Solved vista home basic cant manage hardware or run anything with system settings
This sounds like a hradware problem - have you disconnected all external devices? If not, please do so (printers, scanners, external HD, USB sticks, etc)
Possibly you need to run some diagnostics.
MemTest86+ - www.memtest.org - create the boot disk, and run continuous scans for at least an hour (preferably 4 hours)
Download the HD manufacturer's test utility and create the disk - then run both the quick scan, and the long scan. See if that finds any errors.
    Acer Aspire 8930G
it is now fixed. i ended up in rage (pretty comical) taking my 2 laptops apart, and just throwing parts from one to the other. then i reloaded factory recovery setting and installed my graphics card. now i have a beautifully operating computer again. seems slower but there's a ton of junk ware still and its only the second start-up, so many updates to catch.
    accer 5517
    4gb
    256mb
    160gb
Woot woot !!! bet you are one happy camper. good news from you, Good luck on getting your updates.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
yes i am extremely happy! 3 sleepless nights and ended up being a simple hardware issue that never showed on any of the tests i ran.
just curious, but shouldn't this run much faster than windows7 when i have it cleaned up?
    accer 5517
    4gb
    256mb
    160gb
Speed wise really depends on your processor speed, number of cores, etc. As far as OS speed, if the hard drive is defragged , and cleaned of temp files and such and you have good amount of useable Ram available , mere microseconds will be unnoticeable .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
somehow the sims 2 partion of my hard drive remains... are there benefits to diff partions besides this?
    accer 5517
    4gb
    256mb
    160gb
As long as your main partition is large enough, leave the sims 2 partition as it is. We have tutorials on extending partition, changing size and etc. For now, i would not mess with it.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Not surprising that you're happy - hardware problems can be a b*tch to solve!
As far as speed vs Win 7 is concerned, generally, my experience is that Win 7 will run slightly faster than a fully-updated Vista on the same hardware (but a LOT faster than Vsita RTM) - especially if the RAM is restricted.
    Acer Aspire 8930G
Please start a NEW thread of your own, and include the EXACT error message you get, and what updates you are talking about.
    Acer Aspire 8930G
Welcome to the Forum. Please start your own thread , this one was for munion07 and has been marked solved.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
