ive had the game work b4 and i have all the udates for the card it runs fine till its suposed to get to the menu. the background movie with the map moving is there but no menu
It's due to ATi's Open GL implementation and HDR shading. Basically the card is rendering everything as black.
Turn off HDR rendering, and you'll probably see stuff then. There are workarounds, google Oblivion and Ati HDR. Basically you need to figure which shader set the game is using, and copy the HDR shader set and rename it. Easy to do, you just need to know what to do.
I'll look around and see if I can find the fix. In the meantime you can try disabling catalyst AI and see if that helps. Catalyst AI and Bethesda games don't mix well.
- Q9450 @3.4Ghz
- Asus P5Q Deluxe
- 8GB Corsair Dominator @ 1066
- Asus AH4850
- Samsung 2235BW
- 2x Seagate 750GB 1x Seagate 160GB (IDE)
- PSU
- Cooler Master Real Power Pro 850
- Case
- Cooler Master Cosmos
- Cooling
- Cooler Master V8
- Logitech WAVE Cordless
