Vista ISO download
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Only to an email address, you can edit it out afterwards.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Hi Ex_Brit,
I posted to the thread earlier that I am in need of a 64-bit Windows Vista Home Premium. I did not get any response message to my inbox or email even tho I posted my email.
Hi Ex_Brit,
Sorry I guess I missed it.....sent. You can now edit out your email from the post above. Good luck ;-)
Edit: found your post from back in May....no email address so may have ignored it....sorry.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Ex-Brit
I need .iso for Vista 64 bit Business and Vista 64 bit Ultimate
I have a full retail copy of Vista Ultimate but it does not have SP1 or SP2.
Thanks
Ex-Brit
Thanks
Sent, hope it helps. ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Peter,
Will update you on how it goes. I have a bunch of Thinkpads with original keys and have been trying to streamline the installation process of the native OS. These are for T61 models. My avatar shows my little workshop in my garage.
Hello, not sure if I've done this right (i replied to thread??!!) I've been searching for a Vista iso as my dell machine came with a vista pre-installed and something's gone wrong with it. Please may I have the link or the iso? Do i have to post my email address in this thread? Many thanks. Oh and my key is for Vista Home Premium 64bit.
    Dell
    Core 2 duo
    not sure
    1gb
    not sure
    not sure
    dell
Peter,
LOL, you're lucky you have space like that ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
I can help you but as I wont publish my link you'll have to post your email, you should disguise it as in abc AT xyz DOT com or similar and then you can always edit it out of the post later.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Thanks a bunch, works like a charm :)
E: And the email address used to be in the old post, just deleted it after no response so it wont be hanging there ;>
OK, good luck ;-)
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
