Greetings all who suffer from the Vista Wireless dropout problem.
I've done most every fix I could find on line and though the IPv6 box being unchecked was the answer as after I did that everything was fine for several months, then a couple of days ago it was back with a vengence and nothing was working. It seems everytime I get an update from MS for my Vista system something goes haywire. I lose my contact list and have to reboot.
But, for dropouts, I tried a "reset to default" on the power saver settings and so far I'm up and running for over 24 hours. Can it really be that simple? Never could figure out what setting to use per on line suggestions on my Acer machine.
After all this it does seem to be the power save setting some how shuts off the wireless driver even if you are actively using your computer.
Any other comments??? Pass the word it this helps you.
larry in MN.
