Vista Local Access Only Problem!
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : RoryFong-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Bluetooth PAN Network Adapter
Physical Address. . . . . . . . . : 00-11-67-8E-99-D8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-53-DC-73
Link-local IPv6 Address . . . . . : fe80::a154:2dc5:91d1:2a48%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, November 03, 2010 7:40:25 PM
Lease Expires . . . . . . . . . . : Thursday, November 04, 2010 7:40:25 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234888665
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-02-E8-AD-00-1B-24-BB-CF-FE
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce 10/100/1000 Mbps Ethernet
Physical Address. . . . . . . . . : 00-1B-24-BB-CF-FE
Link-local IPv6 Address . . . . . : fe80::b488:2be4:8037:d8ab%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, November 03, 2010 7:39:36 PM
Lease Expires . . . . . . . . . . : Thursday, November 04, 2010 7:39:35 PM
DHCPv6 IAID . . . . . . . . . . . : 234887972
192.168.1.1
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{8E8992CA-DE24-4034-A370-5CFE3B5AC
7B8}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.{DFDFC314-CBC6-4D30-8569-EAEADEE44
D3C}
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 17:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Local Area Connection* 18:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 20:
7B8}
Tunnel adapter Local Area Connection* 21:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
Tunnel adapter Local Area Connection* 22:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #7
Tunnel adapter Local Area Connection* 23:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #8
Tunnel adapter Local Area Connection* 24:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #9
Tunnel adapter Local Area Connection* 25:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #10
Tunnel adapter Local Area Connection* 26:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #11
Tunnel adapter Local Area Connection* 27:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #12
Tunnel adapter Local Area Connection* 28:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #13
Tunnel adapter Local Area Connection* 29:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #14
Tunnel adapter Local Area Connection* 30:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #15
Tunnel adapter Local Area Connection* 31:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #16
Tunnel adapter Local Area Connection* 32:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #17
Tunnel adapter Local Area Connection* 35:
Description . . . . . . . . . . . : isatap.{D95BC3FB-FCC0-4D6D-A98E-67A2375C4
DEE}
Tunnel adapter Local Area Connection* 36:
DEE}
192.168.1.1
192.168.1.1
7B8}
D3C}
7B8}
DEE}
DEE}
Okay Thank you did you run the Batch File that was attached?
Also Is there any Problems in Device Manger?
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
OP's Question:
I'M SORRY, I NEED HELP AGAIN
RIGHT HERE IS THE STORY:
When it was fixed, I was at my sister's flat (where the wifi wasn't working initially, but uninstalling the yellow flagged driver fixed it, so i just assumed it had fixed my wifi completely!)
but i've just got back to my own house, and the wifi here still isn't working. local only until i plug in the ethernet cable.
What do I do?
Appreciate any help you can give me.
Thank you.
Previous Solution - http://www.vistax64.com/network-sharing/284261-vista-local-access-only-problem.html
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Hey, thanks for replying so quickly. Yes, I ran the file but I'm not sure if it worked. It automatically restarted my computer.
There are no yellow flags in device manager.
Yeah it worked thank you ,
Also Could you go to Start>Control Panel>Networking and Internet>Network and Sharing Centre
This will Display a Brief Network Map There should be a Red X Between your Router and The Internet Icon
Please CLick it and then let the Diagnoses run once it comes up with a Selection or a Report Please post back what the Options are and what has been Stated
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Okay Could you Please Unplug your Router/Modem and Wait 1 Minutes / 60 Seconds then Plug your Router back in and test your Netowork Connection
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Do you know your Routers IP Address?
What Router do you have?
    AMD HD Radeon 6870
    Novatech Night
    AMD HD Radeon 6870
    Novatech Night
Mmmmm have you tried Upgrading the Firmware of your Router and what is your ISP (Internet Service Provider) ?
    AMD HD Radeon 6870
    Novatech Night
hi again,
sorry i know this may sound stupid. but how do i upgrade the firmware (althought, sure it should be up to date because it was only installed a few weeks ago and it works for my flatmates laptops, and my iphone.).
I'm in the UK using TalkTalk.
Hey,
I am sure your Firmware isn't the Problem
Just One thing to make sure for certain it is your Wireless card or if it is your Internet Protocol Settings
Could you please plug in an Ethernet Cable and check the connection if it connects
Please Report Back,
Josh
    AMD HD Radeon 6870
    Novatech Night
Hi, sorry! I thought I had written originally that I can use the Ethernet cable to connect to the Internet. That is how I have been posting on here haha. And I don't think it would be my network card, because my laptop works with my school and my sisters and starbucks wifi. :S
Okay I have also noticed you have some IPv4 Address having a preffered IP Address could you please turn this off
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
Click Start>Control panel> Network and Internet> Network and Sharing Centre
Then Click View Status by your Netowork signal
After that click Properties
Please give an Admin Password if asked
Then click on:
Code:
Internet Protocol Version 6
And click Properties
This will bring up a Window Please make sure that it says to get IPv6 and DNS Automatically
Do this for Internet Protocol Version 4
Also Do you have an Installation Disk?
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
