FDDE16B-836F-4806-AB1F-1455CBEFF289} - C:\Program Files\Windows Live\Companion\companioncore.dll (Microsoft Corporation)
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.5612.1312\swg.dll (Google Inc.)
O2 - BHO: (Office Document Cache Handler) - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\Program Files\Microsoft Office\Office14\URLREDIR.DLL (Microsoft Corporation)
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O3 - HKLM\..\Toolbar: (Google Toolbar) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O3 - HKLM\..\Toolbar: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\coieplg.dll (Symantec Corporation)
O3 - HKLM\..\Toolbar: (Winamp Toolbar) - {EBF2BA02-9094-4c5a-858B-BB198F3D8DE2} - C:\Program Files\Winamp Toolbar\winamptb.dll (AOL Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Google Toolbar) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Norton Security Suite\Engine\5.1.0.29\coieplg.dll (Symantec Corporation)
O4 - HKLM..\Run: [DivXUpdate] C:\Program Files\DivX\DivX Update\DivXUpdate.exe ()
O4 - HKLM..\Run: [EvtMgr6] C:\Program Files\Logitech\SetPointP\SetPoint.exe (Logitech, Inc.)
O4 - HKLM..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe (Apple Inc.)
O4 - HKLM..\Run: [QuickTime Task] C:\Program Files\QuickTime\QTTask.exe (Apple Inc.)
O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Real\RealPlayer\update\realsched.exe (RealNetworks, Inc.)
O4 - HKCU..\Run: [ehTray.exe] C:\Windows\ehome\ehtray.exe (Microsoft Corporation)
O4 - HKCU..\Run: [Google Update] C:\Users\Alexian\AppData\Local\Google\Update\GoogleUpdate.exe (Google Inc.)
O4 - HKCU..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe (Safer-Networking Ltd.)
O4 - HKCU..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
O4 - HKCU..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\wmpnscfg.exe (Microsoft Corporation)
O4 - Startup: C:\Users\Alexian\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\CurseClientStartup.ccip ()
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: BindDirectlyToPropertySetStorage = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableInstallerDetection = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableSecureUIAPaths = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableVirtualization = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: PromptOnSecureDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ValidateAdminCodeSignatures = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: dontdisplaylastusername = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: scforceoption = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: shutdownwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: undockwithoutlogon = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: FilterAdministratorToken = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableUIADesktopToggle = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticecaption =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: legalnoticetext =
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableRegistryTools = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLUA = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_TEXT = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_BITMAP = 2
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_OEMTEXT = 7
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIB = 8
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_PALETTE = 9
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_UNICODETEXT = 13
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\UIPI\Clipboard\ExceptionFormats: CF_DIBV5 = 17
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: disableregistrytools = 0
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files\Microsoft Office\Office14\EXCEL.EXE (Microsoft Corporation)
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_60D6097707281E79.dll (Google Inc.)
O8 - Extra context menu item: Se&nd to OneNote - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: @C:\Program Files\Windows Live\Companion\companionlang.dll,-600 - {0000036B-C524-4050-81A0-243669A86B9F} - C:\Program Files\Windows Live\Companion\companioncore.dll (Microsoft Corporation)
O9 - Extra Button: @C:\Program Files\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1004 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : @C:\Program Files\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1003 - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000001 [] - C:\Windows\System32\nlaapi.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000002 [] - C:\Windows\System32\NapiNSP.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000003 [] - C:\Windows\System32\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\Windows\System32\pnrpnsp.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000005 [] - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000006 [] - C:\Windows\System32\winrnr.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
O10 - Protocol_Catalog9\Catalog_Entries\000000000001 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000002 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000003 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000004 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000005 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000006 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000007 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000008 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000009 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000010 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000011 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000012 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000013 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000014 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000015 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000016 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000017 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O10 - Protocol_Catalog9\Catalog_Entries\000000000018 - C:\Windows\System32\mswsock.dll (Microsoft Corporation)
O15 - HKCU\..Trusted Domains: clonewarsadventures.com ([]* in Trusted sites)
O15 - HKCU\..Trusted Domains: freerealms.com ([]* in Trusted sites)
O15 - HKCU\..Trusted Domains: localhost ([]http in Local intranet)
O15 - HKCU\..Trusted Domains: soe.com ([]* in Trusted sites)
O15 - HKCU\..Trusted Domains: sony.com ([]* in Trusted sites)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get/flashplayer/current/polarbear/ultrashim.cab (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_26-windows-i586.cab (Java Plug-in 1.6.0_26)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
O18 - Protocol\Handler\about {3050F406-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\System32\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\belarc {6318E0AB-2E93-11D1-B8ED-00608CC9A71F} - C:\Program Files\Belarc\Advisor\System\BAVoilaX.dll (Belarc, Inc.)
O18 - Protocol\Handler\cdl {3dd53d40-7b8b-11D0-b013-00aa0059ce02} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\dvd {12D51199-0DB5-46FE-A120-47A3D7D937CC} - C:\Windows\System32\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\file {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\ftp {79eac9e3-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\http {79eac9e2-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\http\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\http\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\https {79eac9e5-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\https\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\https\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\ipp - No CLSID value found
O18 - Protocol\Handler\ipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\System32\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\javascript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\System32\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\livecall {828030A1-22C1-4009-854F-8E305202313F} - C:\Program Files\Windows Live\Messenger\msgrapp.dll (Microsoft Corporation)
O18 - Protocol\Handler\local {79eac9e7-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\mailto {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\System32\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\mhtml {05300401-BCBC-11d0-85E3-00C04FD85AB4} - C:\Windows\System32\inetcomm.dll (Microsoft Corporation)
O18 - Protocol\Handler\mk {79eac9e6-baf9-11ce-8c82-00aa004ba90b} - C:\Windows\System32\urlmon.dll (Microsoft Corporation)
O18 - Protocol\Handler\msdaipp - No CLSID value found
O18 - Protocol\Handler\msdaipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\msdaipp\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\microsoft shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-its {9D148291-B9C8-11D0-A4CC-0000F80149F6} - C:\Windows\System32\itss.dll (Microsoft Corporation)
O18 - Protocol\Handler\msnim {828030A1-22C1-4009-854F-8E305202313F} - C:\Program Files\Windows Live\Messenger\msgrapp.dll (Microsoft Corporation)
O18 - Protocol\Handler\res {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\System32\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\tv {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} - C:\Windows\System32\MSVidCtl.dll (Microsoft Corporation)
O18 - Protocol\Handler\vbscript {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} - C:\Windows\System32\mshtml.dll (Microsoft Corporation)
O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
O18 - Protocol\Handler\wlpg {E43EF6CD-A37A-4A9B-9E6F-83F89B8E6324} - C:\Program Files\Windows Live\Photo Gallery\AlbumDownloadProtocolHandler.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/octet-stream {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\System32\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-complus {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\System32\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\application/x-msdownload {1E66F26B-79EE-11D2-8710-00C04F79ED0D} - C:\Windows\System32\mscoree.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807573E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\microsoft shared\OFFICE14\MSOXMLMF.DLL (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\System32\userinit.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (rundll32 shell32) - C:\Windows\System32\shell32.dll (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (Control_RunDLL "sysdm.cpl") - C:\Windows\System32\sysdm.cpl (Microsoft Corporation)
O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL (SUPERAntiSpyware.com)
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - C:\Windows\System32\webcheck.dll (Microsoft Corporation)
O22 - SharedTaskScheduler: {8C7461EF-2B13-11d2-BE35-3078302C2030} - Component Categories cache daemon - C:\Windows\System32\browseui.dll (Microsoft Corporation)
O24 - Desktop Components:0 (My Current Home Page) - About:Home
O24 - Desktop WallPaper: C:\Users\Alexian\my pictures\fotos de memorias!!\nuestras fotos recuerdos\DSCF0273.JPG
O24 - Desktop BackupWallPaper: C:\Users\Alexian\my pictures\fotos de memorias!!\nuestras fotos recuerdos\DSCF0273.JPG
O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
O29 - HKLM SecurityProviders - (credssp.dll) - C:\Windows\System32\credssp.dll (Microsoft Corporation)
O30 - LSA: Authentication Packages - (msv1_0) - C:\Windows\System32\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (kerberos) - C:\Windows\System32\kerberos.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (msv1_0) - C:\Windows\System32\msv1_0.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (schannel) - C:\Windows\System32\schannel.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (wdigest) - C:\Windows\System32\wdigest.dll (Microsoft Corporation)
O30 - LSA: Security Packages - (tspkg) - C:\Windows\System32\tspkg.dll (Microsoft Corporation)
O31 - SafeBoot: AlternateShell - cmd.exe
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2011/01/19 21:29:42 | 000,000,000 | ---D | M] - C:\Autodesk -- [ NTFS ]
O32 - AutoRun File - [2006/09/18 16:43:36 | 000,000,024 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O34 - HKLM BootExecute: (autocheck autochk *) - File not found
O34 - HKLM BootExecute: (lsdelete) - C:\Windows\System32\lsdelete.exe ()
O35 - HKLM\..comfile [open] -- "%1" %*
O35 - HKLM\..exefile [open] -- "%1" %*
O37 - HKLM\...com [@ = comfile] -- "%1" %*
O37 - HKLM\...exe [@ = exefile] -- "%1" %*
O37 - HKCU\...exe [@ = exefile] -- Reg Error: Key error. File not found
========== Files/Folders - Created Within 30 Days ==========
[2011/07/31 09:39:41 | 000,579,584 | ---- | C] (OldTimer Tools) -- C:\Users\Alexian\Desktop\OTL.exe
[2011/07/28 19:31:02 | 000,000,000 | ---D | C] -- C:\ProgramData\UAB
[2011/07/28 19:30:59 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\PC_Drivers_Headquarters
[2011/07/28 19:30:53 | 000,000,000 | ---D | C] -- C:\ProgramData\PC Drivers HeadQuarters
[2011/07/28 19:29:36 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Driver Detective
[2011/07/28 19:29:34 | 000,000,000 | ---D | C] -- C:\Program Files\PC Drivers HeadQuarters
[2011/07/25 19:19:46 | 000,000,000 | -HSD | C] -- C:\$RECYCLE.BIN
[2011/07/25 19:19:43 | 000,000,000 | ---D | C] -- C:\Windows\temp
[2011/07/25 19:19:43 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\temp
[2011/07/24 20:17:00 | 000,000,000 | ---D | C] -- C:\Windows\Sun
[2011/07/24 16:13:03 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Motorola
[2011/07/23 22:31:25 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
[2011/07/23 22:30:54 | 000,000,000 | ---D | C] -- C:\Program Files\iPod
[2011/07/23 22:30:53 | 000,000,000 | ---D | C] -- C:\Program Files\iTunes
[2011/07/23 22:28:48 | 000,000,000 | ---D | C] -- C:\Program Files\Apple Software Update
[2011/07/23 22:25:53 | 000,000,000 | ---D | C] -- C:\Program Files\Bonjour
[2011/07/23 22:21:42 | 000,404,640 | ---- | C] (Adobe Systems Incorporated) -- C:\Windows\System32\FlashPlayerCPLApp.cpl
[2011/07/23 22:19:42 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime
[2011/07/23 22:19:24 | 000,000,000 | ---D | C] -- C:\Program Files\QuickTime
[2011/07/23 22:12:23 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DivX Plus
[2011/07/23 22:12:14 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\DivX Shared
[2011/07/23 22:11:19 | 000,000,000 | ---D | C] -- C:\ProgramData\DivX
[2011/07/23 22:10:34 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Software Update Utility
[2011/07/23 22:07:32 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TweakUAC
[2011/07/23 22:07:32 | 000,000,000 | ---D | C] -- C:\Program Files\TweakUAC
[2011/07/23 22:03:38 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\xing shared
[2011/07/23 22:03:24 | 000,198,848 | ---- | C] (RealNetworks, Inc.) -- C:\Windows\System32\rmoc3260.dll
[2011/07/23 22:03:12 | 000,006,656 | ---- | C] (RealNetworks, Inc.) -- C:\Windows\System32\pndx5016.dll
[2011/07/23 22:03:12 | 000,005,632 | ---- | C] (RealNetworks, Inc.) -- C:\Windows\System32\pndx5032.dll
[2011/07/23 22:03:10 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Real
[2011/07/23 22:02:31 | 000,000,000 | ---D | C] -- C:\ProgramData\Real
[2011/07/23 21:59:25 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ImgBurn
[2011/07/23 21:56:57 | 000,000,000 | ---D | C] -- C:\Windows\IrfanView
[2011/07/23 21:30:04 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\Secunia PSI
[2011/07/23 21:29:18 | 000,000,000 | ---D | C] -- C:\Program Files\Secunia
[2011/07/23 20:52:02 | 000,000,000 | ---D | C] -- C:\Users\Alexian\Desktop\TreeSize
[2011/07/23 19:36:19 | 000,607,017 | R--- | C] (Swearware) -- C:\Users\Alexian\Desktop\dds.com
[2011/07/23 18:28:01 | 000,000,000 | ---D | C] -- C:\rsit
[2011/07/23 17:33:28 | 002,557,544 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvsvc.dll
[2011/07/23 17:33:28 | 000,066,664 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvshext.dll
[2011/07/23 17:33:27 | 003,693,672 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvcpl.dll
[2011/07/23 17:33:27 | 000,111,208 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvmctray.dll
[2011/07/23 17:33:26 | 000,543,336 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\easyupdatusapiu.dll
[2011/07/23 17:29:45 | 000,057,960 | ---- | C] (Khronos Group) -- C:\Windows\System32\OpenCL.dll
[2011/07/23 17:29:44 | 016,456,296 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvoglv32.dll
[2011/07/23 17:29:44 | 006,555,240 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvwgf2um.dll
[2011/07/23 17:29:43 | 010,589,800 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\drivers\nvlddmkm.sys
[2011/07/23 17:29:43 | 000,899,688 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvdispco3220150.dll
[2011/07/23 17:29:43 | 000,865,896 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvgenco322090.dll
[2011/07/23 17:29:42 | 013,011,560 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvcompiler.dll
[2011/07/23 17:29:42 | 005,301,352 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvcuda.dll
[2011/07/23 17:29:42 | 002,804,328 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvcuvid.dll
[2011/07/23 17:29:42 | 002,082,408 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\nvcuvenc.dll
[2011/07/23 17:29:42 | 000,012,392 | ---- | C] (NVIDIA Corporation) -- C:\Windows\System32\drivers\nvBridge.kmd
[2011/07/23 15:13:13 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{0188C5D8-8B9E-45B7-90FE-273E19C667E6}
[2011/07/22 22:15:49 | 000,000,000 | ---D | C] -- C:\Users\Alexian\Documents\Windows_NT6_BSOD_jcgriff2
[2011/07/22 21:26:23 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{67126483-7049-4E3E-9283-B0122DC2EBB9}
[2011/07/22 20:49:38 | 000,000,000 | ---D | C] -- C:\Users\Alexian\Desktop\New Folder
[2011/07/22 20:09:59 | 000,023,456 | ---- | C] (Phoenix Technologies) -- C:\Windows\System32\drivers\DrvAgent32.sys
[2011/07/22 19:54:58 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{1BDDFFF1-16B1-4224-B449-3BF34EC576DA}
[2011/07/22 19:24:34 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{A1B4BA19-4761-4105-A56A-28E94FC6CCEC}
[2011/07/21 20:57:07 | 000,000,000 | ---D | C] -- C:\ProgramData\Kaspersky Lab
[2011/07/21 19:56:37 | 000,016,400 | ---- | C] (Logitech, Inc.) -- C:\Windows\System32\drivers\LNonPnP.sys
[2011/07/21 19:55:08 | 000,000,000 | ---D | C] -- C:\Users\Public\Documents\LogiShrd
[2011/07/21 19:54:36 | 000,000,000 | ---D | C] -- C:\ProgramData\Logishrd
[2011/07/21 19:50:26 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{521957A2-2568-4F7D-855B-BAF38F627214}
[2011/07/21 19:41:02 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Roaming\Logishrd
[2011/07/20 17:03:48 | 000,000,000 | ---D | C] -- C:\Users\Alexian\SystemRequirementsLab
[2011/07/20 16:59:23 | 000,064,512 | ---- | C] (Lavasoft AB) -- C:\Windows\System32\drivers\Lbd.sys
[2011/07/20 16:59:16 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lavasoft
[2011/07/20 10:34:25 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{464A120F-3F3B-451E-9475-4AD4F3375AF8}
[2011/07/19 17:28:30 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{89CE0CE7-3D49-42C3-B423-89F86B2545BE}
[2011/07/18 23:22:37 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{D2EA7E58-C0AF-4FE2-B65A-88C63FD082EC}
[2011/07/16 17:35:00 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
[2011/07/16 17:34:56 | 000,000,000 | ---D | C] -- C:\Program Files\CCleaner
[2011/07/16 12:34:34 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{3A0630D2-3B5A-45A7-A03D-50590BAF93A3}
[2011/07/13 22:04:40 | 000,000,000 | ---D | C] -- C:\Program Files\Tactile Pictures
[2011/07/13 22:04:31 | 000,303,616 | ---- | C] (InstallShield Software Corporation) -- C:\Windows\IsUninst.exe
[2011/07/13 09:54:25 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{FECB1D2A-02FF-4230-B8B6-7CB1BBCD8EFD}
[2011/07/12 22:18:50 | 002,043,392 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\win32k.sys
[2011/07/12 22:18:45 | 000,375,808 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\winsrv.dll
[2011/07/12 22:18:45 | 000,049,152 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\csrsrv.dll
[2011/07/12 11:20:54 | 000,178,536 | ---- | C] (Apple Inc.) -- C:\Windows\System32\dnssdX.dll
[2011/07/12 11:20:54 | 000,083,816 | ---- | C] (Apple Inc.) -- C:\Windows\System32\dns-sd.exe
[2011/07/12 11:20:54 | 000,073,064 | ---- | C] (Apple Inc.) -- C:\Windows\System32\dnssd.dll
[2011/07/12 11:20:54 | 000,050,536 | ---- | C] (Apple Inc.) -- C:\Windows\System32\jdns_sd.dll
[2011/07/11 23:18:03 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{CACA7075-A23E-4C67-AA16-218B642BFD61}
[2011/07/11 17:43:41 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\EVEMon
[2011/07/10 22:53:49 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{6EDF2635-EBCC-4B6C-99EA-A411E169C315}
[2011/07/08 15:48:59 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{AD3A41E8-D933-4261-9179-EEAE7BE59EBE}
[2011/07/06 13:33:36 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Local\{B469ADB1-ABF2-4CB2-B23E-C25192BA63A5}
[2011/07/05 10:31:23 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Curse
[2011/07/02 19:51:03 | 000,000,000 | ---D | C] -- C:\Users\Alexian\AppData\Roaming\EVEMon
[2011/07/02 19:48:36 | 000,000,000 | ---D | C] -- C:\Program Files\EVEMon
[3 C:\Windows\*.tmp files -> C:\Windows\*.tmp -> ]
========== Files - Modified Within 30 Days ==========
[2011/07/31 09:39:42 | 000,579,584 | ---- | M] (OldTimer Tools) -- C:\Users\Alexian\Desktop\OTL.exe
[2011/07/31 09:31:31 | 000,000,868 | ---- | M] () -- C:\Windows\tasks\Google Software Updater.job
[2011/07/31 09:28:18 | 000,000,882 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2011/07/31 09:28:12 | 000,002,400 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2011/07/31 09:28:12 | 000,002,400 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2011/07/31 09:28:06 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2011/07/31 09:18:00 | 000,000,886 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2011/07/31 08:47:00 | 000,001,054 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-1202660629-299502267-839522115-1004UA.job
[2011/07/31 00:47:00 | 000,001,002 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-1202660629-299502267-839522115-1004Core.job
[2011/07/30 17:09:49 | 000,000,064 | ---- | M] () -- C:\Windows\System32\rp_stats.dat
[2011/07/30 17:09:49 | 000,000,044 | ---- | M] () -- C:\Windows\System32\rp_rules.dat
[2011/07/30 13:50:42 | 005,766,868 | ---- | M] () -- C:\Windows\System32\perfh009.dat
[2011/07/30 13:50:41 | 001,905,860 | ---- | M] () -- C:\Windows\System32\perfc009.dat
[2011/07/28 19:29:41 | 000,002,335 | ---- | M] () -- C:\Users\Public\Desktop\Driver Detective.lnk
[2011/07/27 17:19:29 | 000,000,612 | RHS- | M] () -- C:\ProgramData\ntuser.pol
[2011/07/25 18:29:05 | 000,000,136 | ---- | M] () -- C:\Users\Alexian\webct_upload_applet.properties
[2011/07/24 16:19:04 | 002,357,952 | ---- | M] () -- C:\Windows\System32\drivers\N360\0501000.01D\Cat.DB
[2011/07/23 22:22:06 | 000,404,640 | ---- | M] (Adobe Systems Incorporated) -- C:\Windows\System32\FlashPlayerCPLApp.cpl
[2011/07/23 22:10:51 | 000,000,773 | ---- | M] () -- C:\Users\Public\Desktop\Winamp.lnk
[2011/07/23 22:07:32 | 000,000,749 | ---- | M] () -- C:\Users\Public\Desktop\TweakUAC.lnk
[2011/07/23 22:03:51 | 000,000,847 | ---- | M] () -- C:\Users\Public\Desktop\RealPlayer.lnk
[2011/07/23 22:03:24 | 000,198,848 | ---- | M] (RealNetworks, Inc.) -- C:\Windows\System32\rmoc3260.dll
[2011/07/23 22:03:12 | 000,006,656 | ---- | M] (RealNetworks, Inc.) -- C:\Windows\System32\pndx5016.dll
[2011/07/23 22:03:12 | 000,005,632 | ---- | M] (RealNetworks, Inc.) -- C:\Windows\System32\pndx5032.dll
[2011/07/23 22:03:10 | 000,272,896 | ---- | M] (Progressive Networks) -- C:\Windows\System32\pncrt.dll
[2011/07/23 21:59:26 | 000,001,647 | ---- | M] () -- C:\Users\Public\Desktop\ImgBurn.lnk
[2011/07/23 21:35:53 | 000,000,310 | ---- | M] () -- C:\Users\Alexian\Desktop\Turn_UAC_On.reg
[2011/07/23 21:29:29 | 000,000,896 | ---- | M] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Secunia PSI Tray.lnk
[2011/07/23 19:53:17 | 000,005,783 | ---- | M] () -- C:\Users\Alexian\Desktop\Attach.zip
[2011/07/23 19:41:27 | 000,302,592 | ---- | M] () -- C:\Users\Alexian\Desktop\gmer.exe
[2011/07/23 19:36:20 | 000,607,017 | R--- | M] (Swearware) -- C:\Users\Alexian\Desktop\dds.com
[2011/07/23 18:55:24 | 000,000,027 | ---- | M] () -- C:\Windows\System32\drivers\etc\hosts
[2011/07/22 22:19:57 | 002,866,904 | ---- | M] () -- C:\Users\Alexian\Desktop\performance.html
[2011/07/22 21:03:43 | 000,016,400 | ---- | M] (Logitech, Inc.) -- C:\Windows\System32\drivers\LNonPnP.sys
[2011/07/22 20:10:00 | 000,000,933 | ---- | M] () -- C:\Users\Alexian\Desktop\BiosAgent Plus.lnk
[2011/07/22 20:09:59 | 000,023,456 | ---- | M] (Phoenix Technologies) -- C:\Windows\System32\drivers\DrvAgent32.sys
[2011/07/21 20:31:49 | 000,319,456 | ---- | M] (Microsoft Corporation) -- C:\Windows\DIFxAPI.dll
[2011/07/21 16:53:35 | 000,002,298 | ---- | M] () -- C:\Users\Public\Desktop\Norton Security Suite.lnk
[2011/07/20 18:55:27 | 000,126,584 | ---- | M] (Symantec Corporation) -- C:\Windows\System32\drivers\SYMEVENT.SYS
[2011/07/20 18:55:27 | 000,007,468 | ---- | M] () -- C:\Windows\System32\drivers\SYMEVENT.CAT
[2011/07/20 18:55:27 | 000,000,806 | ---- | M] () -- C:\Windows\System32\drivers\SYMEVENT.INF
[2011/07/20 17:04:16 | 000,016,432 | ---- | M] () -- C:\Windows\System32\lsdelete.exe
[2011/07/20 16:59:31 | 000,000,974 | ---- | M] () -- C:\Users\Public\Desktop\Ad-Aware.lnk
[2011/07/20 10:44:43 | 000,001,940 | ---- | M] () -- C:\Users\Alexian\AppData\Local\{96C87F53-AC72-4604-A9CC-186A49F17F3C}.ini
[2011/07/18 12:30:58 | 004,835,338 | ---- | M] () -- C:\Users\Alexian\Documents\Mega-Man and Bass.zip
[2011/07/17 20:57:42 | 000,591,110 | ---- | M] () -- C:\Users\Alexian\Documents\Duncan_Alexian_2.rtf
[2011/07/16 17:38:17 | 000,202,742 | ---- | M] () -- C:\Users\Alexian\Documents\cc_20110716_173804.reg
[2011/07/16 17:35:00 | 000,000,841 | ---- | M] () -- C:\Users\Public\Desktop\CCleaner.lnk
[2011/07/15 19:48:05 | 000,044,593 | ---- | M] () -- C:\Users\Alexian\Desktop\Roxana resumen.rtf
[2011/07/15 01:41:52 | 000,002,089 | ---- | M] () -- C:\Users\Alexian\Desktop\Google Chrome.lnk
[2011/07/13 22:04:41 | 000,000,849 | ---- | M] () -- C:\Users\Public\Desktop\Tactile12000.lnk
[2011/07/13 03:25:49 | 000,379,872 | ---- | M] () -- C:\Windows\System32\FNTCACHE.DAT
[2011/07/12 11:20:54 | 000,178,536 | ---- | M] (Apple Inc.) -- C:\Windows\System32\dnssdX.dll
[2011/07/12 11:20:54 | 000,083,816 | ---- | M] (Apple Inc.) -- C:\Windows\System32\dns-sd.exe
[2011/07/12 11:20:54 | 000,073,064 | ---- | M] (Apple Inc.) -- C:\Windows\System32\dnssd.dll
[2011/07/12 11:20:54 | 000,050,536 | ---- | M] (Apple Inc.) -- C:\Windows\System32\jdns_sd.dll
[2011/07/11 17:43:38 | 000,041,684 | ---- | M] () -- C:\Users\Alexian\Documents\EVEMon_Settings_2798.xml.bak
[2011/07/11 14:17:00 | 001,698,408 | ---- | M] (Realtek Semiconductor Corp.) -- C:\Windows\RtlExUpd.dll
[2011/07/05 10:31:23 | 000,000,312 | ---- | M] () -- C:\Users\Alexian\Desktop\Curse Client.appref-ms
[2011/07/03 14:55:27 | 000,205,200 | ---- | M] () -- C:\Users\Alexian\Documents\Duncan_Alexian_1.rtf
[2011/07/01 15:47:54 | 000,101,720 | ---- | M] (Sunbelt Software) -- C:\Windows\System32\drivers\SBREDrv.sys
========== Files Created - No Company Name ==========
[2011/07/28 19:29:40 | 000,002,335 | ---- | C] () -- C:\Users\Public\Desktop\Driver Detective.lnk
[2011/07/23 22:07:32 | 000,000,749 | ---- | C] () -- C:\Users\Public\Desktop\TweakUAC.lnk
[2011/07/23 22:03:51 | 000,000,847 | ---- | C] () -- C:\Users\Public\Desktop\RealPlayer.lnk
[2011/07/23 21:59:24 | 000,001,659 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ImgBurn.lnk
[2011/07/23 21:35:40 | 000,000,310 | ---- | C] () -- C:\Users\Alexian\Desktop\Turn_UAC_On.reg
[2011/07/23 21:29:28 | 000,000,896 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Secunia PSI Tray.lnk
[2011/07/23 21:29:27 | 000,000,859 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Secunia PSI.lnk
[2011/07/23 19:53:17 | 000,005,783 | ---- | C] () -- C:\Users\Alexian\Desktop\Attach.zip
[2011/07/22 22:22:22 | 002,866,904 | ---- | C] () -- C:\Users\Alexian\Desktop\performance.html
[2011/07/22 20:09:59 | 000,000,933 | ---- | C] () -- C:\Users\Alexian\Desktop\BiosAgent Plus.lnk
[2011/07/21 02:16:53 | 000,016,432 | ---- | C] () -- C:\Windows\System32\lsdelete.exe
[2011/07/20 16:59:31 | 000,000,974 | ---- | C] () -- C:\Users\Public\Desktop\Ad-Aware.lnk
[2011/07/18 12:31:19 | 004,835,338 | ---- | C] () -- C:\Users\Alexian\Documents\Mega-Man and Bass.zip
[2011/07/17 20:57:41 | 000,591,110 | ---- | C] () -- C:\Users\Alexian\Documents\Duncan_Alexian_2.rtf
[2011/07/16 22:21:04 | 000,302,592 | ---- | C] () -- C:\Users\Alexian\Desktop\gmer.exe
[2011/07/16 17:38:10 | 000,202,742 | ---- | C] () -- C:\Users\Alexian\Documents\cc_20110716_173804.reg
[2011/07/16 17:34:59 | 000,000,841 | ---- | C] () -- C:\Users\Public\Desktop\CCleaner.lnk
[2011/07/13 22:04:41 | 000,000,849 | ---- | C] () -- C:\Users\Public\Desktop\Tactile12000.lnk
[2011/07/13 22:04:40 | 000,000,861 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tactile12000.lnk
[2011/07/11 17:44:38 | 000,041,684 | ---- | C] () -- C:\Users\Alexian\Documents\EVEMon_Settings_2798.xml.bak
[2011/07/03 14:55:26 | 000,205,200 | ---- | C] () -- C:\Users\Alexian\Documents\Duncan_Alexian_1.rtf
[2011/05/21 15:09:18 | 000,000,262 | ---- | C] () -- C:\Windows\{789289CA-F73A-4A16-A331-54D498CE069F}_WiseFW.ini
[2011/05/20 22:35:28 | 000,304,744 | ---- | C] () -- C:\Windows\System32\nvStreaming.exe
[2011/05/12 14:19:05 | 000,001,940 | ---- | C] () -- C:\Users\Alexian\AppData\Local\{96C87F53-AC72-4604-A9CC-186A49F17F3C}.ini
[2011/05/06 15:48:42 | 000,000,064 | ---- | C] () -- C:\Windows\System32\rp_stats.dat
[2011/05/06 15:48:42 | 000,000,044 | ---- | C] () -- C:\Windows\System32\rp_rules.dat
[2011/04/01 05:07:02 | 010,877,272 | ---- | C] () -- C:\Windows\System32\LogiDPP.dll
[2011/04/01 05:07:02 | 000,102,744 | ---- | C] () -- C:\Windows\System32\LogiDPPApp.exe
[2011/04/01 05:06:56 | 000,331,608 | ---- | C] () -- C:\Windows\System32\DevManagerCore.dll
[2011/04/01 04:56:00 | 000,027,872 | ---- | C] () -- C:\Windows\System32\lvcoinst.ini
[2011/03/22 23:58:22 | 000,014,168 | ---- | C] () -- C:\Windows\System32\drivers\iKeyLFT2.dll
[2010/06/07 22:31:00 | 000,000,760 | ---- | C] () -- C:\Users\Alexian\AppData\Roaming\setup_ldm.iss
[2009/08/03 15:07:42 | 000,403,816 | ---- | C] () -- C:\Windows\System32\OGACheckControl.dll
[2009/08/03 15:07:42 | 000,230,768 | ---- | C] () -- C:\Windows\System32\OGAEXEC.exe
[2009/07/26 00:25:39 | 000,139,152 | ---- | C] () -- C:\Users\Alexian\AppData\Roaming\PnkBstrK.sys
[2009/07/26 00:25:39 | 000,139,016 | ---- | C] () -- C:\Windows\System32\drivers\PnkBstrK.sys
[2009/07/26 00:25:25 | 000,189,488 | ---- | C] () -- C:\Windows\System32\PnkBstrB.exe
[2009/07/26 00:25:21 | 000,075,064 | ---- | C] () -- C:\Windows\System32\PnkBstrA.exe
[2009/07/26 00:25:20 | 000,794,408 | ---- | C] () -- C:\Windows\System32\pbsvc.exe
[2009/07/17 11:04:32 | 000,000,095 | ---- | C] () -- C:\Users\Alexian\AppData\Local\fusioncache.dat
[2009/07/07 04:43:03 | 000,032,061 | ---- | C] () -- C:\ProgramData\nvModes.001
[2009/06/27 14:20:57 | 000,032,061 | ---- | C] () -- C:\ProgramData\nvModes.dat
[2009/06/26 04:27:23 | 000,117,248 | ---- | C] () -- C:\Windows\System32\EhStorAuthn.dll
[2009/06/26 04:27:23 | 000,107,612 | ---- | C] () -- C:\Windows\System32\StructuredQuerySchema.bin
[2009/06/26 04:26:31 | 000,062,976 | ---- | C] () -- C:\Windows\System32\PrintBrmUi.exe
[2009/05/25 21:21:20 | 000,000,076 | ---- | C] () -- C:\Windows\QUICKEN.INI
[2009/05/10 20:42:48 | 000,000,069 | ---- | C] () -- C:\Windows\NeroDigital.ini
[2009/01/11 05:12:30 | 000,941,568 | ---- | C] () -- C:\Windows\System32\msvcx86.dll
[2008/12/24 03:26:44 | 000,046,592 | ---- | C] () -- C:\Users\Alexian\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2008/12/23 14:51:55 | 000,018,904 | ---- | C] () -- C:\Windows\System32\StructuredQuerySchemaTrivial.bin
[2008/12/23 13:17:04 | 000,002,032 | ---- | C] () -- C:\Users\Alexian\AppData\Local\d3d9caps.dat
[2008/12/23 13:12:41 | 000,022,172 | ---- | C] () -- C:\Windows\System32\emptyregdb.dat
[2008/12/23 06:22:30 | 000,004,161 | ---- | C] () -- C:\Windows\ODBCINST.INI
[2008/12/21 03:16:06 | 000,000,612 | RHS- | C] () -- C:\ProgramData\ntuser.pol
[2008/11/21 16:47:52 | 003,596,288 | ---- | C] () -- C:\Windows\System32\qt-dx331.dll
[2008/01/20 21:23:41 | 000,081,158 | ---- | C] () -- C:\Windows\System32\manage-bde.ini.en
[2007/08/06 11:07:30 | 000,008,784 | ---- | C] () -- C:\Windows\System32\ractrlkeyhook.dll
[2006/11/02 07:55:52 | 000,067,584 | --S- | C] () -- C:\Windows\bootstat.dat
[2006/11/02 07:46:27 | 000,379,872 | ---- | C] () -- C:\Windows\System32\FNTCACHE.DAT
[2006/11/02 07:34:20 | 000,005,632 | ---- | C] () -- C:\Windows\System32\sysprepMCE.dll
[2006/11/02 05:33:01 | 005,766,868 | ---- | C] () -- C:\Windows\System32\perfh009.dat
[2006/11/02 05:33:01 | 001,905,860 | ---- | C] () -- C:\Windows\System32\perfc009.dat
[2006/11/02 05:33:01 | 000,287,440 | ---- | C] () -- C:\Windows\System32\perfi009.dat
[2006/11/02 05:33:01 | 000,030,674 | ---- | C] () -- C:\Windows\System32\perfd009.dat
[2006/11/02 05:23:21 | 000,215,943 | ---- | C] () -- C:\Windows\System32\dssec.dat
[2006/11/02 03:58:30 | 000,043,131 | ---- | C] () -- C:\Windows\mib.bin
[2006/11/02 03:19:00 | 000,000,741 | ---- | C] () -- C:\Windows\System32\NOISE.DAT
[2006/11/02 02:40:29 | 000,013,750 | ---- | C] () -- C:\Windows\System32\pacerprf.ini
[2006/11/02 02:25:31 | 000,673,088 | ---- | C] () -- C:\Windows\System32\mlang.dat
========== LOP Check ==========
[2010/04/29 19:11:54 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Amazon
[2011/01/19 22:44:34 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Autodesk
[2011/07/23 19:15:17 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\BitTorrent
[2009/02/03 05:58:40 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
[2010/12/19 15:31:34 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\eMule
[2011/07/11 17:45:08 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\EVEMon
[2010/08/12 22:24:41 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\FUJIFILM
[2009/07/17 03:21:04 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\GetRightToGo
[2010/08/26 21:45:32 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\ImgBurn
[2009/05/14 13:23:26 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\IrfanView
[2008/12/21 04:21:43 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Leadertech
[2010/10/23 21:11:28 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\motorola
[2008/12/22 01:34:05 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\nHancer
[2009/07/07 04:37:23 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Nokia
[2009/07/07 05:19:18 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Nseries
[2009/07/07 05:18:05 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\PC Suite
[2011/06/15 22:13:17 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\SoftGrid Client
[2010/02/28 17:22:50 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\SystemRequirementsLab
[2010/09/01 11:09:26 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\TP
[2009/07/17 11:04:56 | 000,000,000 | ---D | M] -- C:\Users\Alexian\AppData\Roaming\Turbine
[2008/01/20 21:54:58 | 000,003,456 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
========== Purity Check ==========
========== Alternate Data Streams ==========
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0389.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0381.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0369.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0368.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0366.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0356.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0355.AVI:TOC.WMV
@Alternate Data Stream - 64 bytes -> C:\Users\Alexian\Documents\DSCF0352.AVI:TOC.WMV
@Alternate Data Stream - 122 bytes -> C:\ProgramData\TEMP:1E8CCDDE
@Alternate Data Stream - 113 bytes -> C:\ProgramData\TEMP:6FE816BE
< End of report >
OTL Extras logfile created on: 7/31/2011 9:43:35 AM - Run 1
OTL by OldTimer - Version 3.2.26.1 Folder = C:\Users\Alexian\Desktop
Windows Vista Ultimate Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 9.0.8112.16421)
Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
3.00 Gb Total Physical Memory | 1.68 Gb Available Physical Memory | 56.03% Memory free
6.21 Gb Paging File | 4.81 Gb Available in Paging File | 77.38% Paging File free
Paging file location(s): ?:\pagefile.sys [binary data]
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files
Drive C: | 465.75 Gb Total Space | 148.77 Gb Free Space | 31.94% Space Free | Partition Type: NTFS
Drive E: | 37.26 Gb Total Space | 19.47 Gb Free Space | 52.27% Space Free | Partition Type: NTFS
Drive F: | 1397.23 Gb Total Space | 1310.75 Gb Free Space | 93.81% Space Free | Partition Type: NTFS
Computer Name: MAGIC-BOX | User Name: Alexian | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user
Company Name Whitelist: Off | Skip Microsoft Files: Off | No Company Name Whitelist: On | File Age = 30 Days
========== Extra Registry (SafeList) ==========
========== File Associations ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
.cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
.hlp [@ = hlpfile] -- C:\Windows\winhlp32.exe (Microsoft Corporation)
[HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
.bat [@ = batfile] -- Reg Error: Key error. File not found
.html [@ = FirefoxHTML] -- C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation)
========== Shell Spawning ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
helpfile [open] -- Reg Error: Key error.
hlpfile [open] -- %SystemRoot%\winhlp32.exe %1 (Microsoft Corporation)
htmlfile [edit] -- "C:\Program Files\Microsoft Office\Office14\msohtmed.exe" %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
regfile [merge] -- Reg Error: Key error.
scrfile [config] -- "%1"
scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l
scrfile [open] -- "%1" /S
txtfile [edit] -- Reg Error: Key error.
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
Directory [AddToPlaylistVLC] -- C:\Program Files\VideoLAN\VLC\vlc.exe --started-from-file --playlist-enqueue "%1" ()
Directory [cmd] -- cmd.exe /s /k pushd "%V" (Microsoft Corporation)
Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
Directory [PlayWithVLC] -- C:\Program Files\VideoLAN\VLC\vlc.exe --started-from-file --no-playlist-enqueue "%1" ()
Directory [Winamp.Bookmark] -- "C:\Program Files\Winamp\winamp.exe" /BOOKMARK "%1" (Nullsoft, Inc.)
Directory [Winamp.Enqueue] -- "C:\Program Files\Winamp\winamp.exe" /ADD "%1" (Nullsoft, Inc.)
Directory [Winamp.Play] -- "C:\Program Files\Winamp\winamp.exe" "%1" (Nullsoft, Inc.)
Folder [open] -- %SystemRoot%\Explorer.exe /separate,/idlist,%I,%L (Microsoft Corporation)
Folder [explore] -- %SystemRoot%\Explorer.exe /separate,/e,/idlist,%I,%L (Microsoft Corporation)
Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
========== Security Center Settings ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
"FirewallDisableNotify" = 0
"AntiVirusDisableNotify" = 0
"UpdatesDisableNotify" = 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"VistaSp1" = Reg Error: Unknown registry data type -- File not found
"VistaSp2" = Reg Error: Unknown registry data type -- File not found
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
========== System Restore Settings ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\SystemRestore]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
"DisableSR" = 0
========== Firewall Settings ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
"EnableFirewall" = 0
"DisableNotifications" = 0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]
========== Authorized Applications List ==========
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
"%windir%\system32\sessmgr.exe" = %windir%\system32\sessmgr.exe:*:enabled:@xpsp2res.dll,-22019
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
"C:\Program Files\BitTorrent\bittorrent.exe" = C:\Program Files\BitTorrent\bittorrent.exe:*:Enabled:BitTorrent
========== Vista Active Open Ports Exception List ==========
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]
"{1A368AAE-9157-47AE-8B17-8AC32933F9F3}" = lport=rpc-epmap | protocol=6 | dir=in | svc=rpcss | [email protected],-28539 |
"{23F79136-02F2-4654-8977-091BB55CDB4C}" = rport=10243 | protocol=6 | dir=out | app=system |
"{35EDAAA9-C928-4460-846E-6223EC757C90}" = lport=138 | protocol=17 | dir=in | app=system |
"{4857D283-2FBE-4085-B98E-87C9EF72FBEE}" = lport=3724 | protocol=6 | dir=in | name=blizzard downloader: 3724 |
"{4EB991A2-32B5-4455-8159-65E691FAE21C}" = rport=1900 | protocol=17 | dir=out | svc=ssdpsrv | app=%systemroot%\system32\svchost.exe |
"{5426C452-19E0-4734-9495-DF91AB256B5C}" = lport=2869 | protocol=6 | dir=in | name=windows live communications platform (upnp) |
"{5D743943-4F20-41DF-9308-9B15F2161517}" = lport=49163 | protocol=6 | dir=in | name=akamai netsession interface |
"{660CAAB6-E914-41E1-8411-18BD16598EAC}" = lport=1900 | protocol=17 | dir=in | name=windows live communications platform (ssdp) |
"{75C16C35-FF34-47B3-BE61-DA3737BE9733}" = rport=2177 | protocol=17 | dir=out | svc=qwave | app=%systemroot%\system32\svchost.exe |
"{868B7D02-DB43-4CED-BC70-08FCE6600D2F}" = lport=808 | protocol=6 | dir=in | svc=nettcpactivator | app=c:\windows\microsoft.net\framework\v4.0.30319\smsvchost.exe |
"{8F0CACF4-10F1-4933-9F8E-29C6C9453186}" = rport=445 | protocol=6 | dir=out | app=system |
"{92C30103-F3CE-42FE-BD93-5181D5DB3B2A}" = rport=2177 | protocol=6 | dir=out | svc=qwave | app=%systemroot%\system32\svchost.exe |
"{B008B862-9FC3-4EE3-959C-AE5FFA70D5CE}" = lport=10243 | protocol=6 | dir=in | app=system |
"{B1D3E6DC-DFF7-47E7-957E-AA3CC1E6505E}" = lport=2177 | protocol=6 | dir=in | svc=qwave | app=%systemroot%\system32\svchost.exe |
"{B20B28B9-54EC-466B-98B5-1370EC11A9C8}" = lport=137 | protocol=17 | dir=in | app=system |
"{BB48625B-C832-42F4-B0B1-458BF0A1BEC4}" = lport=49159 | protocol=6 | dir=in | name=akamai netsession interface |
"{BEF0A028-2783-4F97-9C6A-C87DB8C17457}" = lport=139 | protocol=6 | dir=in | app=system |
"{C3659B55-38D1-4692-96C8-09BA9DD87C33}" = lport=12345 | protocol=6 | dir=in | name=motorola helper |
"{CE0DC066-06A4-400F-A463-21F0E2E26FEA}" = lport=2869 | protocol=6 | dir=in | app=system |
"{D14B1EAB-0202-4382-98E1-3ADE07D8AE62}" = lport=1900 | protocol=17 | dir=in | svc=ssdpsrv | app=%systemroot%\system32\svchost.exe |
"{D3526F0F-92EE-4236-8975-C19E58B04248}" = rport=139 | protocol=6 | dir=out | app=system |
"{D7F45250-C7BA-4BC1-ABC5-AB1F7AE69F19}" = lport=5000 | protocol=17 | dir=in | name=akamai netsession interface |
"{DE7791ED-0C8E-4B0A-B715-5941ABC02731}" = rport=137 | protocol=17 | dir=out | app=system |
"{E407F2D6-418F-4F9B-B293-154DAE123BD4}" = rport=138 | protocol=17 | dir=out | app=system |
"{EDCA118F-E402-492E-9DB0-9AC577696C4C}" = lport=1900 | protocol=17 | dir=in | svc=ssdpsrv | app=svchost.exe |
"{F0F2B350-7DE1-453E-A496-AE6F5EA5B1AD}" = lport=2869 | protocol=6 | dir=in | app=system |
"{F29C54B1-7577-42D0-BEA0-19680B37AFE2}" = lport=2177 | protocol=17 | dir=in | svc=qwave | app=%systemroot%\system32\svchost.exe |
"{F4A836CF-2AD9-48C9-912C-7D3BA5239DB2}" = lport=rpc | protocol=6 | dir=in | svc=spooler | app=%systemroot%\system32\spoolsv.exe |
"{F8F0F18E-C4CD-491E-80E8-01BA8CD1D444}" = lport=445 | protocol=6 | dir=in | app=system |
========== Vista Active Application Exception List ==========
"{0681E2B3-79E4-4F72-8E37-5B077C18639F}" = protocol=17 | dir=in | app=%programfiles%\windows media player\wmpnetwk.exe |
"{07ECA25C-1334-4B67-8C71-8D6BD849EA6F}" = protocol=6 | dir=in | app=c:\users\public\documents\blizzard entertainment\world of warcraft\wow-3.0.1-to-3.0.2-enus-win-update-downloader.exe |
"{0D6E3112-7D9C-4D11-9F79-F42BBF61F698}" = protocol=1 | dir=in | [email protected],-26140 |
"{24E6FE56-FA11-4C18-8295-49F5B8E6F93A}" = protocol=6 | dir=in | app=c:\program files\microsoft office\office14\onenote.exe |
"{29D544E0-0FF0-4C9A-9084-B147065D01FD}" = protocol=17 | dir=in | app=c:\windows\system32\pnkbstrb.exe |
"{32C3F510-0A23-418C-9D68-13EDC952BB1D}" = protocol=6 | dir=in | app=%systemroot%\system32\msra.exe |
"{3980F431-CF0E-452F-9B2B-4F5B2F70A045}" = protocol=58 | dir=in | [email protected],-26142 |
"{3D696CBE-7722-4956-BA0E-5F94DA01408B}" = dir=in | app=c:\program files\windows live\mesh\moe.exe |
"{3E8622F7-5E5C-4697-B8DA-CF289D59E637}" = protocol=1 | dir=out | [email protected],-28544 |
"{40737DFA-9CD7-4FA0-8EAC-9015D3B8C53D}" = dir=in | app=c:\program files\windows live\contacts\wlcomm.exe |
"{43F6A975-9607-4AE1-8967-B7260DA6382A}" = protocol=17 | dir=in | app=%programfiles%\windows media player\wmplayer.exe |
"{45DA8994-5BCC-487A-9FE7-94BFE9DC10EA}" = protocol=6 | dir=out | svc=upnphost | app=%systemroot%\system32\svchost.exe |
"{4FC8435D-5A45-4DE0-AAD8-0CA6A3DD1FA6}" = dir=in | app=c:\program files\itunes\itunes.exe |
"{557A778E-0BE0-4486-B898-07384F61A9D8}" = protocol=6 | dir=in | app=c:\windows\system32\pnkbstra.exe |
"{58771BE1-2B00-444A-9997-E0AF486577A7}" = protocol=17 | dir=out | app=%programfiles%\windows media player\wmplayer.exe |
"{618F140A-FBC2-45CE-9AE8-EA9BFA1178EC}" = protocol=1 | dir=in | [email protected],-28543 |
"{61DC2DA9-3893-4160-A7C3-381FBFA5A070}" = protocol=17 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{62F30F5E-E7D8-4821-AFEC-09C2CA33BEBC}" = protocol=6 | dir=out | svc=upnphost | app=%systemroot%\system32\svchost.exe |
"{690B4106-94D6-44EB-AE2B-DFF6F9F87E8D}" = dir=in | app=c:\program files\windows live\messenger\msnmsgr.exe |
"{71A0F4CD-87C6-4AB4-8413-5902748DC766}" = protocol=6 | dir=out | app=%programfiles%\windows media player\wmpnetwk.exe |
"{7271C6E2-377B-4E81-A530-8A7CE18CDBB2}" = protocol=17 | dir=in | app=c:\program files\ventrilo\ventrilo.exe |
"{7EB21956-F3EE-4C6E-8DCD-5550E32882E5}" = protocol=6 | dir=out | app=%programfiles%\windows media player\wmplayer.exe |
"{897A850A-C0BA-4C12-BFED-3E7D0F34047B}" = protocol=17 | dir=in | app=c:\program files\cryptic studios\champions online.exe |
"{90B41D80-0D5F-4ABC-B8BE-4A06C1E7B813}" = protocol=17 | dir=in | app=c:\program files\world of warcraft\launcher.exe |
"{96D289CB-7FF9-4A76-8951-FF3A42877454}" = protocol=58 | dir=in | [email protected],-28545 |
"{9C25567F-0498-47CA-A0E2-2CFB3A3BD298}" = protocol=6 | dir=in | app=c:\program files\ventrilo\ventrilo.exe |
"{A3D204A1-FCD4-4DDA-A82F-84BEB608C26C}" = protocol=6 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{A7B52764-6395-47F8-8264-6DD5BCE136B7}" = protocol=58 | dir=out | [email protected],-28546 |
"{AB4320DB-87E2-4A97-9575-EB1F6448F34B}" = protocol=6 | dir=in | app=c:\windows\system32\pnkbstrb.exe |
"{AD965B45-8D2F-473D-9918-3B0B9B9BD6BC}" = protocol=17 | dir=in | app=c:\users\public\documents\blizzard entertainment\world of warcraft\wow-3.0.9.9551-to-3.1.0.9767-enus-downloader.exe |
"{AF3CD71B-BF8E-4D46-B792-37AB92BC1318}" = dir=in | app=c:\program files\windows live\sync\windowslivesync.exe |
"{B3B94216-9D42-4EB1-A497-66CA9713B114}" = protocol=6 | dir=in | app=c:\program files\ventrilo\ventrilo.exe |
"{BA4F5700-B5C5-4C23-BA6D-80931270EE54}" = protocol=17 | dir=out | app=%programfiles%\windows media player\wmplayer.exe |
"{BDFB338D-46AB-43AE-A52D-D276076A1327}" = protocol=6 | dir=in | app=c:\program files\world of warcraft\launcher.exe |
"{C2361A43-568D-4BE4-9871-A234D3DB1953}" = protocol=17 | dir=in | app=c:\program files\microsoft office\office14\onenote.exe |
"{D802DEEB-2F56-4197-B515-A97D36456DFA}" = protocol=6 | dir=in | app=%programfiles%\windows media player\wmpnetwk.exe |
"{DCAED9D1-CBC4-49AA-BF56-2DEC1568F0DE}" = protocol=6 | dir=out | app=%programfiles%\windows media player\wmplayer.exe |
"{DCC3926F-5256-4A3A-9F9B-7A61CF50B81D}" = protocol=6 | dir=in | app=c:\users\public\documents\blizzard entertainment\world of warcraft\wow-3.0.9.9551-to-3.1.0.9767-enus-downloader.exe |
"{E07FC8EA-DA0E-4C62-8C08-AEED60A75122}" = protocol=17 | dir=in | app=c:\windows\system32\pnkbstra.exe |
"{EA7B272D-5307-422A-A080-587CED387A1D}" = protocol=17 | dir=out | app=%programfiles%\windows media player\wmpnetwk.exe |
"{EAF7FADC-63B7-4315-AFCF-7D12B04344EC}" = protocol=6 | dir=out | app=system |
"{EC41031F-AF29-4C1D-8BDD-24047E0E7C54}" = protocol=17 | dir=in | app=c:\users\public\documents\blizzard entertainment\world of warcraft\wow-3.0.1-to-3.0.2-enus-win-update-downloader.exe |
"{F30CBDF5-A1C5-4FFB-811E-2DE9A0288E08}" = protocol=6 | dir=in | app=c:\program files\cryptic studios\champions online.exe |
"{FA0BA42E-F6E2-4EE5-80DE-047F371450B2}" = protocol=6 | dir=out | app=%systemroot%\system32\msra.exe |
"{FA587C35-AF2F-415A-9675-4ED438151A01}" = protocol=17 | dir=in | app=%programfiles%\windows media player\wmplayer.exe |
"{FAB060C5-BDC3-496D-8C35-CF8BE5EFCBCF}" = protocol=17 | dir=in | app=c:\program files\ventrilo\ventrilo.exe |
"TCP Query User{03D16DE0-CF1D-4177-8A60-899FBBB01EE4}C:\program files\motorola media link\mml.exe" = protocol=6 | dir=in | app=c:\program files\motorola media link\mml.exe |
"TCP Query User{10EDF985-37B1-41A9-BCB4-E39D08577F78}C:\program files\world of warcraft\wow-3.3.5.12340-x86-win-enus-bkgnd-downloader.exe" = protocol=6 | dir=in | app=c:\program files\world of warcraft\wow-3.3.5.12340-x86-win-enus-bkgnd-downloader.exe |
"TCP Query User{36FE7BCD-D06D-4EC1-9B18-75657E1F01B1}C:\program files\ccp\eve\bin\exefile.exe" = protocol=6 | dir=in | app=c:\program files\ccp\eve\bin\exefile.exe |
"TCP Query User{5C45277B-6552-42B9-AC56-30053F70CB94}C:\program files\mozilla firefox\firefox.exe" = protocol=6 | dir=in | app=c:\program files\mozilla firefox\firefox.exe |
"TCP Query User{5CE8C798-D103-4659-8017-00FEAF39B0A4}C:\users\alexian\program files\dna\btdna.exe" = protocol=6 | dir=in | app=c:\users\alexian\program files\dna\btdna.exe |
"TCP Query User{60D6219E-C315-4502-BD00-43976666DC85}C:\program files\world of warcraft\launcher.exe" = protocol=6 | dir=in | app=c:\program files\world of warcraft\launcher.exe |
"TCP Query User{649D80AE-7D14-4406-91F5-5D8F4FCF5FA9}C:\program files\world of warcraft\backgrounddownloader.exe" = protocol=6 | dir=in | app=c:\program files\world of warcraft\backgrounddownloader.exe |
"TCP Query User{6D360D55-214D-46CC-8B00-602874E13B6A}C:\program files\magictune premium\magictune.exe" = protocol=6 | dir=in | app=c:\program files\magictune premium\magictune.exe |
"TCP Query User{71C7E1DD-724D-498B-B383-6F174A7A4470}C:\program files\google\google earth\client\googleearth.exe" = protocol=6 | dir=in | app=c:\program files\google\google earth\client\googleearth.exe |
"TCP Query User{9C23D4F1-9C17-4654-9A4F-F42FC8EC3B4B}C:\users\alexian\appdata\roaming\macromedia\flash player\www.macromedia.com\bin\octoshape\octoshape.exe" = protocol=6 | dir=in | app=c:\users\alexian\appdata\roaming\macromedia\flash player\www.macromedia.com\bin\octoshape\octoshape.exe |
"TCP Query User{A510B73F-5D0D-4D07-905F-2DC8771B068F}C:\users\alexian\program files\dna\btdna.exe" = protocol=6 | dir=in | app=c:\users\alexian\program files\dna\btdna.exe |
"TCP Query User{B1B3B47C-5D6D-47FC-9ED5-3C4F20DE10A7}C:\program files\turbine\the lord of the rings online\lotroclient.exe" = protocol=6 | dir=in | app=c:\program files\turbine\the lord of the rings online\lotroclient.exe |
"TCP Query User{B6AAF544-189B-41F2-83E2-58575CD1DAF7}C:\program files\soulseekns\slsk.exe" = protocol=6 | dir=in | app=c:\program files\soulseekns\slsk.exe |
"TCP Query User{BA1951D3-19A8-4267-8963-57D35EEFC5F0}C:\program files\internet explorer\iexplore.exe" = protocol=6 | dir=in | app=c:\program files\internet explorer\iexplore.exe |
"TCP Query User{CC4C9808-34C8-4049-A047-4BAF99C04BA3}C:\program files\ccp\eve\bin\exefile.exe" = protocol=6 | dir=in | app=c:\program files\ccp\eve\bin\exefile.exe |
"TCP Query User{EB51A2A8-B02B-4F7F-A266-4F15EEA78852}C:\program files\soulseekns\slsk.exe" = protocol=6 | dir=in | app=c:\program files\soulseekns\slsk.exe |
"TCP Query User{EF76F6C6-7B3D-4EB9-9DC6-DAB74F829B39}C:\program files\magictune premium\magictune.exe" = protocol=6 | dir=in | app=c:\program files\magictune premium\magictune.exe |
"TCP Query User{FF8A03A6-4C0F-48E2-9A95-30BA9767980B}C:\program files\bittorrent\bittorrent.exe" = protocol=6 | dir=in | app=c:\program files\bittorrent\bittorrent.exe |
"UDP Query User{1736BB6C-B049-4F70-A6C1-8AA17B051A1A}C:\users\alexian\program files\dna\btdna.exe" = protocol=17 | dir=in | app=c:\users\alexian\program files\dna\btdna.exe |
"UDP Query User{25D92D98-58E4-401D-87D2-15F7B8A5F4A6}C:\program files\mozilla firefox\firefox.exe" = protocol=17 | dir=in | app=c:\program files\mozilla firefox\firefox.exe |
"UDP Query User{28B0EA11-63C2-48C9-9FC2-6622A7184962}C:\program files\motorola media link\mml.exe" = protocol=17 | dir=in | app=c:\program files\motorola media link\mml.exe |
"UDP Query User{3CC4FA07-C723-4D9E-A833-2E6CCCEC482F}C:\program files\ccp\eve\bin\exefile.exe" = protocol=17 | dir=in | app=c:\program files\ccp\eve\bin\exefile.exe |
"UDP Query User{4529BF84-19ED-4C56-9CF4-CD7A276744F0}C:\program files\world of warcraft\wow-3.3.5.12340-x86-win-enus-bkgnd-downloader.exe" = protocol=17 | dir=in | app=c:\program files\world of warcraft\wow-3.3.5.12340-x86-win-enus-bkgnd-downloader.exe |
"UDP Query User{4786096C-1186-40FC-85E5-AC2CF36AF343}C:\program files\bittorrent\bittorrent.exe" = protocol=17 | dir=in | app=c:\program files\bittorrent\bittorrent.exe |
"UDP Query User{4BC1CFFC-FF1C-4552-97D1-6FE108AFB896}C:\program files\soulseekns\slsk.exe" = protocol=17 | dir=in | app=c:\program files\soulseekns\slsk.exe |
"UDP Query User{4FB05FD6-9D0F-489D-BC80-D23A22D78BF9}C:\program files\magictune premium\magictune.exe" = protocol=17 | dir=in | app=c:\program files\magictune premium\magictune.exe |
"UDP Query User{58965323-3587-4BAA-A3E5-94B091895E4E}C:\program files\magictune premium\magictune.exe" = protocol=17 | dir=in | app=c:\program files\magictune premium\magictune.exe |
"UDP Query User{6256511E-349D-4BFE-B16D-9A03DF23B6ED}C:\users\alexian\appdata\roaming\macromedia\flash player\www.macromedia.com\bin\octoshape\octoshape.exe" = protocol=17 | dir=in | app=c:\users\alexian\appdata\roaming\macromedia\flash player\www.macromedia.com\bin\octoshape\octoshape.exe |
"UDP Query User{6BD6CAE6-91CB-473D-BA3A-073EC6F02D47}C:\program files\soulseekns\slsk.exe" = protocol=17 | dir=in | app=c:\program files\soulseekns\slsk.exe |
"UDP Query User{9D35E00B-F0BD-479F-A7AE-7091BC415F35}C:\program files\google\google earth\client\googleearth.exe" = protocol=17 | dir=in | app=c:\program files\google\google earth\client\googleearth.exe |
"UDP Query User{A05D3E43-52BB-43CC-8A4F-4E4D1FD88468}C:\program files\internet explorer\iexplore.exe" = protocol=17 | dir=in | app=c:\program files\internet explorer\iexplore.exe |
"UDP Query User{A57BBE1A-6F9F-4CC6-8A7D-ED80721F6AF0}C:\program files\world of warcraft\launcher.exe" = protocol=17 | dir=in | app=c:\program files\world of warcraft\launcher.exe |
"UDP Query User{C8B24A0D-3F12-49EF-B849-97F6BBA3F008}C:\program files\ccp\eve\bin\exefile.exe" = protocol=17 | dir=in | app=c:\program files\ccp\eve\bin\exefile.exe |
"UDP Query User{CD4459C1-1A3D-4B36-836B-85D9946862A0}C:\program files\world of warcraft\backgrounddownloader.exe" = protocol=17 | dir=in | app=c:\program files\world of warcraft\backgrounddownloader.exe |
"UDP Query User{E239BA67-EBD5-48BD-A223-6D0509D4395F}C:\program files\turbine\the lord of the rings online\lotroclient.exe" = protocol=17 | dir=in | app=c:\program files\turbine\the lord of the rings online\lotroclient.exe |
"UDP Query User{EADB8AA8-2155-4645-9B48-EAECFD6DBEDD}C:\users\alexian\program files\dna\btdna.exe" = protocol=17 | dir=in | app=c:\users\alexian\program files\dna\btdna.exe |
========== HKEY_LOCAL_MACHINE Uninstall List ==========
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{08610298-29AE-445B-B37D-EFBE05802967}" = LWS Pictures And Video
"{0A0CADCF-78DA-33C4-A350-CD51849B9702}" = Microsoft .NET Framework 4 Extended
"{0B0F231F-CE6A-483D-AA23-77B364F75917}" = Windows Live Installer
"{10204ABB-1728-4A23-8D44-D14F568DF25C}" = Mototools Software Update
"{138A4072-9E64-46BD-B5F9-DB2BB395391F}" = LWS VideoEffects
"{15634701-BACE-4449-8B25-1567DA8C9FD3}" = CameraHelperMsi
"{1651216E-E7AD-4250-92A1-FB8ED61391C9}" = LWS Help_main
"{174A3B31-4C43-43DD-866F-73C9DB887B48}" = LWS Twitter
"{17504ED4-DB08-40A8-81C2-27D8C01581DA}" = Windows Live Remote Service Resources
"{18455581-E099-4BA8-BC6B-F34B2F06600C}" = Google Toolbar for Internet Explorer
"{196467F1-C11F-4F76-858B-5812ADC83B94}" = MSXML 4.0 SP3 Parser
"{19A4A990-5343-4FF7-B3B5-6F046C091EDF}" = Windows Live Remote Client
"{19BA08F7-C728-469C-8A35-BFBD3633BE08}" = Windows Live Movie Maker
"{1D76A52C-87A6-4AB0-A7B0-08C8D5DF1D75}" = Motorola Mobile Drivers Installation 5.2.0
"{1E99F5D7-4262-4C7C-9135-F066E7485811}" = System Requirements Lab
"{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
"{1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4}" = Junk Mail filter update
"{200FEC62-3C34-4D60-9CE8-EC372E01C08F}" = Windows Live SOXE Definitions
"{21DF0294-6B9D-4741-AB6F-B2ABFBD2387E}" = LWS YouTube Plugin
"{227E8782-B2F4-4E97-B0EE-49DE9CC1C0C0}" = Windows Live Remote Service
"{2318C2B1-4965-11d4-9B18-009027A5CD4F}" = Google Toolbar for Internet Explorer
"{26A24AE4-039D-4CA4-87B4-2F83216026FF}" = Java(TM) 6 Update 26
"{28C2DED6-325B-4CC7-983A-1777C8F7FBAB}" = RealUpgrade 1.1
"{2902F983-B4C1-44BA-B85D-5C6D52E2C441}" = Windows Live Mesh ActiveX Control for Remote Connections
"{294BF709-D758-4363-8D75-01479AD20927}" = Windows Live Family Safety
"{3336F667-9049-4D46-98B6-4C743EEBC5B1}" = Windows Live Photo Gallery
"{34F4D9A4-42C2-4348-BEF4-E553C84549E7}" = Windows Live Photo Gallery
"{350C97B0-3D7C-4EE8-BAA9-00BCB3D54227}" = WebFldrs XP
"{3921A67A-5AB1-4E48-9444-C71814CF3027}" = VCRedistSetup
"{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
"{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}" = erLT
"{4640FDE1-B83A-4376-84ED-86F86BEE2D41}" = Driver Detective
"{464B3406-A4D0-4914-910F-7CA4380DCC13}" = Windows Live Remote Client Resources
"{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
"{4CBABDFD-49F8-47FD-BE7D-ECDE7270525A}" = Windows Live PIMT Platform
"{50816F92-1652-4A7C-B9BC-48F682742C4B}" = Messenger Companion
"{553C904F-57A2-4113-888E-BA0C3D1C69C0}" = Microsoft VC9 runtime libraries
"{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
"{57752979-A1C9-4C02-856B-FBB27AC4E02C}" = QuickTime
"{5783F2D7-9001-0409-0002-0060B0CE6BBA}" = AutoCAD 2011 - English
"{5783F2D7-9001-0409-1002-0060B0CE6BBA}" = AutoCAD 2011 Language Pack - English
"{59625CC8-69B3-4917-864B-3CE27B76DCF3}" = MagicTunePremium
"{5DD4FCBD-A3C1-4155-9E17-4161C70AAABA}" = Segoe UI
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{60C7374C-B546-45DE-A578-2E29BA8C3F1C}" = Moto Helper Service
"{61AD15B2-50DB-4686-A739-14FE180D4429}" = Windows Live ID Sign-in Assistant
"{682B3E4F-696A-42DE-A41C-4C07EA1678B4}" = Windows Live SOXE
"{69FDFBB6-351D-4B8C-89D8-867DC9D0A2A4}" = Windows Media Player Firefox Plugin
"{6A05FEDF-662E-46BF-8A25-010E3F1C9C69}" = Windows Live UX Platform Language Pack
"{6F3D2F66-F050-45E3-BEB1-6523FE6D6690}" = MotoHelper MergeModules
"{6F76EC3C-34B1-436E-97FB-48C58D7BEDCD}" = LWS Gallery
"{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}" = Microsoft Visual C++ 2005 Redistributable
"{71E66D3F-A009-44AB-8784-75E2819BA4BA}" = LWS Motion Detection
"{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
"{7770E71B-2D43-4800-9CB3-5B6CAAEBEBEA}" = RealNetworks - Microsoft Visual C++ 2008 Runtime
"{789289CA-F73A-4A16-A331-54D498CE069F}" = Ventrilo Client
"{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}" = Apple Software Update
"{78A96B4C-A643-4D0F-98C2-A8E16A6669F9}" = Windows Live Messenger Companion Core
"{80956555-A512-4190-9CAD-B000C36D6B6B}" = Windows Live Messenger
"{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
"{83C8FA3C-F4EA-46C4-8392-D3CE353738D6}" = LWS Launcher
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{85195381-0426-4715-8D25-E21B9457FC00}" = Ad-Aware
"{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}" = Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
"{8937D274-C281-42E4-8CDB-A0B2DF979189}" = LWS Webcam Software
"{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
"{8BA510D1-045B-4E1A-AF52-2282BBF69D5D}" = LightScribe System Software
"{8C6D6116-B724-4810-8F2D-D047E6B7D68E}" = Mesh Runtime
"{8DC910CD-8EE3-4ffc-A4EB-9B02701059C4}" = Battlefield Heroes
"{8DD46C6A-0056-4FEC-B70A-28BB16A1F11F}" = MSVCRT
"{90120000-0020-0409-0000-0000000FF1CE}" = Compatibility Pack for the 2007 Office system
"{90140000-0015-0409-0000-0000000FF1CE}" = Microsoft Office Access MUI (English) 2010
"{90140000-0015-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-0016-0409-0000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2010
"{90140000-0016-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-0018-0409-0000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2010
"{90140000-0018-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-0019-0409-0000-0000000FF1CE}" = Microsoft Office Publisher MUI (English) 2010
"{90140000-0019-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-001A-0409-0000-0000000FF1CE}" = Microsoft Office Outlook MUI (English) 2010
"{90140000-001A-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-001B-0409-0000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2010
"{90140000-001B-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-001F-0409-0000-0000000FF1CE}" = Microsoft Office Proof (English) 2010
"{90140000-001F-0409-0000-0000000FF1CE}_Office14.SingleImage_{99ACCA38-6DD3-48A8-96AE-A283C9759279}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-001F-040C-0000-0000000FF1CE}" = Microsoft Office Proof (French) 2010
"{90140000-001F-040C-0000-0000000FF1CE}_Office14.SingleImage_{46298F6A-1E7E-4D4A-B5F5-106A4F0E48C6}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-001F-0C0A-0000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2010
"{90140000-001F-0C0A-0000-0000000FF1CE}_Office14.SingleImage_{DEA87BE2-FFCC-4F33-9946-FCBE55A1E998}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-002C-0409-0000-0000000FF1CE}" = Microsoft Office Proofing (English) 2010
"{90140000-002C-0409-0000-0000000FF1CE}_Office14.SingleImage_{7CA93DF4-8902-449E-A42E-4C5923CFBDE3}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-003D-0000-0000-0000000FF1CE}" = Microsoft Office Single Image 2010
"{90140000-003D-0000-0000-0000000FF1CE}_Office14.SingleImage_{047B0968-E622-4FAA-9B4B-121FA109EDDE}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-006E-0409-0000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2010
"{90140000-006E-0409-0000-0000000FF1CE}_Office14.SingleImage_{4560037C-E356-444A-A015-D21F487D809E}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-00A1-0409-0000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2010
"{90140000-00A1-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-0115-0409-0000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2010
"{90140000-0115-0409-0000-0000000FF1CE}_Office14.SingleImage_{4560037C-E356-444A-A015-D21F487D809E}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90140000-0117-0409-0000-0000000FF1CE}" = Microsoft Office Access Setup Metadata MUI (English) 2010
"{90140000-0117-0409-0000-0000000FF1CE}_Office14.SingleImage_{6BD185A0-E67F-4F77-8BCD-E34EA6AE76DF}" = Microsoft Office 2010 Service Pack 1 (SP1)
"{90850409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Word Viewer 2003
"{92482FB3-C05B-41C6-89E7-75D985602A6E}" = System Requirements Lab
"{92EA4134-10D1-418A-91E1-5A0453131A38}" = Windows Live Movie Maker
"{94CAC2F1-C856-47F4-AF24-65A1E75AEDB9}" = MotoHelper MergeModules
"{95120000-00B9-0409-0000-0000000FF1CE}" = Microsoft Application Error Reporting
"{9A25302D-30C0-39D9-BD6F-21E6EC160475}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
"{9BE518E6-ECC6-35A9-88E4-87755C07200F}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
"{9D56775A-93F3-44A3-8092-840E3826DE30}" = Windows Live Mail
"{9D6B740F-D9A2-45A6-BDC4-0A453D499FE6}" = PC Connectivity Solution
"{9DAEA76B-E50F-4272-A595-0124E826553D}" = LWS WLM Plugin
"{9DEABCB6-B759-4D52-92F8-51B34A2B4D40}" = Autodesk Material Library 2011
"{A0C91188-C88F-4E86-93E6-CD7C9A266649}" = Windows Live Mesh
"{A5C92CF6-7B3E-4892-8DE5-125E44D1AD06}" = nHancer
"{A726AE06-AAA3-43D1-87E3-70F510314F04}" = Windows Live Writer
"{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}" = Google Update Helper
"{A9BDCA6B-3653-467B-AC83-94367DA3BFE3}" = Windows Live Photo Common
"{AAAFC670-569B-4A2F-82B4-42945E0DE3EF}" = Windows Live Writer
"{AAF454FC-82CA-4F29-AB31-6A109485E76E}" = Windows Live Writer
"{AB05F2C8-F608-403b-95E1-FD8ADFACD31E}" = Windows 7 Upgrade Advisor
"{AC76BA86-7AD7-1033-7B44-A94000000001}" = Adobe Reader 9.4.5
"{AC76BA86-7AD7-5464-3428-900000000004}" = Spelling Dictionaries Support For Adobe Reader 9
"{AC76BA86-7AD7-5670-0000-900000000003}" = Korean Fonts Support For Adobe Reader 9
"{AF844339-2F8A-4593-81B3-9F4C54038C4E}" = Windows Live MIME IFilter
"{B13A7C41581B411290FBC0395694E2A9}" = DivX Converter
"{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.ControlPanel" = NVIDIA Control Panel 275.33
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver" = NVIDIA Graphics Driver 275.33
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX" = NVIDIA PhysX System Software 9.10.0514
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Update" = NVIDIA Update 1.3.5
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_installer" = NVIDIA Install Application
"{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NVIDIA.Update" = NVIDIA Update Components
"{B3575D00-27EF-49C2-B9E0-14B3D954E992}" = Apple Application Support
"{B3FED300-806C-11E0-A0D0-B8AC6F97B88E}" = Google Earth
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{B9DB4C76-01A4-46D5-8910-F7AA6376DBAF}" = NVIDIA PhysX
"{C23CD6DA-1958-43A5-ADD0-59396572E02E}" = Apple Mobile Device Support
"{C66824E4-CBB3-4851-BB3F-E8CFD6350923}" = Windows Live Mail
"{C73CA646-73B3-4AEF-A136-C37505745174}" = iTunes
"{CB2F7EDD-9D1F-43C1-90FC-4F52EAE172A1}" = Microsoft .NET Framework 1.1
"{CD1E078C-A6B9-47DA-B035-6365C85C7832}" = Autodesk Material Library 2011 Base Image library
"{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware Free Edition
"{CE2CDD62-0124-36CA-84D3-9F4DCF5C5BD9}" = Microsoft .NET Framework 3.5 SP1
"{CE95A79E-E4FC-4FFF-8A75-29F04B942FF2}" = Windows Live UX Platform
"{CEF7211D-CE3A-44C4-B321-D84A2099AE94}" = Comcast Desktop Software (v1.2.0.9)
"{D03482C5-9AD8-496D-B388-692AE04C93AF}" = Bonjour
"{D40EB009-0499-459c-A8AF-C9C110766215}" = Logitech Webcam Software
"{D436F577-1695-4D2F-8B44-AC76C99E0002}" = Windows Live Photo Common
"{D45240D3-B6B3-4FF9-B243-54ECE3E10066}" = Windows Live Communications Platform
"{D87149B3-7A1D-4548-9CBF-032B791E5908}" = Desktop Doctor
"{D9DC70B6-BE13-41DD-9053-9E617E72D085}" = MOTOROLA MEDIA LINK
"{DDC8BDEE-DCAC-404D-8257-3E8D4B782467}" = Windows Live Writer Resources
"{DECDCB7C-58CC-4865-91AF-627F9798FE48}" = Windows Live Mesh
"{E09C4DB7-630C-4F06-A631-8EA7239923AF}" = D3DX10
"{E7C97E98-4C2D-BEAF-5D2F-CC45A2F95D90}" = Acrobat.com
"{EB4DF488-AAEF-406F-A341-CB2AAA315B90}" = Windows Live Messenger
"{EED027B7-0DB6-404B-8F45-6DFEE34A0441}" = LWS Video Mask Maker
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}" = Visual C++ 2008 x86 Runtime - (v9.0.30729)
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}.vc_x86runtime_30729_01" = Visual C++ 2008 x86 Runtime - v9.0.30729.01
"{F53D678E-238F-4A71-9742-08BB6774E9DC}" = Windows Live Family Safety
"{FDB3B167-F4FA-461D-976F-286304A57B2A}" = Adobe AIR
"{FE044230-9CA5-43F7-9B58-5AC5A28A1F33}" = Windows Live Essentials
"{FF167195-9EE4-46C0-8CD7-FBA3457E88AB}" = LWS Facebook
"12bbe590-c890-11d9-9669-0800200c9a66_is1" = The Lord of the Rings Online™: Mines of Moria™ v02.02.03.8033
"504244733D18C8F63FF584AEB290E3904E791693" = Windows Driver Package - Nokia pccsmcfd (08/22/2008 7.0.0.0)
"Adobe AIR" = Adobe AIR
"Adobe Flash Player ActiveX" = Adobe Flash Player 10 ActiveX
"Adobe Flash Player Plugin" = Adobe Flash Player 10 Plugin
"Akamai" = Akamai NetSession Interface
"Amazon MP3 Downloader" = Amazon MP3 Downloader 1.0.10
"ASIO4ALL" = ASIO4ALL
"Audacity_is1" = Audacity 1.2.6
"AutoCAD 2011 - English" = AutoCAD 2011 - English
"Belarc Advisor" = Belarc Advisor 8.1
"CCleaner" = CCleaner
"Celestia_is1" = Celestia 1.6.0
"Champions Online" = Champions Online
"com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
"Creative PD0620" = Creative WebCam Instant Driver (1.01.02.0729)
"DivX Setup.divx.com" = DivX Setup
"DriverAgent.exe" = DriverAgent by eSupport.com
"EVE" = EVE Online (remove only)
"EVEMon" = EVEMon
"Google Updater" = Google Updater
"HijackThis" = HijackThis 2.0.2
"ImgBurn" = ImgBurn
"IrfanView" = IrfanView (remove only)
"Logitech Vid" = Logitech Vid HD
"Magic ISO Maker v5.5 (build 0281)" = Magic ISO Maker v5.5 (build 0281)
"Microsoft .NET Framework 1.1 (1033)" = Microsoft .NET Framework 1.1
"Microsoft .NET Framework 3.5 SP1" = Microsoft .NET Framework 3.5 SP1
"Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
"Microsoft .NET Framework 4 Extended" = Microsoft .NET Framework 4 Extended
"MotoHelper" = MotoHelper 2.0.51 Driver 5.2.0
"Mozilla Firefox 5.0 (x86 en-US)" = Mozilla Firefox 5.0 (x86 en-US)
"N360" = Norton Security Suite
"NVIDIA Display Control Panel" = NVIDIA Display Control Panel
"NVIDIA Drivers" = NVIDIA Drivers
"NVIDIA StereoUSB Driver" = NVIDIA 3D Vision Controller Driver
"Office14.SingleImage" = Microsoft Office Home and Student 2010
"Plants vs. Zombies" = Plants vs. Zombies
"PowerISO" = PowerISO
"PunkBusterSvc" = PunkBuster Services
"RealPlayer 12.0" = RealPlayer
"Secunia PSI" = Secunia PSI (2.0.0.3003)
"SoftwareUpdUtility" = Download Updater (AOL LLC)
"Soulseek2" = SoulSeek 157 NS 13e
"sp6" = Logitech SetPoint 6.30
"SystemRequirementsLab" = System Requirements Lab
"Tactile12000 2.1" = Tactile12000 2.1
"TweakUAC_is1" = TweakUAC
"VLC media player" = VLC media player 0.9.8a
"Warhammer Online - Age of Reckoning" = Warhammer Online - Age of Reckoning
"WinAce Archiver" = WinAce Archiver
"Winamp" = Winamp
"Winamp Toolbar" = Winamp Toolbar
"WinLiveSuite" = Windows Live Essentials
"World of Warcraft" = World of Warcraft
========== HKEY_CURRENT_USER Uninstall List ==========
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"090215de958f1060" = Curse Client
"Google Chrome" = Google Chrome
"Octoshape add-in for Adobe Flash Player" = Octoshape add-in for Adobe Flash Player
"SOE-Star Wars Galaxies" = Star Wars Galaxies
"Winamp Detect" = Winamp Detector Plug-in
========== Last 10 Event Log Errors ==========
[ Application Events ]
Error - 6/16/2011 1:30:06 AM | Computer Name = magic-box | Source = Lavasoft Ad-Aware Service | ID = 0
Description =
Error - 6/17/2011 3:12:35 AM | Computer Name = magic-box | Source = Lavasoft Ad-Aware Service | ID = 0
Description =
Error - 6/17/2011 6:11:56 PM | Computer Name = magic-box | Source = LoadPerf | ID = 3012
Description = The performance strings in the Performance registry value is corrupted
when process Performance extension counter provider. The BaseIndex value from the
Performance registry is the first DWORD in the Data section, LastCounter value
is the second DWORD in the Data section, and LastHelp value is the third DWORD in
the Data section.
Error - 6/17/2011 6:11:56 PM | Computer Name = magic-box | Source = LoadPerf | ID = 3011
Description = Unloading the performance counter strings for service WmiApRpl (WmiApRpl)
failed. The first DWORD in the Data section contains the error code.
Error - 6/18/2011 2:33:48 AM | Computer Name = magic-box | Source = Lavasoft Ad-Aware Service | ID = 0
Description =
Error - 6/19/2011 1:30:06 AM | Computer Name = magic-box | Source = Lavasoft Ad-Aware Service | ID = 0
Description =
Error - 6/20/2011 8:13:25 PM | Computer Name = magic-box | Source = LoadPerf | ID = 3012
the Data section.
Error - 6/20/2011 8:13:25 PM | Computer Name = magic-box | Source = LoadPerf | ID = 3011
Error - 6/21/2011 8:48:43 PM | Computer Name = magic-box | Source = VSS | ID = 8194
Description =
Error - 6/21/2011 8:49:52 PM | Computer Name = magic-box | Source = System Restore | ID = 8193
Description =
[ System Events ]
Error - 7/28/2011 11:38:40 PM | Computer Name = magic-box | Source = disk | ID = 262151
Description = The device, \Device\Harddisk0\DR0, has a bad block.
Error - 7/30/2011 6:37:57 PM | Computer Name = magic-box | Source = EventLog | ID = 6008
Description = The previous system shutdown at 5:27:31 PM on 7/30/2011 was unexpected.
Error - 7/30/2011 6:38:52 PM | Computer Name = magic-box | Source = Service Control Manager | ID = 7026
Description = The following boot-start or system-start driver(s) failed to load:
HdAudint
Error - 7/30/2011 7:52:17 PM | Computer Name = magic-box | Source = EventLog | ID = 6008
Description = The previous system shutdown at 6:42:26 PM on 7/30/2011 was unexpected.
Error - 7/30/2011 7:53:04 PM | Computer Name = magic-box | Source = Service Control Manager | ID = 7026
HdAudint
Error - 7/30/2011 8:14:33 PM | Computer Name = magic-box | Source = EventLog | ID = 6008
Description = The previous system shutdown at 7:10:46 PM on 7/30/2011 was unexpected.
Error - 7/30/2011 8:14:58 PM | Computer Name = magic-box | Source = Service Control Manager | ID = 7026
HdAudint
Error - 7/31/2011 10:28:09 AM | Computer Name = magic-box | Source = EventLog | ID = 6008
Description = The previous system shutdown at 9:24:14 AM on 7/31/2011 was unexpected.
Error - 7/31/2011 10:29:00 AM | Computer Name = magic-box | Source = Service Control Manager | ID = 7026
HdAudint
Error - 7/31/2011 10:31:22 AM | Computer Name = magic-box | Source = Service Control Manager | ID = 7011
Description = Timeout (30000 milliseconds) waiting for a transaction response from
the Eventlog service.
< End of report >
    AMD Phenom X4 9750 Quad-Core Processor
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Okay, I see nothing too wrong with that log, there's a little housekeeping we can do:
Open up OTL again, and in the custom scans/fixes box copy and paste the following, then press Run Fix
Code:
:OTL
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
O16 - DPF: {8FFBE65D-2C9C-4669-84BD-5829DC0B603C} http://fpdownload.macromedia.com/get.../ultrashim.cab (Reg Error: Key error.)
O18 - Protocol\Handler\ipp - No CLSID value found
:commands
[EMPTYTEMP]
[REBOOT]
Copy and paste the contents of the log that opens upon completion of that
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4efb-9B51-7695ECA05670}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{02478D38-C3F9-4efb-9B51-7695ECA05670}\ not found.
Starting removal of ActiveX control {8FFBE65D-2C9C-4669-84BD-5829DC0B603C}
C:\WINDOWS\Downloaded Program Files\erma.inf moved successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{8FFBE65D-2C9C-4669-84BD-5829DC0B603C}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\ipp\ deleted successfully.
File Protocol\Handler\ipp - No CLSID value found not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\ipp\ not found.
File PTYTEMP] not found.
File BOOT] not found.
OTL by OldTimer - Version 3.2.26.1 log created on 07312011_131403
Files\Folders moved on Reboot...
Registry entries deleted on Reboot...
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Have you tried disabling Norton?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
No I haven't tried that approach yet. Is it known to cause errors such as this?
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
I am currently looking at the event log and have filtered it to show only the Event ID 7026 and the first instance of this occurring is back on August 12, 2010. Is there any way to see what was added or changed on or before this day to maybe get a hint of what is causing this?
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
That's a long time ago, I doubt looking at things that changed on that day would help - the chances are any bugs from that date have been patched
Anti virus programs are known to cause problems here and there sometimes so its worth a shot - try the same with Spybot and Ad-Aware
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Turned them all off and still have the same problem.
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I already have this one installed. I've attempted to uninstall and reinstall it, but it's still the same.
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
What audio device do you have? Sound card etc.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
It's an onboard sound device. nForce 750a SLI is the motherboard. I have version 15.56 driver installed for the motherboard. I've uninstalled and reinstalled this driver as well. No luck though.
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Try a fresh version not the driver file you already have.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Same result :(
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
Why does windows install its HD audio driver when I reboot after installing the nvidia driver?
    XFX nForce 750a SLI
    4 Gigs DDR2 RAM
    2x Nvidia 9800 GT
