vista acting weird...help?
seems to be fine, the error message didnt pop up on this re boot. tried a couple google searches and the links were fine. and crossing my fingers, and hoping i dont jinx it, but the windows arent messing up and switching to that grey taskbar. im going to give it a day or two and see how it runs but all is well so far
Okay .... let's get rid of some of the tools I asked you to download.
Combofix uninstall (it can't be kept because there are new versions everyday)
• Click START > Search
• Now type ComboFix /Uninstall in the runbox and click OK. Note the space between the X and the /, it needs to be there.
You can delete RSIT.
Next, download TFC by Old Timer TFC - Temp File Cleaner by OldTimer - Geeks to Go Forums and save it to your desktop.
Save any unsaved work. TFC will close ALL open programs including your browser!
Right-click on the file and choose Run As Administrator.
Click the Start button to begin the cleaning process and let it run uninterrupted to completion.
Important! If TFC prompts you to reboot, please do so immediately. If not prompted, manually reboot the machine anyway to ensure a complete clean.
(this temp cleaner is a good one to keep!)
Now, I would like yout run an ESET online scan:
  1. Hold down Control and click on the following link to open ESET OnlineScan in a new window.ESET OnlineScan
  2. Click the
    button.
  3. For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
    1. Click on
      to download the ESET Smart Installer. Save it to your desktop.
    2. Double click on the
      icon on your desktop.
  4. Check
  5. Click the
    button.
  6. Accept any security warnings from your browser.
  7. Check
  8. Push the Start button.
  9. ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
  10. When the scan completes, push
  11. Push
    , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  12. Push the
    button.
  13. Push
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device. One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
