System Restore - How to
How to Do a System Restore in Vista
This will show you how to do a System Restore to help you restore your computer's system files, programs, and registry settings to an earlier point in time. It will not affect your personal files, such as e‑mail, documents, or photos, so it cannot help you restore a deleted file.
  • Be sure to use a restore point dated before the problem started or it will not help you.
  • If this System Restore did not help or made things worse and you need or want to undo it, then see: How to Undo the Last System Restore in Vista
System Restore uses this Service with this setting: Volume Shadow Copy
This service is set to Manual by default.
METHOD ONE
Through System Protection
  • If you have not done a system restore before, you will not have the two options below in the first screen of the video below. Just click Next to see your restore point choices.
  • If the System Restore was unsuccessfully completed, then you can try to do a System Restore in Safe Mode or use Method Two below instead.
1. Open the Start Menu.
2. Click All Programs - Accessories - System Tools - System Restore.
A) Go to step 3.
OR
2. In the white line (Start Search) area, type rstrui and press Enter.
NOTE: rsrui is the EXE file for System Restore. C:\Windows\System32\rstrui.exe
A) Click Continue for UAC prompt.
3. Click on the Click to Play button in the video below.
NOTE: After you click Choose a different restore point, make sure you check Show Restore points older than 5 days, if this is displayed, to see your older restore points.
[media]http://www.vistax64.com/download/flash/system_restore.swf[/media]
METHOD TWO
Using System Recovery Options at Boot
1. Boot from either your retail Vista installation disc or created Vista repair disc into the System Recovery Options screen.
2. Click on the System Restore option. (See screenshot below)
3. Follow the rest of the instructions in the video at step 3 on in METHOD ONE above for how to do the rest.
  • Like
Reactions: lux
You're most welcome EverMoreOrLess. I'm happy to hear that you got it all sorted out. :)
Brinks and all others...I can't thank you enough! I knew there was a backdoor somewhere, though it turned out to be the open window by the front door.... It seems I'm learning computing backwards...I've never done a backup or restore until now, and that's about 16 years. Still learning at 77, and very pleased to know there are others willing to help me navigate. God bless and Merry Christmas!
    Dell T5062 X86-based PC
    AMD Athlon(tm) 64 Processor 3800+, 2400 Mhz, 1Core(s), l Log
    1 GB
