One other thing to check is that you are connecting to the correct port on the router,
On most standard wireless routers for cable use you will have five ports, four for use with devices, (pc's, printers, etc) and one for use with the cable modem, this is often a cross wired port so these have to be correct.
Thanks Barman58, i have checked that. The cable is in the correct port. It is actually a different colour and labeled "Internet"
- Hewlett Packard
- 3.40Ghz / 2.20Gz Duo Core
- 2GB / 3GB
- 160 GB / 160 GB
