First off, if the PC is only nine months old and you bought it, I’d look to see if the warranty is still good before going through any other hoops.
As for your temp monitoring program -
Try the latest version of
Core Temp, which supports Vista x64, and see what it gives for temps. If Core Temp gives the same readings then something might be going on with one of the sensors on the CPU. I too doubt that that processor could run with that amount of heat.
Using msconfig I got to System/Config/Boot/Advanced where I should be able to select the number of Processors or Cores, it is Grayed Out at One and I Can Not check the # of Processors.
No need to use that – it’s used for testing purposes and does nothing for you! Google it and see for yourself.
Good luck
