tidserv! inf dhcp wont start ddayww.sys error
according to that link I'm stuck doing a clean install from cd because my cd is sans service pack and i currently have sp2 installed. I will try to extract tdx files manually from the cd and reinstalling sp2. Other than that I think I will repost and see if anyone else has anything to add. Thanks for your efforts.
No problem, I'm sorry I couldn't help more :(
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
do you have a vista machine? if so can you search your registry and find all instances of tdx.dll and export them to a .reg file for me? I extracted tdx.dll from the vista cd and the dhcp service started working again. werid thing is that its no longer listed as a dependancy service for dhcp like it was when i started having these issues. I can get a dhcp address and connect to the web but the network shares are still not visible. I figure if I can re-enter the reg lines pertaining to tdx.sys that should do the trick but I dont have any other vista system in the house.
I searched my registry, and my system, for tdx.dll and found nothing at all :(
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Where did you find your dependency list?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
