tsst corp cd/dvdw ts-l632d ata device
Please answer the following questions.
1) Have you reseated the drive cable (desktop) / Drive (Notebook)
2) Check device manager for ! or ? on the drive.
3) Did the drive open when the system is in BIOS
4) Try to boot using the windows vista dvd & check if it boots or not.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
ok i tried the f2 and the system bio but it didnt work i dont have a drive cable because im on a laptop.ive already done device manager and it says everything updated.now i have like 4 dvds that came with my laptop one is windows upgrade and i havent used any of the discs before.
You can try to use any one of the bootable cd or dvd. Such as windows xp or windows vista.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
You can try to reseat the drive once & then check. If it works then well & good. If not then its time for a drive replacement.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
I have problems with my tsstcorp cd/dvd ts-l632d ata device. I have Vista Home Premium 32bit and HP dv6000. Sometimes the computer finds the device and sometimes not. I have re-installed the Windows and the drivers are new. What should I do?
If you only have trouble with DVD under system - not any boot up trouble you can try install FrogAspi Frog Aspi - the FREE wnaspi32.dll replacement
1.Uninstall DVD driver from device manager
2. Place wnaspi32.dll in C:\Windows\System32 if you have x32 system - for x64 you have to place it in C:\Windows\SYSWOW64
3.Restart computer -system will reinstall DVD driver after restart
Ok. I uninstalled the drivers and the device came back but the computer lost it again. I have unistalled the drivers couple of times but the same happens again and again. What should I do now? Humm..
Saved my life! ;)
The cdgone.reg worked for me too!
I know it's an old thread, but I've looked everywhere for help and the solution is so simple...
thanks again!
Right click it and click merge.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
I've uninstalled and reinstalled the driver. I merged the CDgone.reg. I still I'm having no luck. The door opens and closes fine and I can hear the cd spinning inside the drive, but it never shows up in the explorer or plays. Any more ideas of things to try?
Thanks for the help.
Thank you Tanuj! I wrestled with this issue for a couple of days before finding your post.:D I was close to replacing the CD/DVD drive in my Inspiron 1720 laptop; I would have really been upset after finding out that was not the real issue.
Chuck
