vista dvd-rw drive record speed
The default setting is usually "Maximum"!
The maximum speeds for me are 126x CD (18900KB/sec) & 16x DVD (22160KB/sec).
The speed is usually capped by the recording medium (CD or DVD), OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
In general, most DVD's are rated for burning speeds of 1x-4x. Some burners say they can burn DVD's at higher rates but they don't tell you that you need a specific brand of DVD and probably a specific type.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
