Hi Moon, It's not a dumb question. I personally don't use Realmedia player so haven't had any .rm/.Ram extensions so I can't tell you if it would work or not. Perhaps someone else who knows could.
But here's a link to the VCP developers page, you may find an answer there.
Vista Codec Package Homepage (VCP)
Good luck
To determine if your running 32 or 64 hit WIN+Pause/Break and you'll find some simple info.
Good luck
- Self Built
- i7 3770K HT ON 4.7GHz
- P8Z68 Deluxe Gen 3
- 8GB G.Skill Ripjaws X 2133mhz
- 2x Gigabyte GTX 670 OC WindForce SLI
- X-FI Forte + ATH-AD900
- x2 Dell U2410 / 58" Samsung / "40 Sony
- 1920*1200 / 1920x1080
- 2x Intel 520 240GB * Crucial M4 128GB * 2x Samsung F3 1TB (RAID 0) * 2x WD Caviar Blacks 2TB (RAID 0)
- PSU
- Corsair AX1200W
- Case
- Lian Li PC-V1020A
- Cooling
- NH-D14: 3x140mm Gelid Wing 14: Sunbeam Rheobus Extreme
- Razer Imperator + Thermaltake Theron
- Topre Realforce // Ducky Shine Cherry MX Black
- Other Info
- Laptop Specs: Clevo Sager P170HM // 17.3 Matte 1920x1200 // i7 2720QM // 8GB 1333mhz // Dedicated GTX 485M // 240GB Intel 520 + 750GB + Blu-Ray // Samsung Story 2TB USB 3.0
